Texas Impreza Club
Go Back   NASIOC > NASIOC Chapters > Texas Impreza Club Forum -- TXIC
Old 03-31-2007, 12:29 PM   #1
stuttgart
Member#: 13920
2006 WRX
CGM
Default Just pulled my headlights to bake and paint
any tips on painting my 06 headlights?
stuttgart is offline   Reply With Quote
Old 03-31-2007, 12:46 PM   #2
APSWRX1
Member#: 63630
2009 CWP Mazdaspeed3
TXIC Groupie Member #1
TAKE YOUR TIME!!! Condensation FTL!!!
Invest in some silicone to re-seal and try not to break tabs. Give yourself time in between coats and spray evenly.
Good Luck!
APSWRX1 is offline   Reply With Quote
Old 03-31-2007, 01:10 PM   #3
stuttgart
Member#: 13920
2006 WRX
CGM
do i need to sand or use primer?
Old 03-31-2007, 02:57 PM   #4
uathatis
Member#: 117300
use sand paper. and make sure to tape off that ring very well.. um here..
hope you haven't finished yet but it should look something near this
Make sure you follow the nasioc directions carefully, it takes a while
uathatis is offline   Reply With Quote
Old 03-31-2007, 03:01 PM   #5
iri_tuan
Member#: 80572
06 STi
waiting for something new
remember to paint about 6-9 inches away from the item, and even if you dont cover everything the 1st time, you can always come back later on and get it. Take your time, and do a layer about every 15-20 mins. I learned these steps after I finished mine heaedlights, so they are gona be coming back off and getting repainted when I do my s2000 retrofit.
iri_tuan is offline   Reply With Quote
Old 03-31-2007, 03:41 PM   #6
ohxietviet
Member#: 143164
06 AW WRX
u dont really need to sand it if u use krylon fusion
ohxietviet is offline   Reply With Quote
Old 03-31-2007, 09:40 PM   #7
Subyslacker
Member#: 105096
2007 WRX/STI
What do you have to bake?
Subyslacker is offline   Reply With Quote
Old 04-01-2007, 03:20 AM   #8
wrxpunk53
Member#: 48001
the whole assembly
wrxpunk53 is offline   Reply With Quote
Old 04-01-2007, 03:30 AM   #9
uathatis
Member#: 117300
after you take out the screws... and wires...bulbs... and etc etc
Old 04-01-2007, 08:35 AM   #10
Subyslacker
Member#: 105096
2007 WRX/STI
Why do you have to bake it?
How long?
What Temp ?
Is it to get it apart?
If so how do you put it back together?
How long will it take?
What are the dangers involved?
Is there a MSDS?
Old 04-01-2007, 11:28 AM   #11
KrazyKarl
Member#: 94706
2007 STI
1995 Miata
you dont have to take anything out but the screws. atleast I didn't and mine turned out perfectly fine.
How long?
What Temp ?
Is there a MSDS?
you bake it to get the sealant to melt a bit (its kinda like hot glue, but its not as runny when its hot) I did mine for 20 minutes at 220 F. to put it back together, you push everything together as best you can, bake it again for about 10 minutes and then push it back together the rest of the way.
Took me about 4 hours, including about a half hour of wrestling with getting them off when I hadn't gotten all the bolts out.
there's only really 2 dangers (mind you, i take no responsibility if you get hurt somehow....) dropping and breaking whats probably the single most expensive part on the car (or very close) and getting a little burned when your seperating it. I just wore dishwashing gloves and i was fine though.
KrazyKarl is offline   Reply With Quote
Old 04-01-2007, 11:36 AM   #12
stuttgart
Member#: 13920
2006 WRX
CGM
before
after
here is a link to the thread on how to do it.http://forums.nasioc.com/forums/showthread.php?t=957478
It went pretty good. took me about 4 hours with getting all the parts off the car, baking, painting, drying and reinstalling.
Old 04-01-2007, 01:48 PM   #13
wcbjr
Member#: 4001
2006 Legacy GT
Obsidian black
Oh damn, I am bored today. I need to do the LGT. Thanks to the poster for the idea.
wcbjr is offline   Reply With Quote
Old 04-01-2007, 01:54 PM   #14
Javwrx
Member#: 38875
you can also use a heatgun to heat up the glue, instead of baking them.
Javwrx is offline   Reply With Quote
How To Bake & Paint Your Headlights (diy Video!) GreenTeaCRV Off-Topic 8 06-02-2009 03:01 PM
Just pulled my codes from my swap..what to do? parkes Subaru Conversions 4 10-04-2008 12:19 AM
Just pulled my JDM WRX 2.0 apart AllAspects1 Built Motor Discussion 2 03-21-2007 04:33 PM
I just added my wife to my car insurance and my premium plummeted! perret318 Off-Topic 9 02-09-2006 12:29 PM
just pulled my plugs, is this normal? blackie Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 29 01-29-2004 06:41 PM
