Old 03-28-2007, 09:55 AM   #1
cucamelsmd15
Member#: 122980
2010 F150, 2013 CX-5
92 Miata 15 TTF/PTF/E3
Default Oil pressure install on '06
I tried searching, and got no results. Has anyone put the Prosport oil pressure sending unit on an '06 WRX? The reason I ask is because the DBW module, BPV hose and another hose look to sit directly above it, and Im not sure it will fit...
Also, in this case, Im considering a relocation unit for the sender from www.wrxtra.com Has anyone had luck with relocating the unit and still getting accurate readings?
cucamelsmd15 is offline   Reply With Quote
Old 03-28-2007, 02:51 PM   #2
OKR S06
Member#: 116105
2001 Civic/2006 WRX
Blue/Steel Grey Metallic
Are you talking about in the rear galley plug area? I put my defi oil press under my alternator because of all the clutter under my intercooler. I just removed my low pressure swith and put my sending unit there. You will not have a working oil idiot light but, big deal when you have a oil press gauge.
OKR S06 is offline   Reply With Quote
Old 03-28-2007, 02:52 PM   #3
cucamelsmd15
Member#: 122980
Yeah, but the Defi is ALOT smaller than the Prosport sender.
Old 03-28-2007, 06:08 PM   #4
veightkiller
Member#: 78967
2011 335i
i put mine underneath the alternator.
veightkiller is offline   Reply With Quote
Old 03-28-2007, 08:27 PM   #5
sjl1614
Member#: 56791
06 OBS
I used a oil sandwhich adaptor for oil psi and temp with my prosport gauges, works great
sjl1614 is offline   Reply With Quote
oil pressure install on o6 sti nation1979 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 9 02-23-2009 10:46 AM
Oil Pressure Install SOOBY Alaskan Impreza Club Forum -- AKIC 7 04-09-2004 02:53 AM
Oil Pressure Install Sideshowbob Electrical & Lighting 6 02-28-2004 12:37 PM
Oil Pressure Gauge on GC8 install willguidry Normally Aspirated Powertrain 3 01-08-2003 04:02 PM
Mechanical Oil Pressure Instalation Mugamby Newbies & FAQs 2 05-28-2002 02:10 AM
