Old 03-27-2007, 07:42 PM   #1
mamiyarz67
Member#: 55940
05 LGT 5SPD WGN
Brilliant Silver Metallic
Unhappy Could i have "overheated" the window motor?
Im hoping that you will all say "Yes" and illl feel better - at least till i go out and find that my window still wont go up
in attempting to fix my speaker again, i ended up popping the white plug out of the passengers side door arm rest, and lost the 2 balls that go in the switch. I found them and in trying to get them in, with the proper orientation to the levers, ended up heating up the motor something fierce. Now it makes little if any noise, but doesnt move the window ... its all the way down, the last thing I wanted it to do, but I had to test it :P Least im at home, and not in boston on vacation like I would be in 2 days! :/
So, can you over heat it, and it will stop working for a while, or am i def going to need a new window motor.
PS _ any way to raise it by hand? I tried pulling it but nothing :P (hoping for a hex nut or something to drive it with by wrench?
mamiyarz67 is offline   Reply With Quote
WTB: Window motor for the rear/driverside window Stivie NWIC Private Classifieds 2 02-11-2008 03:19 AM
Window motors - rear doors the same as the front? moogoob Service & Maintenance 8 09-24-2005 01:20 AM
02 TS - How do I get to the window motor? jasona Electrical & Lighting 1 06-24-2004 08:57 PM
does anyone have a window motor? JaBooo Tri-State Area Forum 1 05-18-2003 05:50 PM
My window motor broke. the window fell off the track..help DoctorNick Service & Maintenance 1 01-26-2002 03:55 AM
Message Board Statistics All times are GMT -4. The time now is 03:14 AM.
