Old 12-10-2001, 12:04 AM   #1
supermarkus
Member Sales Rating: (13)
Member#: 6971
2008 WRX STi
SSM
Talking Greddy 52mm gauges from Vivid!
I received a full set of Greddy gauges from Vivid Racing, thanks Dan, overnight UPS earlier this week. I went with the black 52mm electronic boost, egt, and oil pressure. I had previously purchased a gauge mask and pod from Derres Catalano so with the gauges finally in my grubby mitts, I was all set for a fun weekend install.
Upon some research I decided that I would run the boost and oil wires and wait until I got a 1/8 BSPT tap, some help, and some drill bits to do the EGT sensor. As I got further into researching, I found I'd need to find a 24 mm wrench and a 17 mm wrench for the oil senders. So running short on time, I just left the oil sender line taped off to my throttle cable until I got the right tools. I'm also considering running a SS braided tube to the firewall and teeing off from there so I can keep my stock oil sender along with the Greddy unit.
The gauges fit very well in Derres's mask but do not come with any sort of retention system so for the mean time I just zip tied them in place. I'm going to CAD a retainer for them this week and see if I can talk our machine shop into making the part for me. Also, the Greddy gauges stick out of the mask further than the Autometer gauges the mask was designed around but I can live with that.
I soldered all of the power lines together according to their color groups, dremelled off the clock's wiring harness fitting, unsoldered the pins from the clock circuit board and crimped the lines to their respective pins. I then glued the pins into the wiring harness piece and plugged it in. The gauges lit up perfectly.
Then I put the car up on ramps, and ran the wires/tubes for the sending units into position and plugged the boost harness into the gauge.
At idle and off boost I'm reading anywhere from 650 to 550 mmHG vacuum and I peak out at about .98 kg/cm2 in 3-5 gears at ~5000 rpm. I had a slight leak from the BOV line but a hose clamp fixed that. The illumination doesn't change, but I was expecting that. However, they do match the stock gauge lighting very well. They're worth the extra cost in my opinion because of their ease of installation, accuracy, and looks. I'll come back to this post later when I have access to a digital camera and post the rest of the results.
supermarkus is offline   Reply With Quote
Old 12-10-2001, 01:10 PM   #2
mitch808
Member#: 10228
2002 Subaru WRX
Derres gauge mask doesn't have retainers because he had the Autometer gauges in mind when making them. Don't know if you took a look at mine a couple weeks ago while at Jacob's home.
But I believe he was working on something to accomidate you guys too.
mitch808 is offline   Reply With Quote
Old 12-10-2001, 11:12 PM   #3
supermarkus
Member#: 6971
2008 WRX STi
SSM
Yeah, I gawked and drooled over your gauges at Jacob's house. I wish Greddys came with brackets. I couldn't find a solution from Derres' thread so I poked around work today in the engineering toolboxes. It turns out hot glue guns make pretty darned good mounting brackets! We'll see how long it holds out but for now things are in place, not moving and I spruced up my wiring harness with some solder and shrink wrap tubing. Very nice now. I may eventually give RTV a shot if the hot glue doesn't want to hold very long, I'm thinking it won't but it's good enough for government work.
Old 12-12-2001, 03:50 PM   #4
WRX addict
Member#: 13043
2002 WRX Sedan
Platinum Silver Metallic
Have any pics?
WRX addict is offline   Reply With Quote
Old 12-21-2001, 05:25 AM   #5
supermarkus
Member#: 6971
2008 WRX STi
SSM
Default Pic
Here is a pic of my gauge pod installed. Note that it has not been completely installed, I still need to hook the EGT sender up and then I can push the pack on all the way.
Thanks to iv30 for the shot, I'll try to get a closer shot later.
it would help if I attached the image
Old 12-21-2001, 01:09 PM   #6
WRX addict
Member#: 13043
2002 WRX Sedan
Pretty cool! How much did those babies cost?
Where did you get them?
Old 12-25-2001, 07:57 PM   #7
Graham
Member Sales Rating: (1)
Member#: 11931
2001 2.5 RS Turbo
257/FMIC/T3-T04S
I've got, EGT, Fuel Pressure in my RS. I paid $300 for EGT and Fuel Pressure. They are kinda pricey but they look VERY nice in the car. I personally like the white faced gauges better because they match my white faced dash gauges.
Graham
Graham is offline   Reply With Quote
FS: Greddy 52mm Gauges, GD JDM Kakimoto Exhaust, JDM corners SubyDoobyDoo Private 'For Sale' Classifieds 7 09-09-2003 07:46 PM
Greddy 52mm gauges mr2guru Electrical & Lighting 1 08-10-2003 09:02 AM
Greddy 52mm gauge depth question. Cosworth Factory 2.0L Turbo Powertrain 1 12-31-2002 01:48 AM
fs: Set of Greddy 52mm gauges mpj_becks Bay Area Impreza Club Forum -- BAIC 9 05-28-2002 02:29 PM
depth of greddy 52mm gauge? scoop Factory 2.0L Turbo Powertrain 2 12-11-2001 12:21 AM
Message Board Statistics All times are GMT -4. The time now is 08:57 AM.
