Old 12-11-2001, 02:36 AM   #1
wrxinfx
Member#: 10515
2002 WRX Sedan
Question burning oil smell after oil change?
I have been taking my car to a independent shop to do my oil changes and it seems like they allow some oil around the filter to leak on the manafold and it stinks for a little while after. I haven't done it myself or taken it to the dealer for a change, does this happen to any of you?
wrxinfx is offline   Reply With Quote
Old 12-11-2001, 02:51 AM   #2
topcover
Member#: 8999
2002 EJ25 FXT Wagon
Platinum Silver, Stage2
All I know is that when I first changed the oil and removed my oil filter a lot of oil got caught up on the black plastic "skid plate" towards the front of the car. It was a PITA to get all of the oil out and it did leave a burning smell for a few days later.
I changed my oil just this past weekend. The Futumo valve was a saviour. Not one drip! On the suggestion of a couple of club members, I used an awe to poke two holes into the bottom of my oil filter. Let most (I stress "most" as there was more oil in the filter) oil drain out. Put my finger over the two holes gave the oil filter one full rotation removed my finger and sure enough more oil. Let that finally drain down, slipped a plastic bag over the filter and removed it. Two small drops of oil at the most.
No fuss, no muss, no burning!
I suggest that everyone change their own oil. It's cheap and easy to do... even for me... a mechanical idiot.
topcover is offline   Reply With Quote
Old 12-11-2001, 02:54 AM   #3
Richard L.
Member#: 8465
'00 2.5RS Coupe, AW
'93 GMC Typhoon AWD
I rarely get oil onto the manifold when I remove my oil filter. If oil happens to get onto the manifold, then I just spray the affected area with some cleaner and wipe it clean before I drive off.
Richard L. is offline   Reply With Quote
Old 12-12-2001, 02:53 AM   #4
wrxinfx
Member#: 10515
2002 WRX Sedan
Thanks for the info! I'll ask the guys who do mine to be more careful. If I had a place to do it myself, I'd prob. get the valve thinghy and take good care to not spill. Oh well.
Old 12-12-2001, 09:13 AM   #5
fabulous12
Member#: 6831
98 impreza 2.5RS
black
man i think the first time i changed my oil i got more of the stuff on myself and the driveway than i did in the darn catchpan
fabulous12 is offline   Reply With Quote
burning oil smell after oil change happs subi Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 17 12-02-2009 12:37 PM
Oil Leak after Oil Change? salvator_rizzo Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 7 05-28-2009 10:14 PM
burning clutch smell after driving 02blkwagn19 Transmission (AT/MT) & Driveline 2 12-22-2007 01:30 PM
Burnt oil smell after Turbo Install roybfr Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 2 06-13-2006 11:49 PM
Leaking Oil FAST After Oil Change williaty Service & Maintenance 10 12-05-2005 02:57 PM
