Welcome to the North American Subaru Impreza Owners Club Monday August 29, 2016
Mid Atlantic Impreza Club
View Poll Results: 17" Rota Torques vs. 18" Rota Torques
17" 21 84.00%
18" 4 16.00%
Voters: 25. You may not vote on this poll
Old 03-28-2007, 10:30 PM   #1
jamapor
Member#: 111694
2002 Bugeye clan
Suspension is next...
Default 17" vs. 18" Rota Torques
What do you guys personally think looks better? (I drive an 02 WRB WRX).
I personally think I like 17"'s and found a good set I'll most likely be buying, but I wanted to get some quick feedback.
jamapor is offline   Reply With Quote
Old 03-28-2007, 11:12 PM   #2
MidnightSti05
Member#: 74064
Ok before you buy...
1. What is your budget?
2. What tires would you like to run?
3. What is the purpose of the wheels?
I find many people buy Rota's because they are "cheap" well there are many options of wheels out there that you can get - if you want there are some good deals on Work Emotions or even cheaper great wheel are the RPF1s - plenty of affordable non Rota wheels...incase budget is what directed you to Rota
If you get 17s it will be easier to pick up a set of re070s then a size of tires in 18s - everything gets more expensive with 18s even mounting. Sometimes people say you can run wider wheels with 18s well people are rocking 255s on 17x8s no problem so I'm not sure the width is that much of a big deal.
But 18s fill the nasty wheel gap pretty nicely and look much better Personally I'm all about picking the wheels that look the best - if you lower the car 17s are going to look good anyway. Weight of 18inch Rota's is also a bummer...
The main plus side of 18s I think is really looks, space for a big brake kit but that is rarely the deciding factor so yeah...
I'm sorta in the same boat not sure if I should mount some summers on my stock 17s or buy a set of new 18s
MidnightSti05 is offline   Reply With Quote
Old 03-29-2007, 12:03 AM   #3
jamapor
Member#: 111694
2002 Bugeye clan
I'm looking used for < $850
The wheel/tire set I'm looking at buying is running Pirelli 45-17 PZero nero's
I want to use them for my spring/fall/summer tires. I have stock painted rims with Michelin Alpin winter's on now that I want to use as my winter setup.
Do you have any pics by any chance?
Old 03-29-2007, 12:14 AM   #4
ALaDDiN
Member#: 98294
2004 Honda Civic
2006 Acura TL
I'd go with the Used 17x8 Rota Torques w/ 225-45-17 PZero Nero tires in the classifieds. They are going for a pretty good price too!
ALaDDiN is offline   Reply With Quote
Old 03-29-2007, 12:39 AM   #5
Ricky87
Member#: 128549
2006 Benz
I am picking up some rotas this weekend. finally i get some wheels. BTW they are 17's.
Ricky87 is offline   Reply With Quote
Old 03-29-2007, 01:45 AM   #6
Dave6265
Member#: 51583
2014 JGC Overland
aka-Th3BlindMice
you will def feel those wheels I had the 17x8 torques and ditched em cuz it bogged the car down so much...nothing but lightweight stuff for me from now on..
Dave6265 is offline   Reply With Quote
Old 03-29-2007, 01:47 AM   #7
jamapor
Member#: 111694
2002 Bugeye clan
what's the weight of the stock wheels? those are 19.4 lbs....
Old 03-29-2007, 08:34 AM   #8
MidnightSti05
Member#: 74064
go to subydude's website and there is a whole gallery of subarus with wheels on them. You can view by car or by wheel ...here is the link to cars with Torques...
http://www.subydude.com/osc/gallery_...ype=rotatorque
aaah I wouldn't agree so much, I bought a set of Rota Torques from Dan @MachV a long time ago and I was curious about wheel weight and well I compared the stock sti 17x8 wheel and re070 combo (used for 16K) vs Torques and pzero nero M+S (new) in the same tire size and actually the Torques were about a pound or two lighter so I wouldn't call the Torques a heavy wheel. Especially when the stock STi wheel is around 19lbs...
You could get the RPF1 which come in around 15lbs which is a pretty nice jump down...
Old 03-29-2007, 08:36 AM   #9
mav1c
Hoodbridge!
Member#: 560
2006 STi, 16 Outback
Crystal Gray, Silver
I run 18" Torques on the street, and 17" Torques at the track. For looks, go with the 18's. For performance, go for the 17's.
18" Torques, Hyper Black:
17" Torques, Steel Gray:
Old 03-29-2007, 08:40 AM   #10
Jard
In the silly seat
Member#: 34935
SPB- 2013 Dadcore
If you are driving in DC, you'll want the 17s so you get that tiny bit of extra protection with a bigger sidewall.
Jard is offline   Reply With Quote
Old 03-29-2007, 08:46 AM   #11
jamapor
Member#: 111694
2002 Bugeye clan
Thanks for the pics man. A HUGE help to see them.
Old 03-29-2007, 09:37 AM   #12
mav1c
Hoodbridge!
Member#: 560
No problem. Unfortunately I don't have many good pics of the 17's.
Old 03-29-2007, 09:49 AM   #13
Zoinks
Member#: 35924
I don't think the Torques are especially heavy, but for me there's a very noticeable* difference with my 17x7.5s compared to the stock 16" wheels. Part of it may be the heavy tires I run (RT215s), or the weight being further out on the larger diameter wheel. On the other hand, I think you'd have to go significantly up in price to get a much lighter wheel.
OP - Get the 17's. 18's look ghetto and/or goofy on Subarus.
*Edit - I should amend that to say that by "very noticeable", I mean it's apparent for the first 30 minutes after I switch tires, and then I pretty much get used to it. I wouldn't worry about it. The car just seems slightly less light on its feet when pulling away from a stop, etc.
Zoinks is offline   Reply With Quote
Old 03-29-2007, 09:54 AM   #14
MidnightSti05
Member#: 74064
not *always* true, you can get a set RPF1's which are probably the lightest 17inch wheel available (15lbs) for subies with tires for about the same as you can get Rotas with tires.
http://forums.nasioc.com/forums/show....php?t=1186969
just the wheels shipped for $999
http://forums.nasioc.com/forums/show....php?t=1228182
I'm just saying there are option, lightweight and good options within Rota Range - Had the RPF1's been available for my car a few months back then I would have bought them
Old 03-29-2007, 10:04 AM   #15
Zoinks
Member#: 35924
I'd definitely go with the RPF1s if the price is close. What's the going rate on a Rota bundle these days?
Old 03-29-2007, 10:08 AM   #16
Matt_H
Member#: 107000
2015 BMW X1
http://forums.nasioc.com/forums/show....php?t=1181617
17 x 7.5 ROTA Wheel - $650 w/ FREE lugs/shirts/Shipping
17 x 8 ROTA Wheel - $700 w/ FREE Lugs/shirt/Shipping
18 x 7.5 ROTA Wheel - 699 w/ FREE Lugs/Shirt/Shipping
18 x 8 ROTA Wheel - $750 w/ FREE Lugs/Shirt/Shipping
18 x 8.5 ROTA Wheel - $800 w/ FREE Lugs/Shirt/Shipping
Matt_H is offline   Reply With Quote
Old 03-29-2007, 10:15 AM   #17
MidnightSti05
Member#: 74064
Didn't see prices for 17s but here are 18s...
Originally Posted by suby_dude View Post
Tire: you want to go w/ 235/40/18.. so pick any of the following packages:
# 235/40ZR18 95Y RF BW FK-452 FALKEN $1,385.35
# 235/40ZR18 95W ZIEX ZE-512 FALKEN $1,261.75
# 235/40R18 95W AZENIS RT-615 PURE SPORTS FALKEN $1,416.25
# 235/40R18 95W PROXES 4 TOYO $1,375.05
# 235/40R18 95Y PROXES T1R TOYO $1,457.45
# 235/40R18 95W AVS ES100 YOKOHAMA $1,416.25
# 235/40R18 95Y XL BSW ECSTA SPT KU-31 $1,302.95
# 235/40ZR18 95W BSW Ecsta ASX Kumho $1,272.05
all prices above includes wheel/tires/mounting/balancing/lugs/shirt/shipping/hug?
-sd
So the prices are somewhat close to RPF1 packages, obviously Rota's are the cheapest wheel on the market but a couple hundred more will take you a long way in terms of Rotas ->RPF1s....thats all I'm trying to say.
Old 03-29-2007, 10:28 AM   #18
silverF4turbo
Member#: 20492
4 -valve Derper
Let's JDM styling!
[/thread]
I like 17" for the torque... search for threads started by "GNV Motorsports" in the members car gallery
silverF4turbo is offline   Reply With Quote
Old 03-29-2007, 10:29 AM   #19
silverF4turbo
Member#: 20492
4 -valve Derper
Let's JDM styling!
Wow how'd you get black lettering on your brembos? Custom job?
Old 03-29-2007, 12:07 PM   #20
Dave6265
Member#: 51583
2014 JGC Overland
aka-Th3BlindMice
OP, your stock wheel weight is 16.5. I think OEM wheel and tire net you at like 35-37lbs. Rota torques will be around 19lbs in the 17inch format. I had yoko es's on them and you can really feel the difference in acceleration and coasting. I would tell you to save your money for some nice lightweight stuff, or maybe check out the rota sdr in 17inch, they are still lightweight at 16-17 lbs, I think they look nice, cheap, and they won't break...
Midnight, the reason why you didn't really feel it is you had the 2.5l, and your oem wheel weight was a pound or so less... you can really feel those 3+lbs in centrifical (Sp) mass.
Then again you may not be as anal as I am with wheel weights, but having the torques on made it seem like I was missing some mods when I hit the gas.
Old 03-29-2007, 12:22 PM   #21
teh Phil
Member#: 24888
+1 for this.
On a side note, Tim, how do you like the MXs for the street? I'm trying to decide between those and Azenis.
teh Phil is offline   Reply With Quote
Old 03-29-2007, 01:30 PM   #22
MidnightSti05
Member#: 74064
Oh I agree 100% - wheel weight matters to me that is why i'm looking towards RPF1s or something Forged
Old 03-31-2007, 09:07 AM   #23
Butt Dyno
Street's closed, pizza boy
Member#: 17301
is the "dark side"
06 Evo #7 STU, 03 IS300
I forget how I found this thread.
A lot of that, maybe all of it is in the tire. A typical stiff-sidewall tire (S03, Azenis, 070) is something like 24-25 lbs in the 225-45-17 size. The Toyo T1-S, a commonly referenced "light" tire is more like 20-21 lbs in that size so an all season like the Pirelli is probably in the same league. For hard driving though the tradeoff of the heavier/stiffer tire is definitely worth it.
If you're talking about Tim's car... it was a custom job. A hard weekend at Summit Point / Shenandoah
john
Custom RED Brembo BBK & 18" Rota Torque Insane Combo Deal TheKingofParts Wheels/Tires 1 08-07-2007 05:50 PM
FS/WTT: 18" Rota torques cobbler Wheels/Tires 19 01-02-2007 12:09 PM
opinions needed - 17" 5zigen 5zrs vs. 18" rota subzeros kiwee Tire & Wheel 2 10-30-2006 12:34 PM
New wheels! 18" Rota Torque Mach V Dan MAIC Vendor Classifieds 15 03-09-2006 05:38 PM
16" vs 17" vs 18" wheels with the same Max Performance tires comparisons? Heather Tire & Wheel 67 07-03-2003 04:33 PM
