Old 04-03-2007, 08:36 PM   #1
Kostamojen
Member#: 2272
2013 Subaru BRZ
Galaxy Blue
OMGHi2U So... Who will be the first to swap the 3.6?
Same dimensions as the EZ30...
TONS more torque...
A bit more HP...
Better MPG...
Who will be the first?
Old 04-03-2007, 08:41 PM   #2
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
ill post the same thing i would if you were a knoob
http://forums.nasioc.com/forums/showthread.php?t=748385
Old 04-03-2007, 09:12 PM   #3
Kostamojen
Member#: 2272
2013 Subaru BRZ
Galaxy Blue
I have like 50 posts in that thread...
But we still need a 3.6l source/containment thread since it is a new, seperate motor from the EZ30. But since its still using the same basic design, which I actually thought was going to be a timing belt instead of chain from what I heard, means it will fit just the same as the EZ30 in various other engine bays.
The wiring/etc will probably even MORE complicated than the EZ30, but considering this motor is significantly more powerful, this might be more worth all the extra crap you have to go through to use the motor.
Old 04-03-2007, 09:41 PM   #4
Kostamojen
Member#: 2272
2013 Subaru BRZ
Galaxy Blue
I just had another thought...
This engine might end up being a simple swap for someone with a 3.0R outback wagon/sedan or even the current tribecas, depending of course on how different the sensors/wiring/etc. are laid out. If its close though, might be interesting to find a used 3.0R 05 outback sedan and swap in this engine and a 6-speed...
Old 04-03-2007, 10:36 PM   #5
adhowe70
Member#: 3363
1982 Reynard
Blue, Red, and White
Bore and stroke? Anyone?
adhowe70 is offline   Reply With Quote
Old 04-03-2007, 10:41 PM   #6
Kostamojen
Member#: 2272
2013 Subaru BRZ
Galaxy Blue
Old 04-03-2007, 10:51 PM   #7
Kostamojen
Member#: 2272
2013 Subaru BRZ
Galaxy Blue
For reference, here is a simular cut away of the 3.0R...
Old 04-03-2007, 11:05 PM   #8
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
i am messin' with ya
i don't think it will be a big swap canidate
its stil WAY WAY WAY more work than a ej205 and less power (assuming stage 2)
until a uber flexable can bus standalone ecu comes out .. i dont see it happening at all
what are the bore and stroke of the ez30
Old 04-03-2007, 11:07 PM   #9
adhowe70
Member#: 3363
1982 Reynard
Hmmm... small overbore, but they stroked the piss out of it.
I wonder if there's anything in the heads that I could scavenge for my car - like valves or cams.
Old 04-03-2007, 11:17 PM   #10
Numbchux
Member#: 71658
'84 Brat
4" lift and 29" tires
some interesting info for those who haven't heard:
Originally Posted by http://www.caranddriver.com/autoshows/12685/2008-subaru-tribeca.html
2008 Subaru Tribeca - Auto Shows
Subaru’s slow-selling mid-sizer gets a new 3.6-liter engine and less polarizing styling.
April 2007
Although the availability of a “real” SUV in the form of the B9 Tribeca bumped overall Subaru sales past the 200,000-unit mark in 2006, sales of the controversially styled mid-size SUV were considered mediocre. In response, Subaru is bringing out a hastily revised version. The new Tribeca (the B9 suffix will be dropped for the 2008 model) features fairly comprehensive front and rear styling revisions, replacing the controversial Alfa Romeo–like cues with more conventional treatments. At the same time, the flat-six powerplant is being boosted in capacity from 3.0 liters to 3.6 liters in the interests of better performance and economy.
But here’s where it gets interesting. The flat-six engine (or H6, as Subaru calls it) is already a tight fit in the Tribeca’s engine bay. Since the H6 is a horizontally opposed layout, any significant increase in crankshaft stroke would result in engine-block deck-height increases that would make the engine too wide to fit in the existing structure.
The problem was exacerbated by typically thrifty computer-aided engine design, which left minimal space between the engine’s cylinder bores. Subaru calculated that it could safely increase the bore size from 89.2mm to 92.0mm, but that change would have bumped the displacement to only 3191cc. Subaru needed more than that for the performance improvements it was seeking, so it came up with a novel way of increasing piston stroke without raising the cylinder deck height. The answer was an asymmetrical connecting-rod design (which looks somewhat like a lamb chop) that permits the piston to travel farther downward into the crankcase and increases the effective stroke from 80mm to 91mm.
Numbchux is offline   Reply With Quote
Old 04-04-2007, 12:07 AM   #11
Kostamojen
Member#: 2272
2013 Subaru BRZ
Galaxy Blue
The rods...
Old 04-04-2007, 12:37 AM   #12
supasweetr34skyline
Member#: 113060
2000 Built GC8
Aiming for 10's
ima throw some d's on that bitch
supasweetr34skyline is offline   Reply With Quote
Old 04-04-2007, 01:12 AM   #13
wuuusaa
Member#: 92894
2015 Wrx
what he said.
Old 04-04-2007, 03:30 AM   #14
shadyrex
Member#: 24540
2015 WRX
Who cares who will be the 1st to swap it.
The real question is: Who will be the 1st one to turbo it(maybe twin turbo?) and then swap it? Maybe into a GC8 2dr?
shadyrex is offline   Reply With Quote
Old 04-04-2007, 09:33 AM   #15
kheff46
Member#: 66739
2002 WRX wagon
i'll do it!
i just sold my V4 swap to a friend who wants to build it.
so im searchin right now for the project car/chassis right now!
who's gonna donate the engine? i can afford the regular EZ, but a new 3.6 R may cost a bit more than i'd like. i can do either H6 save the new one maybe(cost).
--keith
and i have a couple turbos and IC's laying around
kheff46 is offline   Reply With Quote
Old 04-04-2007, 11:26 AM   #16
jedz123
Member#: 67083
1993 Impreza L HB
EJ25D swap, 5-speed FWD
What the Engine code on that beast? EZ36?
jedz123 is offline   Reply With Quote
Old 04-04-2007, 11:41 AM   #17
mxpunk
Member#: 132130
2002 Ford F-150
Graphite Gray
Im waiting for a legacy coupe with a turbo'd H6 motor..
mxpunk is offline   Reply With Quote
Old 04-04-2007, 12:31 PM   #18
jedz123
Member#: 67083
1993 Impreza L HB
uhhh... I like the Sedans but Coupe???? Can't say I would like that...I like the Turbo H6 idea though
Old 04-04-2007, 12:42 PM   #19
Homemade WRX
Member#: 33782
96 bastard child
search FIRST, then PM!!!
that makes for an even shorter rod ratio
also looks like it is dual avcs...haven't done any reading on it though...
also wondering if we have the dual cam profile too
edit: that assymetrical connecting rod is what increases the stroke without increasing the stroke of the crank...so that will be a problem in building a performance/turbocharged setup...also makes for interesting timing and crazy dwell times....
Old 04-04-2007, 12:48 PM   #20
LastResort
Member#: 99289
I think this could conceivably be twin turbo-ed and get decent performance out of it. But I'm willing to be a single larger turbo would give you the same spool, and gains, with less complexity.
LastResort is offline   Reply With Quote
Old 04-04-2007, 12:57 PM   #21
jedz123
Member#: 67083
1993 Impreza L HB
THe Best rule on any project like this thats never been done before...Keep It Simple Stupid!
Where would ytou source that motor? Is it in the JDM yet?
Old 04-04-2007, 01:27 PM   #22
Homemade WRX
Member#: 33782
96 bastard child
one more not to this is the incredibly thin cylinder walls wouldn't do too well with boost either
there also really isn't much room for sleeving of any kind on the EZ30 much less the "EZ32" bore...
yes I know I quoted myself but quoted so people won't over look these issues that would arise in building a boosted EZ36 application
Old 04-04-2007, 02:03 PM   #23
jedz123
Member#: 67083
1993 Impreza L HB
Ahhh let em' do it. I love watching people do stuff like this and
then wonder why there engine Gernaded on em'.
The motor isn't closed deck is it? Even if you didn't kill the engine internally It looks like this thing would be prone to Head gasget faliure. If I had the block I would do everything I could to keep it N/A and run with that... Every one wants boos but geez I think N/A is more fun!!!
Old 04-04-2007, 02:18 PM   #24
Kostamojen
Member#: 2272
2013 Subaru BRZ
Galaxy Blue
I have no interest in seeing one turboed. The current EZ30R doesnt like being turboed, and this one is even more sensitive with a longer stroke and thinner cylinder walls. Its not a good engine for turboing.
Old 04-04-2007, 02:20 PM   #25
Kostamojen
Member#: 2272
2013 Subaru BRZ
Galaxy Blue
EZ's dont blow headgaskets, at least not that i've seen.
What company will be the first to bring the China car to the USA??? Destroy Off-Topic 32 04-22-2008 05:43 PM
So who will be going to AutoX tomorrow at FIR? homiusang South West Impreza Club Forum -- SWIC 8 04-29-2006 02:57 PM
Indy motor swap - who will be done first? dbrier Mid West Subaru Owners Club Forum -- MWSOC 15 06-21-2004 05:42 PM
So who will be Auto-X'n on the 18th??? subyguy2 Mid Atlantic Impreza Club -- MAIC 6 08-08-2002 04:48 PM
Who wants to be the first to get the hottest new mod? skyliner33v Interior & Exterior Modification 32 08-18-2001 02:31 PM
