Old 03-28-2007, 05:52 AM   #1
nhat
Member#: 140163
03 STi
hellaflunctional
Question benefit of sandwich adapter?
Sandwich Adapter is a sensor install adapter that slips in place where your oil filter is installed and your oil filter then piggy backs on to this adapter(hence sandwich). The sandwich adapter has 3 sensor input ports for installing Oil Pressure and/or Oil Temperature and can be a usefull install accessory but is not an absolute requirement.
are there any benefits to having the sandwich adapter? ease of install? multiple oil gauges?
Old 03-28-2007, 07:35 AM   #2
Fred Fredburger
Member#: 2539
Ease of install! It definitely beats having to dig around for the gallery plugs (including having to pull the IC) and it's pretty easy to reverse.
Fred Fredburger is offline   Reply With Quote
Old 03-28-2007, 11:16 AM   #3
nhat
Member#: 140163
03 STi
hellaflunctional
all i've read is threads ranting about how the sandwich adapter won't fit and the fitment issue isn't specific to one model year. user error or fitment issue?
Old 03-28-2007, 11:27 AM   #4
Fred Fredburger
Member#: 2539
I don't know what their problems would be. I would think the fitment issue would fall into two categories... 1) wrong size/thread extender and 2) clearance issues.
I believe both issues would be user error.
I had neither problem with mine. Sure, there would be a clearance issue if I wanted either sensor to point towards the pan (where there's very little clearance), but that restriction may only be 100° (out of the whole 360°).
This was the one I bought in November.
Old 06-16-2007, 10:57 AM   #5
jim1969
Member#: 34877
2005 Legacy GT sedan
can you install a sandwich adapter and plug one of the holes? I only want to run oil temp at this time and don't want the hassle of galley plugs.
jim1969 is offline   Reply With Quote
Old 06-16-2007, 11:22 AM   #6
Fred Fredburger
Member#: 2539
It should come that way.
The sandwich adapter that I got had three 1/8" NPT holes, two of which came plugged. I think this is standard for any sandwich adapter; they leave one port open, assuming you're going to put something into it immediately, and they put plugs in the rest.
Old 06-16-2007, 11:23 AM   #7
jim1969
Member#: 34877
thanks.
Those of you with sandwich adapters sixthgear Vancouver Impreza Club Forum -- VIC 25 03-29-2010 12:20 AM
WRXtra sandwich adapter? Prosport sandwich adapter? niblick Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 0 10-30-2007 11:17 PM
Pics of my VDO gauge install <56k beware> with prices and sandwich adapter shadoboxer Mid Atlantic Impreza Club -- MAIC 5 05-29-2004 10:25 PM
2 versions of Defi Oil Sandwich Adapter? korpse Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 03-23-2003 07:50 PM
