#1 |
Member#: 113765
I just wanna post my Protune result @ Dyno Authority (Redmond, WA)
People there are very friendly, and the tuner Tim Hadfield has been awesome. He is not as familar with the Cobb Protune software, therefore alot of time was spent on the non-tuning part on Day 1. (eg. We have to workout some software bugs, and communication errors). However, he is very patient, and show no sign of rushing. I ended up spending my time there from around noon to 6:30pm. The result isn't as good as we want, and there are still something he would like to work on, so I went there the 2nd time today. This time, everything works well. The tune is started as soon as we do a couple of WOT Dyno Pull to make sure everything is at least as good as last time. This time Tim was able to spend 1 hr of good tuning time, and the result looks awesome on the Dyno Chart. Since I know very little about tuning, and my concern isn't on HP alone. I don't want to blow an engine or killing my turbo in a few month or a year. So, I posted the dyno result and a ECUExplorer Log that was logged when the car is still on the Dyno after all the final tune. Please share your opinions. Thanks Here is the link: http://www.pbase.com/freelancerfoto/2006_sti_dyno The following is part of my summary on the result: This are Dyno Result for a 2006 STi Stage 2 PDX OTS Map COBB OTS MAP ProTune ECUExplorer Log @ Final tune on Dyno When I first went on the Dyno, I was on PDX OTS Map (With recent ECU Rest, the result was horrible. The 1st run after the ECU is reset (PDX OTS Map) Result 237WHP @ 6250 234WTQ @ 4500 After a couple full throttle pull, the PDX OTS best # are 247WHP @ 6250 258.8WTQ @ 4250 The Original OTS Cobb Stage 2 Map is almost as good as the PDX OTS (Check the Dyno Chart) 249.9WHP @ 6750 248.3WTQ @ 3750 Final Tune @ Dyno Authority 280.9WHP @ 5500 296.2WTQ @ 4500 Performance Mod: Cobb TubroBack Exchaust w/CAT SPT Intake System COBB AP version 1 Suspension Mod: Cobb Front & Rear Swaybar KW V3 coilover
#2 |
Member#: 18941
NWIC
Vehicle:2005 Lotus Elise Orange |
Wow, numbers look great.
That settles it, I'm going there for a protune ![]() |
#3 |
Member#: 1890
Vehicle:1990 Legacy L Sedan Champagne Rally Car #212 |
Hmmmmm, could this be my long lost cousin Tim?
#4 |
RIP 10/12/83 to 02/10/08
Scooby Specialist Member#: 83254
NWIC
Vehicle:98 2.5 RS 04 WRX |
wow those are some rich AFRs. Ignition timing looks similiar to the tune I did today but the timing on my tune is 17* at peak torque rather than 15* but we were probably using higher octane fuel (Cenex 94+). AFR Target for my tune was 11.5 as well, but again higher octane. Wonder how the two tunes stack up to each other
#5 |
Member#: 113496
Vehicle:... (V) (;,,;) (V) |
Thanks for the kind words Eddy! Glad you are happy with the results.
Ryan @ Dyno Authority. |
#6 |
Member#: 10955
NWIC
Vehicle:07, 06,01,93 I have 4 domtuned subys |
Sweet results.
However, since you posted up the logs and graphs, you are obviously going to get a little critiquing of the tune. From the log: the injectors appear to be over 100% and AFR's look real rich. You probably have about 20hp in fueling. Plus, once the AFR's are fixed, the injector duty cycles will drop down to acceptable limits. The map is very safe and the power numbers are good. In the end, a safe tune and a pleasant experience is all that really matters. I know that the ProTune is new to those guys and it's a good way to start by having happy customers. Hope them the best! |
#7 |
Member#: 113721
NWIC
Vehicle:2002 WRX WRBP |
what type of dyno?
#8 |
Member#: 113496
It's an AWD Mustang Dyno with dual eddy current motors.
#9 |
Member#: 132587
Vehicle:2006 JrTuned STi E85 GT3582r/10.83@126mph |
if you dont mind me asking what kind of $$ did you spend for the tune and dyno time? PM me if you want.
#10 |
Member#: 109002
Vehicle:2005 SYMSTI Aspen White |
i would like to know how much it ended up costing too! please pm me when u get a chance also, do they do ecutek?
#11 |
Member#: 144503
NWIC
Vehicle:2004 FXT Gold |
The dyno chart on the Cobb web for STI indicates stock WHP 238 @ 5300RPM & Torque 248 @ 4500RPM Stage 2 whp 277 @ 5400 And Torque @ 316 @ 3400
What would explain these differences for the SAME pro tune ![]() |
#12 |
Member#: 111165
NWIC
Vehicle:2008 Legacy (Sedan) 2005 S2000 (Supercharged) |
1st, those numbers on their site are for off the shelf maps not a pro tune, 2nd the numbers are from a different dyno so you cant compare them directly, 3rd those are from a website that is used for marketing purposes....
#13 |
Member#: 39806
NWIC
Vehicle:2003 WRX BLK |
#14 | |
NWIC
1. Every car is different 2. Your car probably isn't using the same fuel or in the same enviroment as the car that put the numbers for that tune. 3. Poor Gas 4. Other mechanical issues that keep your car from making that power |
#15 |
Member#: 144503
NWIC
I have Cobb stage 2 on my Forester. I cannot verify the HP. I do now it is running rich. I am looking for a pro tune in the Seattle area. Before I spend the bucks. I wont to verify the tune will be an inprovment. With the Cobb, I have walked away from a stock STI. I run my car at SIR. It will run away from a stock WRX.
#16 | |
Member#: 10955
NWIC
I have quite a few dyno charts that show improvements over COBB OTS maps; some as little as 10, some more than 30hp. So any custom tune (with a skilled tuner) will net you more power. Doesn't really matter the tuning method, UTEC, Open Source, ProTune, Hydra, etc. Each car is different. That's why the cobb maps are rich. They can't hit the peak targets on one car and sell that map. It could run way too lean on someone else's car and blow up. They have to make a map that can help compensate for the idiots out there who do dumb stuff like crank up their MBC. |
#17 | |
NWIC
As a tuner yourself, I bet you've got basemaps that you start off from that run rich AFRs and low timing and then lean it out / advance the timing to each car's needs. |
#18 | |
Member#: 10955
NWIC
I call them my "starter maps". Not sure why I don't call them basemaps... I just like starter more I guess. |
#19 |
NWIC
hehe, to each his own. I think of tuning kind of like building a house (though...I've never built a house...). You need a base to put the foundation on, then build on top of that continually until you are done with the complete project.
yes.. I am crazy ![]() |
#20 |
Vendor
Member#: 144480
NWIC
Vehicle:OBP 05' STi, 02 WRX 01 RS-EJ205, EG33 GM6 |
Removed
#21 |
Member#: 10955
NWIC
sorry. Wasn't advertising. Just trying to help.
Holy paranoia batman |
#22 |
Member#: 111165
NWIC
#23 | |
Vendor
Member#: 144480
NWIC
You got it man, it was a n00b mistake on my part. We are in the process of registering as a vendor right now! |
#24 |
Member#: 111165
NWIC
#25 | |
Vendor
Member#: 144480
NWIC
That they are, but I am OK with that. Since we are new to the game, it's at least good to see that the Mods are keeping everyone on the up & up. As soon as Nick emails me back with the instructions on becoiming a Vendor we will be legit. ![]() |
