Old 03-31-2007, 12:30 PM   #1
Bottom Feeder
Member#: 2808
Unhappy Help! Radio and wipers don't work randomly at startup
As the title says- Once in a while when I start my car, both the radio and windshield wipers have no power to them. The only way to get it back is to turn off the car and restart. Does anyone know if they use the same circuit and/or ground? It obviously can't be a fuse problem or they would never work. If it's something loose, I would assume they would stop working once the car is already moving and getting jostled around, but the opposite is true.
None of the wiring in my car has even been touched. No aftermarket stereo or lights or anything.
Any ideas? Thanks.
Bottom Feeder is online now   Reply With Quote
Old 03-31-2007, 03:24 PM   #2
sxotty
Member#: 95600
2003 WRX wagon
I just want to say good luck that sounds like a very tricky iffy problem. Sounds like a switch kind of problem more than anything else if they work once they start and jostling doesn't change em.
Maybe something on accessory circuit? Does the cigarette lighter work when this happens? If not it is probably the ignition circuit. I checked for you and the Wiper does get power through ACC circuit.
sxotty is offline   Reply With Quote
Old 03-31-2007, 05:21 PM   #3
Bottom Feeder
Member#: 2808
Thanks. I'll have to do a quick check to see what is not working (besides these two) the next time it happens. I know the blower motor isn't affected, but that's all I've tried.
I just remembered that the CD player has power, but not the stereo. WTF?
Old 04-02-2007, 06:40 AM   #4
Bottom Feeder
Member#: 2808
Bump for the day crew.
Old 04-05-2007, 10:37 AM   #5
Bottom Feeder
Member#: 2808
Anyone...?
Old 04-14-2007, 08:57 PM   #6
Bottom Feeder
Member#: 2808
Crap.
Old 04-16-2007, 09:07 PM   #7
Meat Supply
Member#: 137902
---- washed away
a dream of you
kinda sounds like maybe your ignition switch inernals could be going.not making that accssory conatct sometimes
does jiggling your ignition switch help any?
Meat Supply is offline   Reply With Quote
Old 05-05-2007, 06:57 AM   #8
Bottom Feeder
Member#: 2808
Bingo. It happened again last night, so I moved the key around in the switch and the radio and wipers came on and off a few times. Great.
So... how the hell do I fix that?
Old 05-07-2007, 02:51 PM   #9
Bottom Feeder
Member#: 2808
It's been getting bad very quickly. Yesterday I could barely make my wipers and radio come on.
Old 05-07-2007, 03:12 PM   #10
SoobATV
Member#: 6883
MY04 Foz XS
MY02 Imp TS
I'd urge someone to correct me if I'm wrong, but I'd think the only fix would be replacement of the electrical internals of the ignition switch. Should be an easy job, I'd expect.
SoobATV is offline   Reply With Quote
Old 05-07-2007, 04:03 PM   #11
Bottom Feeder
Member#: 2808
Yeah, I'm thinking replacing the whole switch will be easy, just not that cheap. Oh, well.
Old 05-07-2007, 09:54 PM   #12
s-t-izzle
Member#: 145230
05 STi
Stage 2 -- Aspen White
it is definitely the ignition switch, jic that hadn't been established already. i've seen this many times in the past, not necessarily with subies tho.
changing out the ignition switch may turn out to be quite the task. i've never performed this on a suby before, but have on other vehicles. it may require you to disassemble most of the steering wheel column and possibly drop the column from the dash. consult some "mechanically inclined" friends if you're having doubt in your ability or resolve
s-t-izzle is offline   Reply With Quote
Speedometer and tack don't work. Help!!! bryantkalagian Electrical & Lighting 7 04-13-2010 03:34 PM
Brake Help? Anti-Rattle Clips Don't Work With New Pads. MkIII Legacy Forum 6 12-08-2006 08:49 PM
Radio and clock stopped working. Help!!! 02turbosuby Electrical & Lighting 3 11-30-2006 01:13 PM
Help! Keyless entry transmitters don't work! mikeybikey Electrical & Lighting 1 01-31-2005 12:37 PM
Power Windows and Mirrors Don't Work ND4SPD2000 Service & Maintenance 7 05-01-2002 02:55 PM
Message Board Statistics All times are GMT -4. The time now is 11:33 AM.
