Vancouver Impreza Club
Old 03-27-2007, 04:47 AM   #1
timothyip
Member#: 135649
2004 STi Prodrive
SOLD SOLD SOLD
Default STi or WRX's temperatures
hey all.. .....what's your normal oil & water temperature & oil pressure ?? (GC and GD guys)
timothyip is offline   Reply With Quote
Old 03-27-2007, 11:02 AM   #2
veightkiller
Member#: 78967
2011 335i
180-200 F on my sti
veightkiller is offline   Reply With Quote
Old 03-27-2007, 12:03 PM   #3
steve
Member#: 4718
~ too
many to list
I remember the early days of the WRX when it was found that water temps of 225+ were enough to cook an ej20. That seems to be pretty close to the danger zone for all aluminum engines.
steve is offline   Reply With Quote
Old 03-27-2007, 12:50 PM   #4
wrxdrvr
Member#: 79222
'09 STi 297.5 WHP
My water temps for my '02 wrx 4EAT are in the range of; Lowest 81*C, Average 86*C, Highest 96*C.
wrxdrvr is offline   Reply With Quote
Old 03-27-2007, 05:37 PM   #5
banman
Member#: 12408
2006 Legacy GT
Oil: 90C
Water: I dunno - whatever halfway between "C" and "H" is.
Oil Pressure: 6.0kg/m^3 under load
banman is offline   Reply With Quote
Old 03-27-2007, 06:32 PM   #6
tora
Member#: 5851
09 Forester XT
+ NA Miata
86-96 '04 STi
tora is offline   Reply With Quote
Old 03-27-2007, 08:26 PM   #7
semaj
Moderatour
Member#: 113533
2013 Leafs
Hatewagon
1/3 of the way up from "C", on the way to "H"
semaj is offline   Reply With Quote
Old 03-27-2007, 10:19 PM   #8
wrxdrvr
Member#: 79222
'09 STi 297.5 WHP
Originally Posted by banman View Post
Oil: 90C
Halfway between "C" and "H" is 71*C to 99*C.
Old 03-27-2007, 10:34 PM   #9
veightkiller
Member#: 78967
2011 335i
that thing don't barely move.if you have a guage you'll see it dropping down when the fans turn on.
Old 03-27-2007, 11:03 PM   #10
wrxdrvr
Member#: 79222
'09 STi 297.5 WHP
I have never, seen my gauge move when it got to Halfway to "C" and "H" exept when I put in a metal treatment in my oil and now it only gets to about 1/8" up to the 1/2 way mark now, and it still just sits there NEVER moves....
Old 03-28-2007, 02:35 PM   #11
patr
Member#: 97
some good misinformation in this thread (of course this post is probably considered mis-information by someone else as well, so take the internet for what its worth please)
anyways, you can get serious variance with ANY aftermarket sensor by just installing it in a different place (hot place, cold place, externally cooled place, etc. etc.). Never mind the brand, type, model line tolerances, etc.
the ECU has a coolant temp sensor, stock, so going by that one, you dont want the car much over 100 C. The 2 stage fans kick in at different ECU coolant temps, approx 95C on average. The car is considered "warm" by the ECU after 87. Note that the stock gauge is in the middle well before this...The STOCK temp gauge reads "in the middle" across about 20C of variance. if your STOCK temp gauge is at all high, you are TOO HOT.
Most people will use the oil warning light plug as the oil temp sender, and in this place . oil temps should mimic water, be a big higher and a bit cooler depending on when reading. Oil can go higher than water and still be ok if it doesn't break the oil down leading to low pressure or start heating up the water. Disagreeing with what was written about Ej20s, I have seen many a car driven hard on the track or on stages with oil temps peaking in the o240s (and even higher!), point being oil temp is not important (unless its cold), oil pressure is (oil press will go down as oil temp goes high). But dont take that to mean >210 is ok ! Oil coolers are a good thing.
Oil pressure anything below 2-3bar when revving is bad ! on decel or on hard cornering, you will see why people put in baffled sumps and oil accumulators. Oil pressure "at idle when hot" is mostly meaningless unless its below 20psi (again, depending on the sending unit, unit location, type, etc.). Cold start you can see 100. Oil viscosity and oil temp plays a big role here too (regading the pressure). Subaru OEM uses defi-type BTW.
patr is offline   Reply With Quote
Old 03-28-2007, 03:46 PM   #12
Dalton
Member#: 90245
2004 STi
I have to say that everytime I read one of patr posts I feel more edumacated.
Dalton is offline   Reply With Quote
Old 03-28-2007, 04:48 PM   #13
semaj
Moderatour
Member#: 113533
2013 Leafs
Hatewagon
+1
Old 03-28-2007, 07:54 PM   #14
Dendrobium
Member#: 24234
2003 WRX Wagon 5sp
I have an EcuTek Dash Monitor that supposedly monitors the WRX 2.0L ECU's coolant temp reading. I also have a speedmonkee all aluminum rad (the stock rad's plastic endcaps started leaking coolant), and I don't run any high-psi rad caps.
That being said, I can confirm that the stock gauge is really an "idiot" gauge, and often reaches the middle long before the EcuTek Dash Monitor reports anything close to 80/90C. Once it reaches the middle, it hardly moves at all.
FWIW -- I consistently see:
87-89 (High-speed highway, or cold winter days)
89-91 (Normal traffic or normal rainy day)
92-94 (Hot summer city traffic, or stuck in an underground parking lot, fans kick in periodically at this point)
I have a slightly mismatched oil temp setup -- I have the EcuTek Dash Monitor reading my Subaru OEM oil temp sensor at the oil drain plug. I don't know if this sensor is really matched up well as it's made to send to the OEM LAMCO gauges, and may not provide Defi signal levels that the EcuTek Dash monitor expects.
Anyways -- qualitatively I notice that the oil temp takes considerably longer (ie. perhaps 5-10 minutes more) to warm up than the coolant does. My normal oil temp is in the range of 90-100C -- but this could be because the thermistor in my OEM LAMCO sender is mismatched to the one that the EcuTek Dash Monitor expects.
Dendrobium is offline   Reply With Quote
Old 03-29-2007, 12:56 AM   #15
patr
Member#: 97
its "OEM" (note the quotes) - differing model years have differing sensor sending unit "companies", the newer stuff is exact same parts as defi stuff (and even has defi logos on it), the older "lamco" stuff is same signal at least for the "factory" 3 gauge dash cluster (but you pay double) - and feel free to infer whatever you want from my quotes
they are the "same", in more ways than just "signal"
this is normal, and what it should be. As per above:
oil temps should mimic water, be a bit higher and a bit cooler depending on when reading. Oil can go higher than water and still be ok
its typically a bit hotter if running hard. oil psi is way more important
Old 03-29-2007, 04:15 AM   #16
timothyip
Member#: 135649
2004 STi Prodrive
SOLD SOLD SOLD
thanks all guys........nice informations~~~i will figure it out......haha
Old 03-29-2007, 12:46 PM   #17
Dendrobium
Member#: 24234
2003 WRX Wagon 5sp
Thanks pat. I always wondered whether it would be ok to reuse the "OEM" sensor with my dash monitor.
Sorry this is a bit OT -- but how non-ideal is the oem location (at the drain plug) I've heard it is a poor location to read oil temp and is disproportionately sensitive to ambient air cool-off while driving?
Old 03-29-2007, 01:01 PM   #18
patr
Member#: 97
the "dealer option" gauge pack (as opposed to "factory" gauge pack) is geared towards being just that, a "dealer option", so of course the location, installation, integration with other components, etc. is all considered into that
I would agree, but "non-ideal" in a street type of application where it most likely will never exceed normal temperatures is "probably ok"
I like getting it under pressure, in a non-cooled location, that also doesn't interfere with oil changes, and has a small chance of getting ripped off... like where the warning light is
Old 03-29-2007, 04:36 PM   #19
shawmacs
Member#: 111284
2005 WRX Wagon
Platinum Silver
It's just "quote city" in here
shawmacs is offline   Reply With Quote
WTT-S2000 for STI or WRX's young buck Private Vehicle 'For Sale' Classifieds 56 08-09-2009 03:08 PM
oil pressure or exhaust temperature? omfgSTI!! Interior & Exterior Modification 12 03-16-2007 02:15 PM
Oil pressure or oil temperature gauge? skubie209 Electrical & Lighting 6 04-22-2005 03:55 PM
Oil Pressure or Oil Temperature, you decide nhluhr Electrical & Lighting 6 03-17-2004 03:43 PM
is there any Imported STI's or WRX's from Europe? Joem32 Mid West Subaru Owners Club Forum -- MWSOC 3 11-22-2002 08:00 PM
Message Board Statistics All times are GMT -4. The time now is 09:13 PM.
