Old 04-02-2007, 07:50 PM   #1
WRX.357
Member#: 145167
Default I smell coolant...head gasket or something minor?
I have a 2004 WRX with 76,000 miles and no mechanical modifications. Lately, I notice the smell of antifreeze after driving the car. I can't smell it from inside the car; it's definately coming from under the hood. It don't see any puddles of coolant or any obvious leaks. The fluid level in the overflow tank is near the low end of normal and the car has never over heated.
The smell is strongest directly above the driver's side cylinder head, which leads me to suspect a head gasket.
Could it be leaking somewhere else? The only cooling system work I've ever done on it was to change the antifreeze a year ago.
Is this a common problem?
Help!
WRX.357 is offline   Reply With Quote
Old 04-02-2007, 07:58 PM   #2
Cation
Member#: 88779
00 E55 AMG
Sounds like it could be a leaking water pump or lower rad hose at the water pump. Get under the car and look near the water pump to see if there is any wetness. Check all coolant hoses and your radiator for signs of leaks. I doubt that it's a head gasket.
Cation is offline   Reply With Quote
Old 04-02-2007, 08:30 PM   #3
rkramer
Member#: 118209
2015 WRX Limitec
or most likely leaking radiator. you usually don't smell antifreeze under the hood for head gaskets.
Old 04-03-2007, 11:45 AM   #4
abosworth
Member#: 53856
2012 Speed3
Red Mica
Yeah, I bet it's your radiator. Do a cooling system pressure check.
abosworth is offline   Reply With Quote
Old 04-03-2007, 05:05 PM   #5
thewerxracing
Member#: 141498
Hey wow, I just got done spending an arm and a leg having the dealership throw on a new water pump/ thermostat/ and hose.
I had the same problem, to the point where it would steam from the right side of the engine bay, right behind the radiator, after driving it. My water pump was leaking and dripping onto the exhaust manifold. It started small, like just a whiff of the 'freeze, and grew into a nice drip.
Thats my guess...
thewerxracing is offline   Reply With Quote
Old 04-03-2007, 07:32 PM   #6
WRX.357
Member#: 145167
Thats my guess...
So...what's the dealership get for a waterpump job these days?
Old 04-03-2007, 07:49 PM   #7
WRXDriftR
Member#: 65065
04 WRX/ STi Hybrid
6MT, VF43
$6,000,000 + tax
I just had my coolant changed, noticed a small amount of sweet smell in the air a day later and 3 days later but nothing more since then. Its probably from the excess that spilled out of the radiator during refill though.
Ill look at the water pump to check for leaks when I do the next oil change.
WRXDriftR is offline   Reply With Quote
Old 04-03-2007, 10:17 PM   #8
drewwrxrogers
Member#: 132574
04 Aspen White Sti
GT35r, axis motor,280cams
I had been smelling coolant also. The other day I did a few pulls. I then turned the key off and popped the hood. There was a coolant/water mix pouring out of the bottom of the car. I took it home and my gauge was past the H!!! I was out of coolant. I filled it, checked for line leaks, and radiator cracks, nothing. I then did a pressure test and nothing would leak. I even checked the lid. I drove around and everything was fine. It was kinda scary, but everything checks out. I guess I just overheated.
drewwrxrogers is offline   Reply With Quote
Old 04-03-2007, 10:17 PM   #9
r0n
Member#: 91839
Thats my guess...
Had the same problem.
r0n is offline   Reply With Quote
Old 04-04-2007, 09:03 PM   #10
thewerxracing
Member#: 141498
I’m not home right now, and the receipt is sitting on my kitchen table.
Actually, I have a story about it, for those who care to lend an ear.
I first took the car in with the same problem, leaky, smelly, etc. They diagnosed it as a hose that ran into the pump. I waited a week for them to get me a hose.
Next visit, a week later I had the system flushed, tossed the hose on, and a new clamp.. Great. That was around 175$ (approx.).
Well, three days later, it turns out that wasn’t the problem. Now, I go back, they toss it back up on the rack, and diagnose it as a water pump; which, you guessed it, was out of stock.
Well a week later, they throw on a water pump, put in new antifreeze, a thermostat and misc. clamps: All for around 500$. It turns out they wont refund me the money from the first visit for the mis-diagnostics, and, here it comes, they even charged me for new anti-freeze for the second visit even though it was their fault it leaked out. Yay!
Old 04-04-2007, 09:19 PM   #11
WRX.357
Member#: 145167
Iím not home right now, and the receipt is sitting on my kitchen table.
Well, three days later, it turns out that wasnít the problem. Now, I go back, they toss it back up on the rack, and diagnose it as a water pump; which, you guessed it, was out of stock.
Two more questions:
How many miles on your car?
Did you change the timing belt at the same time?
Old 04-04-2007, 09:24 PM   #12
thewerxracing
Member#: 141498
I just Turned 70k on a 2002 Sedan. I didnt have the belt changed, it's in great shape because I think it was changed before I bought it, by the 1st owner, or perhaps the dealership I bought it from. I got it around 50k.
Also: Everyone I've talked to said to check the oil. If it looks like theres something in there, like coolant, then its the head gasket. The coolant falls into the cylinder, That's how it was on my fathers Pathfinder. The oil looked a little messy, and it was the head gasket that went.
blown turbo, head gasket, or something else? wrx tekker Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 09-17-2009 06:40 PM
leaky head gasket, or something else? Meat Supply Off-Topic 10 02-03-2009 07:57 PM
Riddle me this - Blown Head Gaskets or Something else mick_the_ginge Built Motor Discussion 107 09-22-2008 04:33 AM
Water coming out the tail pipe.....Head Gasket or something worse? Electric-Mayhem Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 07-24-2007 12:55 PM
coolant ? head gasket or normal coolant use Richmond WRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 08-31-2005 09:39 AM
