Old 03-27-2007, 04:06 PM   #1
WRX26
Member#: 119754
2001 Camaro SS
Red
Default 06 STi Intake Manifold on 02 WRX
Hey does anyone know if an 06 STi intake manifold will bolt up to an 02 WRX??
WRX26 is offline   Reply With Quote
Old 03-27-2007, 06:52 PM   #2
Jasper
Member#: 80136
2006 Ford F-150
no
they wont. your throttle body is drive-by-cable
06 STi (or any STi for that matter) is drive by wire.
you will need to do some modifications.
Jasper is offline   Reply With Quote
Old 04-02-2007, 09:46 AM   #3
SIBzzz
Member#: 129888
Liquid Copper
is there a reall big gain in performance doing this mod, or just doin tgvs is better.
SIBzzz is offline   Reply With Quote
Old 04-02-2007, 10:01 AM   #4
SplatZ400
Member#: 84377
2011 335d
there is no difference in intakes except for the crinkle red and the location of the holes for the TB.
SplatZ400 is offline   Reply With Quote
Old 04-02-2007, 01:04 PM   #5
Homemade WRX
Member#: 33782
96 bastard child
search FIRST, then PM!!!
Originally Posted by Jasper View Post
no
this is wrong...the manifold will but the throttle body won't...there is no point in doing it other than asthetics. The only difference is the STi has the powder coating.
Old 04-02-2007, 01:53 PM   #6
MJU1983
Member#: 14364
2003 WRX, '06 Armada
05 Vette & 05 STi (sold)
no
Except the JDM STi's...they are staying true with a throttle cable.
MJU1983 is offline   Reply With Quote
Old 04-07-2007, 11:08 AM   #7
god910
Member#: 95443
2003 WRX
Sonic Yellow
Here's the skinny... the STi DBW T/B doesn't use the air bypass that the cable driven WRX TB does. It WILL bolt up, the TB will bolt onto it, but it won't work, because (as you'll notice if you look) on the WRX intake there is a big hole at the bottom at the base of the TB, the STi one doesn't have that. It's been said that you can dremel out the STi mani for use on the WRX cable driven TB, but I'm not sure if anybody has done it. All this info came from Phil at Element Tuning.
god910 is offline   Reply With Quote
Old 04-08-2007, 04:46 PM   #8
wrxfactor
Member#: 49978
2002 WRX w/ JDM STi
6spd, EJ255, VF39 & EWG
Wrong^^
Correct, there is a technical issue that prevents the swap. If someone really wants the swap they can switch to DBW, for which you'll need the TB, pedal box and assembly, and an ECU that works with DBW. Seems like a big waste for a non-benefit as far as I'm concerned.
wrxfactor is offline   Reply With Quote
STI Intake Manifold on a WRX P.J. Newbies & FAQs 2 05-27-2007 04:30 PM
06 STi Intake Manifold on 02 WRX WRX26 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 03-27-2007 07:22 PM
Sti intake manifold on a wrx Se7enrex Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 12 10-20-2006 02:48 PM
STi Intake Manifold on 03 WRX CatchMyDrift Subaru Conversions 4 02-09-2005 06:39 PM
sti intake manifold on 03 wrx Smoke Show Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 8 03-14-2004 04:50 PM
