Old 03-25-2007, 08:54 PM   #1
Matt_H
Member#: 107000
2015 BMW X1
Default Flashed to VF-39 93 map, says VF-39 91 map
I got my turbo installed today and flashed to the VF-39 93 map. I have been driving around on it, decided to hook the AP back up. I went to show current map and it displays VF-39 91 map.
So I hooked up the green connections and tried to flash to the 93 map, but it said it was loaded onto the car already. How long should it take to flash the VF-39 map? It took about 1 minute and it seemed pretty fast compared to flashing to stage 2.
Matt_H is offline   Reply With Quote
Old 03-26-2007, 02:54 PM   #2
twizzstyle
Member#: 18941
2005 Lotus Elise
Orange
Did you flash the 93 BASE map, or just a realtime map?
Sounds to me like you did a realtime map, which should take a few seconds, a base map will take a few minutes.
twizzstyle is offline   Reply With Quote
Old 03-26-2007, 02:56 PM   #3
Matt_H
Member#: 107000
2015 BMW X1
Yea I was thinking about it earlier and I think thats what I did. But it still should not read as a 91 octane map, when it was 93.
Old 03-26-2007, 03:49 PM   #4
Airboy
Member#: 72829
2006 WRX
2015 WRX
The AP (v1 anyways) reports the last Base map that was flashed into the ECU. It doesn't keep track of the Real Time maps that you may have loaded in after.
Airboy is online now   Reply With Quote
Old 03-26-2007, 05:26 PM   #5
dcpatters
Member#: 125278
2011 X MR
AS
Try it again, but select "Change Base Map". Then read the current map.
dcpatters is offline   Reply With Quote
Im Stuck! Error "choose new map to flash to ECU" thetomstudley AccessPort 1 11-26-2008 11:38 AM
does the vf-43 crack like the vf-39 NVSPRELUDE Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 02-14-2008 10:54 AM
93 octane on 91 map bjonesy Commercial ECU Reflashes 9 08-21-2007 05:30 PM
need map for vf-39,sti pinks,sti intercooler.. werkInProgress Engine Management & Tuning 6 03-16-2005 07:54 PM
AccessPort - Running 93+ on 91 map UncleMeat Engine Management & Tuning 10 07-23-2004 03:32 PM
