Old 04-03-2007, 11:25 AM   #1
Sanchez
Member#: 51002
2005 Pig STi
Turbo Negro
Default Gauge cluster questions.
Hello all,
I've sone my searching and have come up with a bit of useful information, but not enough to justify my purchase. I have an 04 WRX and have found an 06 STi cluster for pretty cheap.
By searching, I have found plenty of testimonials about the 05 STi cluster going into an 04, and how to mod it to work. I have not found ANY info on the 06 however. I know the 06 STi is a 'drive by wire' configuration and would like to know if the cluster is different or if it's the same as the 05 (Which I have the writeup for).
Any input on this, pros or cons would be greatly appreciated. Also, if anyone knows for sure if it will work or not, please let me know as well.
Thanks!
Sanchez is offline   Reply With Quote
Old 04-03-2007, 11:52 AM   #2
dangerousatom
Member#: 70710
2002 04STi Swaped RS
w/PPGS & 02 Wagon w/PPGs
The 05-06 clusters are same-same. To put it into a 04 you will have to do the mod to make it fit. The DBW pertains to the throttel body only and will have no effect on guage swaping
dangerousatom is offline   Reply With Quote
Old 04-03-2007, 01:39 PM   #3
Sanchez
Member#: 51002
2005 Pig STi
Turbo Negro
Excellent, thanks a lot.
Old 04-04-2007, 01:12 AM   #4
Sanchez
Member#: 51002
2005 Pig STi
Turbo Negro
Okay, so I got them all hooked up and working, and contrary to popular belief, the shift light AND buzzer work fine. However, the BRAKE light remains on at all times, as do the Diff. Temp and ABS lights. If there's anyone who knows how to disable these, I'm all ears.
Old 04-04-2007, 09:56 AM   #5
dangerousatom
Member#: 70710
-Brake light maybe just a polarity issue:
Try unhooking the switch under the center consol at the base of the E-brake handle. If it goes off when unhooked its a real good chance its polarity.
-Diff temp will be on cuz you have no rear diff temp sensor:
Get a wiring diagram and cut the hot wire to the light.
-ABS lights will be on cuz the sensors are different on the STI vs the WRX
Again find the hot and cut-er
I will send you a PM with sumthing that should help ;-)
Old 04-09-2007, 10:24 PM   #6
wrxwhip
Member#: 80343
1993 T67 Supra
Graphite
sanchez and dangerous,
i am swapping an 06 sti cluster into my 05 wrx. how did you get by the difference in size of the fuel/temp wiring on the 06 sti cluster with the 05 wrx wiring? please let me know. also if anyone can send me some wiring diagrams that would be great. thanks.
cliff
wrxwhip is offline   Reply With Quote
GF8 + STi V7 gauge cluster question Billy Electrical & Lighting 1 01-31-2003 10:46 PM
gauge cluster question scobaru Newbies & FAQs 0 12-31-2002 03:10 PM
02 WRX Gauge Cluster Question Malico Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 10-22-2002 08:21 AM
GC8 gauge cluster question decepticon Interior & Exterior Modification 4 06-30-2002 08:52 PM
Stock gauge cluster question EvasionOfTruth Interior & Exterior Modification 2 05-09-2002 08:03 PM
