Welcome to the North American Subaru Impreza Owners Club Friday December 2, 2016
Old 03-31-2007, 03:21 AM   #1
impreza97t
Member#: 144922
Default EJ22T into 97 Impreza
I have swapped a ej22t into my 97 impreza. the whole swwap is done, i am using a STI turbo and a WRX intercooler. everything else on the motor is completly stock. i am using stock computer and stock wiring harness that was on my original motor. i have no check engine lights. at idle or when i hold the throttle steady the RPMs will jump about 1000 RPM. so if i take it to 3000 the rpms will jump from 3000 to about 4000 and then when i let the throttle go it will stall. and when i take it for a ride and push in the clutch to stop the car will stall, everything else seems to be ok. ANY HELP???????????
impreza97t is offline   Reply With Quote
Old 03-31-2007, 10:54 PM   #2
Meat Supply
Member#: 137902
---- among the
lost we all shall survive
seems like i read turbo l's thred or someones about an after market management system (like greddy emanage) that has some sort of anti-stall feauture. i read about this stalling thing somewhere else too.
Meat Supply is offline   Reply With Quote
Old 04-01-2007, 09:43 AM   #3
cowapult
Member#: 25324
2016 WRX
Dark Gray Metallic
Does "original" mean you using the computer and harness from the 97 Impreza? Because it's ECU wouldn't know what to do about boost, and wouldn't necessarily react properly to sensors on the ej22t.
You should also tell us what sensors are from the Impreza and what from the ej22t. For example, MAP? MAF?
cowapult is offline   Reply With Quote
Old 04-02-2007, 10:26 AM   #4
impreza97t
Member#: 144922
I am using all the sensors and the wiring harness off the 97 impreza. i was told that OBDII on the 97 impreza would be able to compensate for the boost as long as i wasnt boosting any crazy numbers.
Old 08-24-2008, 02:47 PM   #5
strikers
Member#: 137263
2006 Forester xT
RBP
so did you ever find the answer to your question 97t?
strikers is offline   Reply With Quote
94 legacy ej22t into 97 impreza l coupe epil0g Newbies & FAQs 18 04-26-2010 08:56 AM
Legacy SS ej22t into 97 L all OEM - Question? urabus555 Subaru Conversions 11 02-29-2008 08:29 PM
98 or 99 impreza rs 2.5 into 97 impreza L questions 97 Pimpreza Subaru Conversions 5 10-23-2006 09:40 PM
sti swap into 97 impreza outback kaneda3 Subaru Conversions 6 02-06-2005 02:45 PM
Jspec EJ20T swap into 97 Impreza L Murray Engine Management & Tuning 24 11-02-2002 04:20 AM
