Old 03-28-2007, 04:00 PM   #1
skiblur
Member#: 48291
02 EJ207RA/JDM6
Still truckin'
Default I'm going to puch my car in the face...JDM AVCS gurus help.
If my car had a nose it would be broken into many little pieces. I am throwing the p1306 code as others have. I had a couple other codes then went through and did some extra grounding on the shielded wire shield and the #1 pin on the ecu connector. for about 10 miles it appeared I had everything taken care of. The intermittent CEL returned. I believe it is based in the grounding. If you had this CEL and problem, how EXACTLY did you track it down and take car of it? I've had the swap for a year with NO AVCS. blows donkeys it does. Anyway, any help is appreciated.
Secondly, I need the downshift1 instructions for AVCS. Dylan no longer has them up, and I need to be able to retrace exactly what I did the first time. I know he's super busy, so if anyone else has them, I will love you forever, and that is a long time.
thanks!
Hunter
skiblur is offline   Reply With Quote
Old 03-28-2007, 07:53 PM   #2
Freon
Member#: 88322
2009 BMW 135i
I got a P2093 once because the ground from the battery to the intake manifold (near the fuel line hookups) was a tad loose. I'd retighten both the grounds that sit on top of your intake manifold and maybe also make sure the battery terminal is clean.
You can log the OCV current. It should be <309mA when AVCS target is zero or something like that, but realistically should be zero. You might try finding the manuals for that exact car to see exactly what the determination is for your model.
Freon is offline   Reply With Quote
Old 06-26-2007, 10:55 PM   #3
Javier
Member#: 19346
2003 MBP WRX
Wiseco / Oliver EJ257
Bump... I too have the p1036 and p1038 cel codes popping up. Does anyone have a copy of the downshift1 instructions they can send me also?
Javier is offline   Reply With Quote
Old 06-26-2007, 11:02 PM   #4
99subi
Member#: 78118
2002 Corvette coupe
05 Legacy
at title
99subi is offline   Reply With Quote
Old 10-17-2009, 06:25 PM   #5
gingertooth
Member#: 82242
2005 wrx wagon
wooh wooh!!!!!
i know this is old but anybody have any answers? i did a jdm V7 swap in my 05 wrx wagon and the avcs is not working and i get a p1036/p1086
gingertooth is offline   Reply With Quote
Old 10-17-2009, 09:56 PM   #6
69subaru360
Member#: 159682
1995 WRX
2015 F150
I have the pdf with install instructions and pinouts if that helps anyone.
Old 10-17-2009, 10:14 PM   #7
gto7419
Member#: 44256
05 outback xt
02 wrx wagon - crushed :(
i have the pdf saved as well - pm me an email address and its yours...
gto7419 is offline   Reply With Quote
Old 10-17-2009, 10:25 PM   #8
fastnoypi
Member#: 6886
MY01 EJ207 HTA35r
AVCS ON!
fastnoypi is offline   Reply With Quote
Old 10-17-2009, 10:26 PM   #9
OppositeLock
Member#: 54060
Now: 16 FXT/04v8 207
Then:JRTuned fastest td04
PDF is here: http://www.ds1motorsports.com/faqs/f...aq-item-2.html
EDIT: 1 minute too slow!
OppositeLock is offline   Reply With Quote
Old 10-17-2009, 10:39 PM   #10
69subaru360
Member#: 159682
1995 WRX
2015 F150
^ Dave sent it to me
Old 10-20-2009, 06:48 AM   #11
gingertooth
Member#: 82242
2005 wrx wagon
wooh wooh!!!!!
did anybody here have grounding issues at all?? MY dash and stereo are not as powerful as they were before the V7 swap.....
Old 10-20-2009, 04:39 PM   #12
T_Racer69
Member#: 188079
2003 Stg 2 Bug Wagon
Sonic Yellow
How powerful was your dash before? Like, BLAM, 5K RPMS!!!
Travis
T_Racer69 is offline   Reply With Quote
Old 10-20-2009, 06:08 PM   #13
gingertooth
Member#: 82242
2005 wrx wagon
wooh wooh!!!!!
i can definately notice a difference. it's not as bright...
Old 10-20-2009, 06:39 PM   #14
69subaru360
Member#: 159682
1995 WRX
2015 F150
Measure the voltage at the battery with it running. Could be more of an alternator issue.
I want to punch my boss in the face. Am i being dumb? kbcr3 Off-Topic 73 01-12-2009 07:11 PM
I think I'm going to waste my money on the dumbest shoes ever scaryfastskier Off-Topic 28 10-13-2007 12:30 PM
idle problem. Im about to punch my car in the face. BlackoutWRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 28 03-08-2006 06:24 PM
I want to punch my car in the face Dolphin Overton Off-Topic 2 07-19-2005 08:43 PM
I've decided that I'm going to sell my car... skeletor25rs Texas Impreza Club Forum -- TXIC 15 04-01-2002 02:49 AM
