Go Back   NASIOC > NASIOC Technical > Engine Management & Tuning > UTEC
Old 03-24-2007, 10:05 PM   #1
Beeya
Member#: 107445
2004 STI
Default GM bcs question with pid boost
Im using a GMBCS w/ a VF39 setup... Im using pid boost. So that being said... 0% colm in the boost map is your target boost... well I had to lower all the values 10%-100% values of the map because the GMBCS is more sensitive that the stocker. does this also mean that target boost needs to be lower?
Beeya is offline   Reply With Quote
Old 04-23-2007, 04:01 AM   #2
Beeya
Member#: 107445
2004 STI
bump TTT
Old 04-23-2007, 04:48 PM   #3
NITROS
Member#: 41561
04 GT3076 2.1
Stroker = Broken 3rd
Target boost is your target boost. whatever you set in the 0% load column is what the utec will try to hit. The values from 10%-100% are based on throttle position. so if you have 50 in the 100% tps column the BCS will start at 50% duty cycle to hit your target boost which maybe at 75%.
You can look at your logs which will show your Boost solenoid duty cycle. You want to set it as close as possible to your target duty cycle for quicker spool up.
NITROS is offline   Reply With Quote
FS: GM BCS boost, GM Boost Control Solenoid WILLFUTHEGREAT Engine/Power/Exhaust 12 04-20-2009 03:06 PM
Reflashed to xpt stg2 gm bcs, not hitting target boost Serkan Open Source Reflashes 6 09-08-2008 02:23 PM
My car has GM GM BCS but was tunned with Factory BCS davedavis1981 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 06-08-2008 06:34 AM
GM BCS Question regarding my TiAL 44mm EWG dexterous Engine Management & Tuning 24 05-21-2008 06:55 PM
question with blitz boost controller... HELP! 2.0TURBOwrx Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 9 04-14-2005 10:07 AM
