Old 04-03-2007, 08:06 PM   #1
urabusti
Member#: 117103
05 STi
crystal gray metallic
Unhappy slow sti
i have an 05 STi that's under boosting. i think it's been like that for about a year now but never really noticed untill a freaken lumina cut me off and spanked me. i haven't been driving my car very hard.....or "enthusiasticly" as some people would say so i don't think that i might have done anything really bad to it. i hooked it up to an access port and was reading the boost at wide open throttle in 4rth and 5th gear and only obtained a maximum of 7.8 psi of boost. the only mods i have on the car is a perrin oil catch can and .......an air freshner......:-\
wondering if anyone has any clues as to what the problem may be before subaru rips mah baby apart and starts pointin' fingers at me........
urabusti is offline   Reply With Quote
Old 04-03-2007, 08:09 PM   #2
fastwrx05
Member#: 94131
08' SRT Caliber
Hard to keep clean black!
Just please unhook the acessport before you take it to subaru, and don't leave it in the car!!! Sorry thats all the advice I can give.
fastwrx05 is offline   Reply With Quote
Old 04-03-2007, 08:14 PM   #3
urabusti
Member#: 117103
05 STi
ya, the access port belongs to a friend and i borrowed it just to monitor the boost cuz i don't have a boost gauge
Old 04-03-2007, 09:11 PM   #4
Got Boost?
Member#: 113096
06 sti
try resetting the ecu first, it may be in limp mode
Got Boost? is offline   Reply With Quote
Old 04-04-2007, 01:28 AM   #5
shemoves
Member#: 80663
2005 STi
Def. reset the ecu and watch her come back to life. Unplug the negative on the battery, pump your brake pedal a couple-few times, put negative back on. Go for a test drive. Also, make sure that the gas in your tank is 'tween 91 and 94 octane.
(I am assuming you are good about regular maintenance...oil, air filter, etc.)
shemoves is offline   Reply With Quote
Old 04-04-2007, 08:26 AM   #6
sticky tires
Member#: 53985
I am 99% sure that your problem is the boost solenoid. Try borrowing one from a friend. I noticed the same problem when I went to get my car protuned. I was only hitting about 8lbs full boost.
My tuner said he has seen lots of stock boost solenoids go bad. Search under boost solenoid and you'll find some hits.
The part cost around $100-150.
sticky tires is offline   Reply With Quote
Going slow over bumpy roads..making people angry ZAG_WRX General Community 100 06-04-2010 12:44 PM
18in volk rims slowing Sti down a bit hilfiger4you Tire & Wheel 39 12-21-2005 11:47 AM
