Old 03-29-2007, 03:30 AM   #1
koeix2
Member#: 123184
93 Impreza L fwd
baby blue
Default headlight problem
the driver side headlight will sometimes not light up when i turn my headlights on. It isnt a common problem, it just happens for reasons i cant figure out yet.
Then later, It will light up again without any problems, and this isnt in the middle of driving. it works fine some other time i start up the car, and turn the headlights on.
The only other known electrical problem, though i am not sure of this is the climate control lights. Im not sure if 93L's have climate control lights, but if they do mine do not work. Maybe a hint/clue that could help toward the main prob?
So far im thinking its a loose connection maybe, or a bad bulb, im not sure exactly, but if someone has had this problem before, or if its an electrical problem, i wanna know whats wrong exactly so i dont blow a bunch of money when the solution is just a few bucks.
koeix2 is offline   Reply With Quote
Old 03-30-2007, 03:21 PM   #2
mossie4
Member#: 83997
2008 STI
Smile
Have you installed high intensity bulbs? My impreza had similar problems and when I checked the connection at the headlight, it had gotten so hot that the plastic connector had melted and was only occasionally maintaining contact.
Just a thought
mossie4 is offline   Reply With Quote
Old 03-30-2007, 04:13 PM   #3
ATX25RS
Member#: 4597
2011 Mitsu Outlander
Sport (Ex-Suby owner X3)
yeah, sounds like a melted connector? any high watage lamps (over 65W) will do his over time.
ATX25RS is offline   Reply With Quote
Old 03-30-2007, 06:14 PM   #4
koeix2
Member#: 123184
93 Impreza L fwd
baby blue
its completely stock. i just came back from an auto shop who diagnosed it, it was quick so i dunno, but they're saying its the headlight switch.
would make a hell of alot of sense since my highbeam does not lock on, and both lights DO work that way.
they checked listings for the switch its friggin $554, plus labor. (I sure as hell do not wanna replace it)
anyway, if i have to....
we're subie owners, im sure someone knows where to get a head light switch for much cheaper? One with a warrantee or SOMETHING.
Old 03-31-2007, 05:51 AM   #5
koeix2
Member#: 123184
93 Impreza L fwd
baby blue
anyone else think its the switch?
Old 03-31-2007, 11:57 PM   #6
koeix2
Member#: 123184
93 Impreza L fwd
baby blue
ive checked the wiring, its ok, the bulb is ok,
but when i checked the fuse box, i found (i didnt do anything with it until now)
a 15A fuse in the light switch socket. its supposed to be a 20A fuse.
After replacing the fuses...nothing.
Could this affect the switch itself then?
Headlight problem! ButTMaN! Interior & Exterior Modification 8 12-07-2002 04:55 AM
WRX Headlight problem ybnormal70 Newbies & FAQs 2 11-02-2001 05:14 PM
Headlight problem Silky Interior & Exterior Modification 5 10-28-2001 12:59 PM
('93-'01) Headlight Problem... MP2.5RS Impreza Forum 2 08-17-2001 02:55 AM
01 Headlight Problem Mr Cheese Forester Forum 4 03-29-2001 02:45 PM
