Go Back   NASIOC > NASIOC Classifieds > Vendor 'For Sale' Classifieds > Engine/Power/Exhaust
Closed Thread
Old 04-03-2007, 05:21 PM   #1
Gruppe-S
Vendor Sales Rating: (65)
Member#: 23216
2006 949-457-1234
949-457-1234
Default VF34s Back in Stock!!(Combos)/EZ30R/EJ25 Turbos/Intercoolers/Injectors/APs/Turbobacks
Hey guys,
Just landed 72x VF34's!!!
The Venerable VF34
For those of you who don't know the VF34 is the turbo found on the JDM STI Spec-C. It is a roller bearing based turbo that employs the best materials and the tightest tolerances in the turbo industry. These turbos take a huge amount of abuse and keep on boosting where many other turbochargers fail. No bearing / cooling issues like Mitsubishi turbos, no finicky oil pressure issues like Garrett turbos. These turbos are good for up to 375HP with excellent spool, transient response, and spool up. There have been a few 2.5 cars running low 12's high 11's with this turbocharger.
-Capable of 375HP
-Excellent response, spool up, durability (top end isn't everything)
-Roller bearing design
-High quality compressor / turbine castings
$819 Shipped!! (must mention this ad)
VF34 TURBO PACKAGE WITH AP
-IHI VF34 Turbo
-STI 565cc Pink Injectors*
-Walbro Fuel Pump
-Cobb V2.0 AP
-Gruppe-S Battery Tie Down
$1699
*STI pink injectors b/o for 2 weeks
VF34 TURBO PACKAGE WITH OPENPORT ECU
-IHI VF34 Turbo
-Open Port ECU Reflash Tuner
-Walbro Fuel Pump
$949
2005/2006 EJ255 Legacy GT / FXT Engines!!
-Virtually identical to USDM 2.5 STI engine
-Very very low miles
-Leak down / compression tested, all greater than 90%
-Great for 2.0 Swaps (2.5 LGT heads flow much better than WRX heads)
-NO INJECTORS
$2999 + Shipping
2007+ EJ25 LGT ENGINE
This is a late 2007+ Legacy GT engine. It has the twin pumps as well as the switch to the top feed 525cc injectors (injectors not included). It is BRAND SPANKING NEW, has probably only a few hours of run time on it. Check out the plugs that came out of it. Compression / Leakdown was perfect. This engine is pretty complete and is perfect for a WRX -> 2.5 Swap. Engines don't come in better condition than this engine.
-2.5 DOHC turbo engine
-Late model virtually no run-time
-NO INJECTORS
-Very complete, may need new turbo inlet
$3499 + Shipping
JDM EZ30R
I am told this is a junkyard engine pulled from a test Tribeca. This particular engine has a bit of leak down loss, about 15-20% loss (80-85%) across all 6 cylinders. Overall the condition of this engine is good (although a bit weathered) - a great candidate for a motor build. We can include custom forged Supertech pistons.
$1899 + Shipping
With 6x Forged Pistons $2199 + Shipping (These pistons have been upgraded to use STI wrist pins)
GRUPPE-S STAGE 2 GS650 SHORT BLOCK
-+2mm Helix Long Rod Ratio engine w/ ARP L19 rod bolts
-Custom Wiseco Forged Pistons with Det Coating (not shown)
-Nitrided, Cross drilled, Balanced Crankshaft (not shown)
-Race coated bearings
-Overall lighter rotating assembly, better balance, stronger internals
-Good for 8000+RPM operation, 650+ crank HP
$3299 + Shipping
Gruppe-S is online now
Old 04-03-2007, 05:21 PM   #2
Gruppe-S
Member#: 23216
2006 949-457-1234
949-457-1234
Greddy PROFEC-B V2 (Black) ONLY ONE AT THIS PRICE!!
Based on the very popular B-Spec., the all new PRofec B-Spec. II, electronic boost controller is equipped with new easy-to-use features at an economical price. In addition to the two presets, remote switch option and wastegate response adjustments, the B-Spec. II also includes: built-in back-lit LCD, which can display real-time, peak, or last boost (in either kPa or PSI), an optional warning and boost limiter functions and a larger capacity inline solenoid valve for higher boost levels.
Normal Price: $439.00
SALES PRICE: $329.00 SHIPPED!!
Y-PIPE & R2D2 BOV PACK!! - ONE IN STOCK!!
-SARD R2D2 BOV
-Gruppe-s Y pipe
Normal Price: $358.00
SALE PRICE: $289.00 SHIPPED!
2004 USDM SUBARU IMPREZA STI INTAKE MANIFOLD (RED)
This intake manifold is designed to be used with the 2004 USDM Subaru Impreza STI (EJ25). This manifold works with the TGV system as well as the drive-by-wire throttle bodies. It will NOT work with the WRX cable throttle body unless new holes are tapped. This is a great upgrade for any other EJ25 DBW car, such as the Legacy GT - the aluminum manifold both flows better and supports higher boost pressures than the plastic manifolds.
PRICE: $89.00 SHIPPED!!
Helix RR500 Turbo Super Special!!
-Perrin V2 Fuel Rail Kit STI - Black
-Perrin Turbo Inlet Pipe
-Helix RR500
-Helix 860CC Injectors
-Walbro 255 lph Fuel Pump
Normal Price: $2138.00
SALE PRICE: $1999.00 SHIPPED!!
HELIX RR500 Turbo Package!!
The Helix RR500 Turbo is a new turbo brought to us by Helix. This turbo is a 46lbs wheel turbo, race designed 8cm hotside, and features similar to the TD06 20G but with a larger compressor wheel. This turbo is rated at 500HP and will give you that extra boost of power when you most desperately need it.
This Package Includes
-Helix RR500 Turbo
-Helix 660cc WRX or Helix 860cc STI
-Walbro Fuel Pump
Sale Price: $1449 Shipped!!
Combo With Cobb V2 Access Port: $2099.00 Shipped!!
Turbo Alone: $999.00 Shipped
HELIX V3 DOWNPIPE & DC SPORTS FLEX UPPIPE
-SS304 TIG welded design
-DC Sports Flex Uppipe
-Excellent Performance gains
Regular Price: $325.00
SALE PRICE: 289.00 Shipped!!
TURBO BACK SPECIALS!!
Helix V3 Downpipe & HKS Carbon TI Exhaust
-Great Look/High Performance
$849.00 SHIPPED!!
Helix V3 Downpipe & Greddy EVO 2 exhaust
-Great balance of power & quietness
$729 Shipped!!
Helix V3 Downpipe & Borla Hush
-Excellent stealth / quiet system
$745 Shipped!!
GRUPPE-S STAGE 2 (+2mm) FORGED INTERNAL KIT!
-Custom Wiseco +2mm Pistons
-Aerospace coating to reduce detonation and improve thermal characteristics (same as Cobb)
-Helix +2mm rods with ARP L19
-Longer piston dwell time improves rev range and top-end power
-Gruppe-S Coated Race Bearings
$999 Shipped!!
Old 04-03-2007, 05:22 PM   #3
Gruppe-S
Member#: 23216
2006 949-457-1234
949-457-1234
The Cobb Version 2 Access Port is one of the most user friendly systems on the market. This hand held ECU reprogramming system utilizes the full extent of your fuel management system allowing for easy, real time tuning. The Cobb AP V2 has come out with some upgrades since the Cobb AP V1 but still retains the high level of performance.
Cobb V2 Access Port Features:
-On the fly map switching
-Monitor vehicle sensor data and display in analog or digital format
-Vibrant color graphic display
-Read/Clear engine trouble codes
-Preloaded with performance, economy and convenience maps.
-Update via the Internet
-Measure 0-60 and ¼ mile times
-Adjustable on screen shift light functionality
-Estimates horsepower and Torque
-Displays current and averaged fuel economy
-Drag race simulation with reaction time and time slip data
-Built in on screen help mode function
-Multi language support
-RoHS Compliant (Lead Free design)
Cobb V2 Access Port Package 1
This package includes
-Cobb V2 Access Port
-Your choice of 1 Step Colder Spark Plugs or Walbro Fuel Pump
-Dyno Tuning
-Free Installation
Sale Price: $899.00 INSTALLED/TUNED
Cobb V2 Access Port Package 2
-Helix 660cc Injectors
-Walbro Fuel Pump
Regular Price: $1199.00
SALE PRICE: $899.00 OTD!!
INSTALLED/TUNED PRICE: $1149.00
Customers will have 30 days to schedule dyno tuning from time of purchase.
Non Local Customers!!!
This Package Includes:
-Set of NGK 1 Step Colder Spark Plugs
$699 shipped!
TURBO COMBOS!!
We have a great selection of turbo packages just for you Combo with Cobb Access Ports For ADDITIONAL SAVINGS!!
Forced Performance Green or Red Turbo Package
-FP Green Turbo or Red
-Helix 860cc Fuel Injectors
-Walbro Fuel Pump
-Water and Oil Lines
Regular Price: $2755.00
Combo With Cobb V2 Access Port: $2599 Shipped!!
Gruppe-S Y-Pipe Kit
The Gruppe-S intercooler hose kit replaces the corrugated rubber stock y-pipe, smoothing and increasing the airflow, making for a nice increase in power and better boost response. Includes a cast-aluminum Y-pipe, premium quality 4-ply silicon hoses, clamps. This kit will work for STi TMICs being installed on WRXs.
Normal Price: $99.00
SALE PRICE: $89.00 SHIPPED!!
SMC ALKI INJECTION KIT
-High quality / reliable pump
-Good for substantial horsepower gains
$499 Shipped!!
Thanks!!!
-Gary
Gruppe-S
Old 04-03-2007, 05:22 PM   #4
Gruppe-S
Member#: 23216
2006 949-457-1234
949-457-1234
TURBO LONG BLOCKS!!!
2005-2006 LEGACY GT TURBO LONG BLOCK!!
-Virtually Identical to USDM STI engine
-2.5 Liter displacement, higher lift / duration AVCS heads
-Better flowing heads, no air-pumps
-Excellent compression / leakdown 95%+
-Less than 1000km
-Great for swaps into 2.0 cars (please see our Gruppe-S cam position adapter)
-Bare Long block only
$2799 + Shipping
JDM 2005 LEGACY B4 "STI" 2.0 TURBO ENGINE
-280 HP
-Twin AVCS
-Includes 2004+ STI style heads and STI style cams (press on lobes)
-These cams have less lift but more duration than the USDM WRX Cams
-This engine has problem with the intake valve (stuck open), so this engine is good for REBUILD ONLY
-Please contact us for more information!
$1499 + Shipping
Old 04-03-2007, 10:35 PM   #5
Gruppe-S
Member#: 23216
2006 949-457-1234
949-457-1234
Default Gt30r Turbo Kit (prototype)
Hey guys, we have one GT30R Prototype Turbo Kit.
This is a setup kit only. This particular turbo kit is a prototype (production units are a few months out). The fitment on this kit is 90%, but there is some rubbing / tight areas on the subframe. You may have to notch the subframe and/or cut and weld to get 100% fitment.
GT30R TURBO SETUP KIT
-Brand New Garrett GT30R Ball Bearing Turbo
-4 Bolt turbo, 0.82 A/R
-4-bolt SS304 downpipe, TIG welded
-SS304 Uppipe TIG welded
-Flanged for 38mm Tial WG
-Oil reducer / water feeds included (oil feed line not included, available for $30)
-Intake not included
-Fitment is >90%< (will bolt on, rubs a little)
-THIS IS A 400WHP+ TURBO KIT
$1499 Shipped!!!
ONE at this price. When the kits come out they will be $2500+
Thanks,
Gary
Gruppe-S
Old 04-03-2007, 11:43 PM   #6
dirtyhartland
Member Sales Rating: (7)
Member#: 64298
lazy and in pieces
pm sent regarding complete EJ255
dirtyhartland is offline
Old 04-04-2007, 09:50 PM   #7
Gruppe-S
Member#: 23216
2006 949-457-1234
949-457-1234
Hi, I think someone responded to your PM already. If you have any questions, please don't hesitate to e-mail me directly. We have only ONE EJ255 left in stock ready to go. I have some built GS650's coming in.
Thanks,
Gary
Gruppe-S
Old 04-04-2007, 10:10 PM   #8
AltronX
Member Sales Rating: (18)
Member#: 86241
2006 Bolony Mobile
REAL MAN KREW #5
Do you guys carry a Helix Catted downpipe?
AltronX is offline
Old 04-05-2007, 12:38 AM   #9
Gruppe-S
Member#: 23216
2006 949-457-1234
949-457-1234
Hi,
Unfortunately we're currently b/o on the Helix catted DP. Next shipment is scheduled for end of April, they are $329 shipped. We do have the Catless V3 in stock for $199 shipped. Thanks
Gary
Gruppe-S
Old 04-05-2007, 05:52 AM   #10
dan_m
Member Sales Rating: (1)
Member#: 82836
interested in the 2004 sti intake manifold, please confirm total to Canada H1C 2B5 ( Montreal ) thx.
dan_m is offline
Old 04-05-2007, 02:45 PM   #11
Gruppe-S
Member#: 23216
2006 949-457-1234
949-457-1234
PM Sent!
Old 04-06-2007, 02:00 PM   #12
jcayos
Member#: 94471
2003 WRX
Default Vf22?
Do you guys have any VF22's in stock? If so do you have any kind of package deal for it like the VF34 combo deal with the Cobb AP, and instead of STI Pinks could I get Helix 660 injectors? Thanks guys.
jcayos is offline
Old 04-06-2007, 04:28 PM   #13
Gruppe-S
Member#: 23216
2006 949-457-1234
949-457-1234
Hi hi, yup we can do VF22's special order! I have 10x coming in for a wholesaler, but I can get you one but you have to prepay!
I can do additional $50 for Helix 660 injectors - but you will likely not need 660 injectors for the VF22/VF34 turbo and they are harder to tune for so I would stay with the STI 565cc unless you really have the need for that extra fuel.
Thanks,
Gary
Gruppe-S
Old 04-07-2007, 02:18 AM   #14
wrxmase
Member Sales Rating: (15)
Member#: 118179
97l cpe&sdn10LGTab
03sti yella 11 2.5i dgm
can you pm me a price for a grupes header
wrxmase is offline
Old 04-07-2007, 12:07 PM   #15
Winner
Member Sales Rating: (38)
Member#: 106050
- pm Josey Wales
you have a pm
Winner is offline
Old 04-07-2007, 01:11 PM   #16
BLAC04WRX
Member#: 145596
2004 WRX 2.0 Wagon
296hp 277tq
$745 Shipped!!
I would like this deal can you send me info on how to buy this.
BLAC04WRX is offline
Old 04-08-2007, 04:43 PM   #17
SubbyPAT
Member Sales Rating: (5)
Member#: 129490
2009 370z blueee
Hey foo's ..
HOw much the VF34 PACKAGE without the AP V.2 ?
Let me know guys!
SubbyPAT is offline
Old 04-08-2007, 09:16 PM   #18
derek686
Member Sales Rating: (6)
Member#: 139258
vf34 come with gaskets studs and lines?
derek686 is offline
Old 04-09-2007, 04:42 AM   #19
wrx2nv
Member#: 48668
black
Got any USDM STI motors?
wrx2nv is offline
Old 04-09-2007, 02:13 PM   #20
RSpeeder
Member Sales Rating: (4)
Member#: 37222
2008 335i
vf34 / pinks / walbro shipped to 48116?
Thanks
AJ
RSpeeder is offline
Old 04-09-2007, 04:36 PM   #21
Gruppe-S
Member#: 23216
2006 949-457-1234
949-457-1234
Pm's Sent!!
Old 04-09-2007, 07:21 PM   #22
brodiemash
Member#: 105011
2006 Impreza TR WRX
Obsidian Black
You guys sell VF-22's?
brodiemash is offline
Old 04-09-2007, 07:44 PM   #23
hater06
Member Sales Rating: (17)
Member#: 139699
2011 WRX STi Limited
[Helix V3 Downpipe & Borla Hush
$745 Shipped!!
is this the catted dp?]
BAH... nvm... i didnt read the other posts... pm when you have the catted version in stock... i'll buy this package then... thanks...
hater06 is offline
Old 04-10-2007, 02:49 PM   #24
ant927
Member Sales Rating: (3)
Member#: 65585
04 FXT
java
Thanks,
Gary
Gruppe-S
Please PM me local pickup price on these vf22s for prepay. I am very interested and can get payment to you ASAP. Will these include oil/coolant lines and studs? Thanks.
ant927 is offline
Old 04-10-2007, 02:52 PM   #25
Gruppe-S
Member#: 23216
2006 949-457-1234
949-457-1234
Hey guys,
Yup we carry the VF22's. They are $749 shipped. Keep in mind though the VF34 has a much better bearing design than the VF22 as the VF34 is a much newer turbo.
Thanks!!
Gary
Gruppe-S
Closed Thread
FS in SC: 2005 WRX OEM Turbo, Intercooler, Injectors, and Exhaust jmhubbard01 South East Region Private Classifieds 8 02-26-2010 08:32 AM
FS in SC: 2005 WRX OEM Turbo, Intercooler, Injectors jmhubbard01 Engine/Power/Exhaust 5 01-25-2010 08:09 PM
Engines Back In Stock! VF34-Helix DP-Gruppe-S Manifold-Turbo Back Combos-Free Dampers Gruppe-S Engine/Power/Exhaust 35 10-08-2007 09:34 PM
Helix, Gruppe-S, VF34s back in stock! More new parts on the way! Gruppe-S Engine/Power/Exhaust 19 07-25-2006 03:54 PM
JDM IHI VF34 Back in stock!! $725 Shipped & Stage 2 Power Package! Gruppe-S Engine/Power/Exhaust 13 04-14-2004 03:04 PM
Message Board Statistics All times are GMT -4. The time now is 09:18 PM.
