Welcome to the North American Subaru Impreza Owners Club Tuesday August 4, 2015
Old 03-10-2007, 01:22 PM   #1
markeddy
Member#: 129605
2007 Limited STi
Urban Gray
Default Which o2 sensor to tap?
I am going to buy the Apexi Auto Timer (pen sized). Anyway, I had one on my 2005 Evo and loved it for the battery voltage, o2 and a/f. I realize it's not the most accurate...but actually on the Evo it seemed to be fairly accurate. I also realize that I don't need one because the Turbo is liquid cooled and not oil cooled.
If anything for ME it's more of an eye candy thing, I think they are cool.
So, my question is...what o2 sensor do I tap (FRONT or REAR)?
The reason I ask is I read a couple threads that specifically say NOT to tap the Front because it can cause ECU problems. I am not sure how that conclusion was drawn because I tapped the Front o2 on my Evo and it worked fine. All it's doing is just reading off that wire if you tap it with a vampire tap.
Any help would be appreciated. Thank you.
markeddy is offline   Reply With Quote
Old 03-10-2007, 03:21 PM   #2
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
I don't know what kind of sensor the Evo uses, but the Subaru turbo engines use a semi-wideband sensor that cannot be tapped. Your TT will not get a useable signal from it and it will load down the circuit causing A/F problems. Therefore you do have to use the rear 02, which will not be as accurate but is your only option.
Old 03-10-2007, 04:24 PM   #3
WRXSIG
Member#: 83660
2013 WRX
Ice Silver
sounds like your just fulfilling your inner ricer.... weak
WRXSIG is offline   Reply With Quote
Old 03-10-2007, 10:55 PM   #4
markeddy
Member#: 129605
2007 Limited STi
Urban Gray
Yes, I am fulfilling my inner ricer, so who really cares. Why would vampire tapping the wire going into the ECU harness load the circuit and cause issues, that would be my only question left.
Also, I have a 2007 STi Limited, not sure if this makes any difference.
Old 03-11-2007, 11:31 AM   #5
rkramer
Member#: 118209
2015 WRX Limitec
o2 sensors work by changing the resistance of the circuit. if you add another device, you change the resistance externally.
rkramer is offline   Reply With Quote
Old 03-11-2007, 11:41 AM   #6
dibblejr
Member#: 94070
05 LGT
Sell your TT to someone in your area that can benefit from it. You have nothing to gain from one and it can cause a lot of issues with your car.
Water/ oil cooled turbos do not need one.
I suppose if you dont want to listen to those of who know, one of your future threads will be titled, "Electrical problem(s) with my dash lights...."
Everyone above is correct, not like they needed validation or anything.
Jay-R
dibblejr is offline   Reply With Quote
Old 03-11-2007, 03:03 PM   #7
The Cheat
Member#: 66044
2004 WRX/1994 Miata
alot of people here have tt's, including myself. Theyre not needed on our cars because of the prevoiusly posted reasons. I like the convienance of letting my car warm up without the key in it, or running into wawa. I wouldnt bother with one with an afr gauge, if you want it, go get a real wideband sensor and gauge. And i would also recommend against using vampire taps, they generally suck. Strip the insulation back, poke a hole through the wire, slip your new wire in the hole and wrap it around, then solder it and tape/shrink tube. Thats the way i do it. Anyway, i say go for the tt if you really want, just dont bother with the afr.
The Cheat is offline   Reply With Quote
Old 03-28-2007, 04:46 PM   #8
markeddy
Member#: 129605
2007 Limited STi
Urban Gray
I am going to revive this thread because I think I didn't state my ? properly.
Again, if I tap off the ECU harness wire and NOT the o2 sensor which would I do the Front o2 or the Rear o2 sensor wire?
I tapped the Front o2 sensor signal wire on my Lancer Evolution and never had any issues with voltage drops, etc..
Thanks everyone!
Which o2 sensor is the front, and which is the rear? jamesfacts Normally Aspirated Powertrain 4 07-06-2005 11:09 AM
Which O2 sensor is best for A/f gauge I love my wrx Engine Management & Tuning 7 06-28-2004 03:22 AM
A/F Gauge in a N/A, Which O2 sensor? Shakuwa Electrical & Lighting 0 04-05-2003 06:32 AM
which o2 sensor to use with upipe and autometer a/f guage WRxednEffect Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 01-16-2002 05:45 PM
a/f ratio o2 sensor meter tap apex tt wagonbeast Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 11-05-2001 09:14 AM
