Old 03-12-2007, 05:32 PM   #1
turboscooby13
Member#: 56280
2003 M3
Default Quick question on dimming Defi
Just bought a Defi Blue Racer boost gauge to replace my old cheapie SPW. Quick question though... when the key is in the "ACC" position, the gauge is brightly lit. However, once in the "ON" position, the gauge dims out after the opening mode and isn't lit as brightly. Does anybody know if these gauges are supposed to dim out or do I need to check my wiring again? Thanks!
turboscooby13 is offline   Reply With Quote
Old 03-15-2007, 03:21 PM   #2
smoSTI
Member#: 99962
2005 WRB STi
'88 Porsche 944
The brightness on mine from Acc to ON doesn't change, only when the headlights are on and it gets a signal on the illum wire. With that being said I usually run my main tach/speedo at Illum 4 and my Defi at 1 down from the brightest. I haven't tried the Defi set to a low illum setting and then powered on the car so the unit very well may perform the initial power on cycle at full illumination and then load up the last user specified illum setting.
Not much help huh What happens when you turn the headlights on, does the gauge dim more?
smoSTI is offline   Reply With Quote
Old 03-26-2007, 10:01 AM   #3
turboscooby13
Member#: 56280
2003 M3
Interesting... how do you change the illumination setting on the gauge itself? It doesn't use the link system, so I'm not sure how I would change that.
quick question on similarities on harnesses simprezl25 Subaru Conversions 1 11-29-2005 09:42 AM
quick question on 99 rims HydeX Brakes, Steering & Suspension 2 09-05-2001 09:21 AM
Quick question on Vent style : ) STi-Nismo Dood Interior & Exterior Modification 1 05-07-2001 07:00 PM
('93-'01) Quick Question On Taking Front Seats Out STORER Impreza Forum 4 04-08-2001 11:43 PM
Quick question on Heads The_extreme Technical Forum Archive 2 07-17-2000 06:57 AM
