Go Back   NASIOC > NASIOC Classifieds > Vendor 'For Sale' Classifieds > Accessories & Misc
Closed Thread
Old 04-03-2007, 03:10 PM   #1
JnJassociates
Vendor Sales Rating: (33)
Member#: 69539
2004 wrx wagon
red
Default Get some sexy head
protection!
At JnJ:
-We were the first vendor to offer safety gear at a fair price on NASIOC.
-We post pricing, because we have nothing to hide. No hidden anything.
-We offer package pricing based on your needs.
-If we say it is in stock, it is in stock, no if ands or butts!
Shop with confidence!
We have instock Pyrotect/Bell helmets, ready to ship!
Stock of sizes vary...
Helmets are SA05 rated and come with a removable liner for easy of cleaning and replacement.
The Pyrotect Open face offers great value and safety!
Just $152.00 shipped to the lower 48 states!
The Pyrotect Full face offers great visability and is well vented!
Just $249.00 shipped to the lower 48 states!
We also have the tribal and flame graphic helmets in stock!
Hot sexy flat black! Just $346 shippedto the lower 48 states!!
These helmets offer many of the features of a more expensive helmet for a lot less money. Again, all are SA05. We do carry and can order M rated helmets at a simialr savings!
Contact us at [email protected] with any questions.
Bryan
JnJassociates is offline
Old 04-13-2007, 02:38 PM   #3
Carreragt2e
Member Sales Rating: (17)
Member#: 130877
2013 Cayenne GTS
any idea of any local vendors in the Milwaukee WI or Madison WI area that I could go to tryon one of these helmets for sizeing?
thanks
-Eric H.
Carreragt2e is offline
Old 04-16-2007, 10:51 AM   #4
JnJassociates
Member#: 69539
2004 wrx wagon
red
Eric,
We are sorry, but we do not know of anyone local to you...
Here is how we size helmets for our customers:
MEASUREMENT:
Measuring the head is a starting point for the entire helmet sizing procedure. Due to varying shapes, heads that are apparently the same size when measured by a tape may not necessarily fit the same size helmet. The circumference of the head should be measured at a point approximately one inch above the eyebrows in front and at a point in the back of the head that results in the largest possible measurement. Take several measurements to make sure you have the largest one.
TRY ON:
A) Grasp the helmet by the chin straps, with the front of the helmet facing you
and the top of the helmet facing down.
B) Place the thumbs on the inside surface of the straps and balance
the helmet with the index fingers.
C) Spread the helmet apart with the hands, and slip down over the head.
If the helmet slides down on the head with no resistance, you have your first indication that it may be too large. Obviously, if it will not slide down over the head at all it is too small. Many people unfamiliar with helmets are reluctant to pull down if they meet resistance as the helmet goes on. Only if the helmet is impossible to put on should you move up to the next size, as helmets that go on snug generally fit very well once all the way on. Remember, most people will select a helmet that is too large for them. The eyes should be approximately in the center of the eye port with the top edge of the liner padding just above the eyebrows.
CHECKING HORIZONTAL AND VERTICAL MOVEMENT:
Now that you are wearing the helmet, look carefully at the way it fits. Check to see if the cheek pads are in contact with the cheeks. Is there excess pressure on the cheeks? Look for gaps between the temples and the brow pad. Check the back of the helmet where the neck roll (if the helmet has one) makes contact with the neck. Does it touch at all? Or is it pushing the helmet away at the rear causing it to roll down over the eyes in front? After you have made your visual check, grab the helmet in your hands, one on either side, and try to rotate the helmet from side to side. Note any movement of the skin while doing this, as well as the amount of resistance to movement remembering to hold your head steady.
Next, check movement up and down, again noting skin movement and resistance. If in either test there was little or no skin movement, and/or the helmet moved very easily, the helmet is too large. A properly fitted helmet will cause the skin to move as the helmet moves. And, it will feel to the wearer as if evenly distributed pressure is being continuously exerted around the head.
NOTE: Helmets are a little like shoes, in that they do break-in a little.
For this reason the best attitude to have when fitting is that the helmet
should be as tight as you can stand to wear it.
HELMET SIZE CONVERSION CHART
Inches Size Metric Equals
21-1/4 6-3/4 54 XX-Small
21-5/8 6-7/8 55 XX-Small
22 7 56 X-Small
22-3/8 7-1/8 57 Small
22-3/4 7-1/4 58 Medium
23-1/8 7-3/8 59 Medium
23-1/2 7-1/2 60 Large
23-7/8 7-5/8 61 Large
24-1/4 7-3/4 62 X-Large
OVER 24 1/4" - 63 XX-Large
Hope this helps.
Bryan
Old 04-25-2007, 03:21 PM   #5
JnJassociates
Member#: 69539
2004 wrx wagon
red
Got some more SA05 rated helmets in stock, a variety of sizes!
Bryan
Old 05-05-2007, 09:06 AM   #6
JnJassociates
Member#: 69539
2004 wrx wagon
red
Bump for more fresh, ready to ship SA05 helmets.
Bryan
Old 05-19-2007, 09:41 AM   #7
JnJassociates
Member#: 69539
2004 wrx wagon
red
We can also order any Bell/Pyrotect helemt at simialr savings!
Please call or email us for more information.
Bryan
Old 05-29-2007, 04:57 PM   #8
JnJassociates
Member#: 69539
2004 wrx wagon
red
Bump for great savings on new SA05 rated helmets!
Bryan
Old 06-11-2007, 04:19 PM   #9
JnJassociates
Member#: 69539
2004 wrx wagon
red
Just got these in...
Bryan
Old 06-18-2007, 02:52 PM   #10
JnJassociates
Member#: 69539
2004 wrx wagon
red
More fresh stock, come and get them....
Remember, we are the ONLY vendor in NY that will come to YOU (LI, Queens, Brooklyn) to fit you for a helemt and/or a driving suit.
Bryan
Old 06-19-2007, 05:58 PM   #11
JnJassociates
Member#: 69539
2004 wrx wagon
red
Also our pricing includes shipping. Best pricing AND service on SA05 rated helemts.
Bryan
Old 06-25-2007, 09:55 AM   #12
JnJassociates
Member#: 69539
2004 wrx wagon
red
Don't use a loaner at the next autocross, get a quality helmet from us!
Bryan
Old 06-27-2007, 05:47 PM   #13
JnJassociates
Member#: 69539
2004 wrx wagon
red
BR1 is in stock.
Bryan
Old 07-01-2007, 09:27 AM   #14
JnJassociates
Member#: 69539
2004 wrx wagon
red
As one of the first vendors to bring safety to NASIOC, order with confidence.
That and these helmets offer awesome bang for the buck when comparing SA05 helmets!
Bryan
Old 07-06-2007, 03:34 PM   #15
JnJassociates
Member#: 69539
2004 wrx wagon
red
Fresh shipment just arrived.
Bryan
Old 07-10-2007, 05:49 PM   #16
JnJassociates
Member#: 69539
2004 wrx wagon
red
Bump for those looking for the post.
Plus, every helmet order will receive our hawt new JNJ decal!
Put it on your helmet or your ride and let them know who took care of you!
Bryan
Old 07-18-2007, 07:03 AM   #17
JnJassociates
Member#: 69539
2004 wrx wagon
red
Just an FYI, we will be out of the office from July 18th 2007 through July 23rd 2007.
Bryan
Old 07-24-2007, 04:44 PM   #18
aren040
Member Sales Rating: (12)
Member#: 74215
Silver-ish
PM Sent
aren040 is offline
Old 07-25-2007, 12:26 PM   #19
JnJassociates
Member#: 69539
2004 wrx wagon
red
Pm answered.
Bryan
Old 08-13-2007, 08:47 AM   #20
JnJassociates
Member#: 69539
2004 wrx wagon
red
We have more fresh stock, ready to ship!
Bryan
Old 08-21-2007, 04:18 PM   #21
JnJassociates
Member#: 69539
2004 wrx wagon
red
We will give you a FREE helmet bag with any order on a closed or open face Pyrotect helmet. Now through the end of September while supplies last!
As the vendor who brought Pyrotect/Bell safety to NASIOC first, we try and offer members excellent service with fair pricing.
Helmets are in stock, so place your order now!
Bryan
Old 08-24-2007, 12:29 PM   #22
kkos06
Member#: 128591
2006 WRX
how much is that new black bell helmet and what is it rated??? Thanks. That thing look wicked by the way.
kkos06 is offline
Old 08-25-2007, 07:39 AM   #23
JnJassociates
Member#: 69539
2004 wrx wagon
red
All of our in stock helemts are SA05 rated.
Price for the Bell BR1 is an awesome helmet! $346.00 shipped to the lower 48 states.
Bryan
Old 09-26-2007, 04:17 PM   #24
JnJassociates
Member#: 69539
2004 wrx wagon
red
Order any in stock helmet and receive a free helmet bag!
Bryan
Old 09-30-2007, 08:00 AM   #25
JnJassociates
Member#: 69539
2004 wrx wagon
red
Free helmet bag offer extended through October!
Order any in stock Pyrotect/Bell helmet listed in this post and receive a free helmet bag. It is that simple.
Bryan
Closed Thread
Who's up for some SEXY Foresters ??? Alex346 General Community 31 11-02-2009 10:40 PM
Hey, Need some sexy costume advice for halloween! kissthetree Off-Topic 28 10-20-2009 05:36 AM
looking for some sexy wheels MyScoobie28 MWSOC Private Classifieds 11 04-20-2008 04:24 AM
Need some sexy 5x100 gold wheels burritotown RMIC Private Classifieds 11 03-03-2008 11:29 PM
Kent gets some head......pics inside Snowman South East Region Forum 16 10-31-2002 09:10 AM
