Canada Region Club
Go Back   NASIOC > NASIOC Regional Areas > Canada Region Forum > Canada Region Vendor Classifieds
Old 04-03-2007, 11:50 PM   #1
Touge Tuning
Vendor Sales Rating: (11)
Member#: 139523
2007 Subaru Legacy
Diamond Grey Metallic
Default Mfactory Magnetic Drain Plugs
If you have recently done an engine rebuild or transmission rebuild these plugs are a MUST in my opinion to protect your freshly machined cylinders or new Close ratio gears from metal particles. This doesnt mean you cant benefit from these plugs if you havent dont either of the above.
More Info:
-Increase your engine/transmission lifespan by removing metal shavings from your oil with this super strong magnetic drain plug
-This will prevent premature damage and will keep metal shavings from circulating throughout your engine/transmission
-Our plugs replaces your stock OEM drain plug with hassle free installation
-Although your oil filter does a good job of cleaning your oil it will not stop the metal particles/flakes from circulating in your system
-Our Magnetic Drain Plugs come with a crush proof aluminium gasket to stop leaks and utilises a neo-dymium magnet which will not rust
-This product provides you with cheap insurance and provides a way of indicating a problem that you may not be aware of before it becomes serious
-The image shows our magnetic drain plug lifting an old Cam Gear, a rear camber arm (Weighing over 1.3kg! You would be hard pushed to find a competing plug able to lift even half that weight!) and 2 plugs attracted to each other through a solid wood shelf
-Beware of cheap plugs on the market with a weak magnet, these plugs will provide a false indication as the particles will be washed away when you drain your oil or when you start your car
-Made out of high quality aluminum
All Fitments are in STOCK
Fitments Available For:
- Honda/Acura Oil Pan Fitment
- Honda/Acura Manual Transmission Fitment
- Lexus Oil Pan Fitment
- Mazda Oil Pan Fitment
- Mitsubishi Oil Pan Fitment
- Nissan Oil Pan Fitment
- Subaru Oil Pan Fitment
- Toyota Oil Pan Fitment
- Ford Oil Pan Fitment
- GM Oil Pan Fitment
- Vauxhall Oil Pan Fitment
- Opel Oil Pan Fitment
These magnetic drain plugs sell for $15+US from other companies but we feel we can do better.
First Plug: $15CAD
Any Additional Plugs: $10 each
Shipping $2.50 for the first plug and $0.50 for each additional plug
Contact Info:
Chris Richardson
Touge Tuning
Email: [email protected]
MSN: [email protected]
Subaru Drain Plug
Metal from close ratio gearset break-in, magnetic drain plugs are incuded with all FD and close ratio gearsets.
Touge Tuning is offline   Reply With Quote
Mfactory Magnetic Drain Plugs Special Touge Tuning Engine/Power/Exhaust 42 09-26-2007 02:22 AM
Magnetic drain plug? rayw1128 Transmission (AT/MT) & Driveline 18 07-12-2002 11:18 PM
Magnetic Drain Plug? HudsoN456 Service & Maintenance 11 06-08-2002 03:36 PM
metal filings on diffs magnetic drain plugs shortlid Transmission (AT/MT) & Driveline 1 06-07-2002 11:35 PM
