Old 03-27-2007, 11:49 PM   #1
avant-gardewrx
Member#: 115433
2004 Wrx
WR Blue
Default tt help
does anyone know where i can find the pics/ directions to make my tt work with my factory remote and alarm. I really need pics
avant-gardewrx is offline   Reply With Quote
Old 03-29-2007, 12:04 AM   #2
t4nk
Member#: 129905
2005 WRB WRX
2003 F-350SD, 7.3PSD
its not that hard man. above the fuse block under the dash there is a black box with a wire harness connected to it. Cut the Dark Green wire w/ black stripe.
t4nk is offline   Reply With Quote
Old 03-29-2007, 12:25 AM   #3
avant-gardewrx
Member#: 115433
2004 Wrx
WR Blue
I did cut it, but there are three green with black strip wires. the one i cut was the darkest, but it cut the arming flash to one side of the car.
Old 03-29-2007, 09:05 PM   #4
avant-gardewrx
Member#: 115433
2004 Wrx
WR Blue
can anyone help me
Old 03-29-2007, 11:46 PM   #5
t4nk
Member#: 129905
2005 WRB WRX
can you take a picture of what you cut and the other possible wires to cut and post them? That would help a lot.
Sounds to me like you are cutting one of the wires that plugs in to the same plastic peice as the fuse block. My friend did that on his and his left blinker wouldn't work. Its got wires for blinkers, and air bag. Make sure you are cutting wires on the black module above the fuse block.. If you need better access to the wires, the module is on a metal bracket, you can bend it down a little and bend it back up when you are done.
Old 03-30-2007, 07:07 PM   #6
avant-gardewrx
Member#: 115433
2004 Wrx
WR Blue
For all those who need help finding the correct green wire with a black stripe
I have pictures of the harness you need to cut to make the turbo timer work with factory remote entry system. But, I canít figure out how to put the pics on though.
Any way the correct wire is on the black box above the fuse box. It says Subaru keyless/ remote entry system on it.
Take it off by removing a 10 mm bolt holding it on.
Next with the side of the black box with no writing facing you, find the dark green wire with a black stripe on the right side of the harness. If you cut it the wrong dark green wire with a black stripe when you lock the car only the right side will flash.
Cut it, tape it, and test it!
Reassemble and your done.
I did this on my 04 wrx, If you need pics or can help me post them for all, pm me.
P.s. Accept your own liability when you do this, donít point the finger at me for trying to help others.
Old 09-29-2007, 02:46 PM   #7
srREXed
Member#: 72234
2004 WRX SRR
EJ257-35R-6MT
What are the sob stories of doing this? has anyone messed anything up, or does this green/black stripe wire soley make the keyless unit see the vehicles running state?
srREXed is offline   Reply With Quote
Apexi TT help kavlaq Electrical & Lighting 3 06-23-2003 11:40 AM
Another HKS TT help thread Wagon Guy Electrical & Lighting 4 10-13-2002 11:20 PM
('93-'01) Greddy TT help please? TaiChih Impreza Forum 2 02-02-2002 07:35 PM
