Old 12-10-2001, 09:56 AM   #1
ImpreziveRS
Member#: 6312
2001 Impreza 2.5 RS
Blue Ridge Pearl
Default Those with header...any troubles with warranty?
Just wanted to know about this. I read somewhere that a guy's Borla header burnt his steering boot (I believe) and he had to pay to fix it, which is understandable. My question is, has anyone had a problem with the engine which wasn't related to the header and had Subaru blame the problem on the header. I want to get one but don't want the trouble with warranty crap.
~Kyle
ImpreziveRS is offline   Reply With Quote
Old 12-10-2001, 12:33 PM   #2
Julian
Member#: 1182
MY00 RS
BRP
Just keep your stock system around. I have mine hanging in the garage. Should anything ever happen that I feel they might give me a hassle about, I'll just change it over (takes about an hour to swap the whole system). I also may be doing this for emissions testing (here in Cali, they can fail you just on a visual).
But, the dealer has seen my system and only asked if it improved power. They even diagnosed my CE light after it first sent off (caused by the header). No problems so far, and the other dealer (two in my area) sells stuff like intakes, so...
Julian is offline   Reply With Quote
Old 12-11-2001, 09:21 AM   #3
ImpreziveRS
Member#: 6312
2001 Impreza 2.5 RS
Blue Ridge Pearl
So that header is pretty easy to install? What about that CEL? Does it stay on constantly now or what?
~Kyle
Old 12-11-2001, 10:19 AM   #4
Julian
Member#: 1182
MY00 RS
BRP
I have the MRT system, but yeah, the CE light dash bulb is in danger of burning out. If you just get a header, you might not get the code, but if you replace the system with a higher-flow unit, you're bound to get it on MY00 and MY01.
Any trouble with the Po-Po..... Black-Falcon South West Impreza Club Forum -- SWIC 41 06-19-2006 12:23 AM
Any trouble with corner splitters in snow? subie4life Interior & Exterior Modification 2 11-13-2005 04:35 PM
Would the stock trans have any trouble with TXS stg 2 and 15lb psi? waitandbleed92 Transmission (AT/MT) & Driveline 7 03-21-2003 04:51 PM
Anyone have any trouble with Cruise Control? Robmat Service & Maintenance 10 09-20-2002 03:59 PM
Any trouble with WRX? FM2 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 17 08-06-2001 01:15 AM
