Old 03-25-2007, 11:09 AM   #1
Magnum626
Member#: 62856
MBP SQC#197
Stockpiling parts...
Default Broken bugeye fog adjustment screw
The screw to adjust my driver's fog appears stripped. Not the screw but the adjustment ability.
Is there anyway to fix this? Can I just replace the white plastic piece in the back?
I tried to search but didnt' find anything about repair.
Magnum626 is offline   Reply With Quote
Old 03-25-2007, 09:52 PM   #2
Bluefoton
Member#: 141373
2008 2.5i-hatch -
now with a HID retrofit
Rest assured. First thing I did when I bought my used car a month ago is to try to adjust the fog light beam (after well reading the instructions on how to do it). Ripped off the head of both adjustmentscrews, and subsequently, off 2 out of 3 of the mounting screws for each foglight. My mechanic told me he can't replace the screws, and that I'd have to buy the full OEM fog light mount.
Bottom line: I took a little piece of wood and stuck it underneath the foglight, basically immobilizing it in the exact position i wanted it to be. Alternatively, use a piece of rubber cut off an eraser, or anything else which fits under it blocking the fog light enough so it doesnt move, but still leaving some room for twisting it should you need to readjust it.
Old 03-26-2007, 01:04 AM   #3
Magnum626
Member#: 62856
MBP SQC#197
Ack, I don't wanna have to do that. But it looks like the plastic piece where the adjustment screw is comes off. I haven't taken it off yet since I just replaced my bulbs.
Maybe someone has a broken foglight they wanna send me? I'll pay for shipping.
Also what happens when you hit something hard enough the wood/eraser pops off?
Old 03-26-2007, 10:07 AM   #4
Magnum626
Member#: 62856
MBP SQC#197
So, any other options than a new foglight? I don't know if I could just buy one rockblocker film. lol
Anyone? Bueller?
Old 03-27-2007, 12:55 AM   #5
Bluefoton
Member#: 141373
2008 2.5i-hatch -
As ugly as my description appears to be, its really not that bad! Bumps, snowpiles, potholes, and the fogs didnt move by a milimeter. Get something black to stick in, and you won't notice a thing - and it will hold it in place really well.
Well alternatively you could flood the entire foglight casing with epoxy, but.....
Old 03-27-2007, 05:41 PM   #6
Magnum626
Member#: 62856
MBP SQC#197
^^LOL....
I'm gonna see if anyone has a spare lying around.
Old 03-28-2007, 12:38 AM   #7
Bluefoton
Member#: 141373
2008 2.5i-hatch -
Consider then changing them. I recall reading good opinions about Hellas, and I think all it takes to fit them is some simple custom-made bracket. Then again, I don't know if with busted screw heards, you don't actually need to change the entire casing.
Stick things under the foglight!!!
Old 03-28-2007, 01:23 AM   #8
Magnum626
Member#: 62856
MBP SQC#197
It's not the heads, it's just the adjustment screw. It just turns and doesn't move the light anymore. And that comes off with the fog.
Thanks...maybe I'll look into the hellas.
drivers side marker, fog light back plate, and a broken bugeye headlight The Beej Exterior/Styling 3 03-20-2010 03:15 PM
Where is the other headlight adjustment screw? hklaine Legacy Forum 3 03-23-2004 11:13 PM
Where's the headlight adjusting screw on my STI? 4kornerz Electrical & Lighting 6 11-14-2003 08:47 PM
Lost the HKS BOV adjustment screw MAD REX Factory 2.0L Turbo Powertrain 0 09-27-2003 02:59 PM
Where is/ or is there an idle adjustment screw for 02' Wrx? PaulRex Factory 2.0L Turbo Powertrain 5 02-14-2003 06:19 PM
Message Board Statistics All times are GMT -4. The time now is 02:25 AM.
