Welcome to the North American Subaru Impreza Owners Club Thursday September 1, 2016
Old 03-28-2007, 07:50 AM   #1
Mk3Design
Member#: 123512
Default My OBDII scanner doesnt work...
I went and bought a OBDII scanner yesterday because no one rents them out..and the car wont drive to AutoZone..
Anyways It works fine in my wifes car. But when I plug it in it gets a err1 message and thats all the screen shows. I think it means it has a bad connection. If I jiggle it around it pops up for aboue 1/2 a second and thats all...so there is no time to read the codes - let alone go through them all..im sure I have a few.
just wondering if this has happened to anyone else before and how they fixed it, or is my car's connection just jacked up and Im screwed?
Mk3Design is offline   Reply With Quote
Old 03-29-2007, 01:07 AM   #2
Fred Fredburger
Member#: 2539
I don't have any experience with troubleshooting OBDII connection errors, but were there any sort of memorable events leading up to your car not being driveable to Autozone? Water damage? Electrical gremlins? Fuses?
Fred Fredburger is offline   Reply With Quote
Old 03-29-2007, 07:58 AM   #3
Mk3Design
Member#: 123512
My car just idles very rough for like 10 seconds then it dies. I thought it was my old L motor.. So I dropped in a EJ25 and its the same problem..so I know its somthing w/my old harness/ecu/MAF as those are the only things I re-used..
Should I try to replace some fuses though
Old 03-30-2007, 12:19 PM   #4
bluescoobywagon
Member#: 14911
Not A Wagon!
2011 WRX - 285s on 18x9.5
Is the MAF in backwards?
bluescoobywagon is offline   Reply With Quote
Old 03-30-2007, 12:33 PM   #5
Fred Fredburger
Member#: 2539
I just cleaned my MAF last week and when I reinstalled was thinking, "I gotta make sure I put it in the right way!"
That'll be pretty dang slick if that's what it is, but I don't think that'd cause an OBDII reader to not work.
Mk3> Does the OBDII act normally when it's plugged in for the ten seconds the car is running?
Old 03-30-2007, 02:51 PM   #6
bluescoobywagon
Member#: 14911
Not A Wagon!
The MAF shouldn't cause the connect errors. However, it could cause the stalling.
Old 03-30-2007, 02:54 PM   #7
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
'09 Concours 14 ABS Black
ECM = Fried
Old 03-31-2007, 03:34 AM   #8
Spec_C
Member#: 91423
Chapter/Region: HIIC
2004 PSM STi on Meth
Tuned by Chris [email protected]
Impreza WRX STi
i have a 04 wrx and when i purchased my innovate obd2 scanner it would also put out an err code. come to find out, the software was too old i guess. i called their support line and they had me ship it back and replaced it with one that had the correct software.
Spec_C is offline   Reply With Quote
Old 03-31-2007, 12:01 PM   #9
RP31
Member#: 123574
2005 2.6L 9:1 425WHP
CGM STi
Who makes this scanner, and what model is it?
RP31 is offline   Reply With Quote
Old 03-31-2007, 10:55 PM   #10
bcblues
Member#: 17256
04 STi
Blue w/ custom bug splat
Some scanners (especially the cheap ones) seem to crap out on the Subies. I went to buy one at a shop and I tried it out first - no go (err). So they brought out their high-dollar unit - no prob. Clearly there are times when you "get what you pay for". With OBDII scanners, it seems to be one of those times.
PS: If anybody knows of an inexpensive OBDII scanner that works CONSISTENTLY on subies, please share it with us!
bcblues is offline   Reply With Quote
Old 03-31-2007, 11:05 PM   #11
Fred Fredburger
Member#: 2539
I use a ScanGauge and I love it. I don't know if it's expensive or inexpensive compared to other OBDII scanners, but I am pleased with it. In addition to having no problem reading and clearing my codes (especially that pesky P0420!) it also records your mileage for the current trip/today/yesterday/tank. I also use it as an accurate speedometer (you can enter a ±%). It's also great for showing various readings from your car (water temp, intake air temp, volt, rpm, etc).
Old 03-31-2007, 11:07 PM   #12
RP31
Member#: 123574
CGM STi
Define inexpensive... I ended up getting an Actron CP9175 for about $80 from Amazon.com. It's a nice unit. Shows the code and the description on the screen, displays freeze frame data, I/M readiness, is upgradeable, and of course clears codes too. Actron has lower units that will probably perform just as well, but won't have as many features. I really wanted the code descriptions on screen, so I sprung for it. But you can get a lower model for $35-$50 less.
Old 04-01-2007, 11:33 AM   #13
bcblues
Member#: 17256
04 STi
I can't remember the brand that I was looking at, but it was on sale for $99. The shop's "pro" model (which I expect was over $500) read fine. I have tried the really cheap ones (like $30) and I have not found one that works on my 04 STi. If anybody knows of a REALLY cheap one that actually works (both reads and clears), please share!
For now I am using EcuExplorer, although there may be some issues with it from what I understand. Seems to work fine.
after my swap... TACOMETER doesnt work azn0boi04 Subaru Conversions 5 09-25-2008 11:19 AM
My F$#%ing Accessport Doesnt WORK! ranger5oh AccessPort 35 10-12-2006 08:11 PM
My Cd Player Doesnt Work jchin829 Car Audio, Video & Security 1 07-28-2006 10:13 PM
So why is it that my obdII scanner cannot connect to my ECU (ecutek reflashed)??? jigga Commercial ECU Reflashes 30 07-14-2006 02:34 PM
my trunk release doesnt work ChungerSuby Interior & Exterior Modification 18 05-18-2005 06:25 PM
