Old 03-29-2007, 03:25 PM   #1
turbo_h4
Member#: 112433
06 WRX.stage2
Default Wiring through firewall
What is the ideal place to run wires through the firewall o 06 imprezas? If possible, i don't want to make any new holes. I want to run 2x 12AWG wires through it.
turbo_h4 is offline   Reply With Quote
Old 03-29-2007, 05:50 PM   #2
02redwagone
Member#: 87067
02 Old but tasty
SRP
Look for the rubber gromets. They pop out fairly easily and there is one that isnt even used behind the intercooler. (above the gas pedal) Pop it out, fold it over, use a sharp knife or skissors to cut an X in the center and then slip it over the wires or loom you want to send through. Then simply pop it back into the bulkhead.
02redwagone is offline   Reply With Quote
Old 03-29-2007, 08:20 PM   #3
sxotty
Member#: 95600
2003 WRX wagon
I disagree strongly with the above suggestion.
There are many different spots, but along the cable for the hood is my favorite b/c it will keep a seal and keep the engine noise out of the interior.
Here look at these.
There is a spot under the clutch and two on the far left of the drivers foot well.
Clutch
Lower left
I decided to use the ones on the far left b/c I didn't want to try and seal that gaping hole or cut a hole in the seal as I thought it might pop out.
I ran 10guage wire for a carputer thru it. Just look here if you want more pictures of how you get the wiring there. I don't want to copy and paste it all.
sxotty is offline   Reply With Quote
Old 03-30-2007, 05:38 PM   #4
jblaze5579
Member#: 83473
#3, I think you and #2 are talking about the same thing
jblaze5579 is offline   Reply With Quote
Old 03-30-2007, 06:16 PM   #5
02redwagone
Member#: 87067
02 Old but tasty
SRP
Engine noise in the cabin indeed. WOW
Old 03-30-2007, 07:40 PM   #6
turbo_h4
Member#: 112433
06 WRX.stage2
One more thing, how to run a wire to the trunk through the inside of the car?
Old 03-30-2007, 07:46 PM   #7
geoffj
Member#: 9
Under the carpet and under the rear seat.
geoffj is offline   Reply With Quote
Old 03-31-2007, 10:56 PM   #8
Meat Supply
Member#: 137902
---- so good
it sucks....
either under the carpet or string it along under your door sill pieces. a little easier than lifting up carpet and stuff
Meat Supply is online now   Reply With Quote
Old 04-01-2007, 12:02 PM   #9
sxotty
Member#: 95600
2003 WRX wagon
Yes I showed a picture of where I would not run it and where I would
Not everyone likes to make their car incredibly loud.
how to get wire through firewall ? Jonnathan Electrical & Lighting 2 05-04-2003 08:18 PM
Running wire through firewall Dakken Car Audio, Video & Security 7 12-04-2002 07:22 AM
wiring through firewall? notarex Interior & Exterior Modification 3 09-04-2002 12:41 PM
where do i route wires through firewall? WRxednEffect Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 15 01-11-2002 12:03 AM
Running power wire through firewall Snowphun Car Audio, Video & Security 4 07-06-2000 10:31 PM
