#1 |
Member#: 324354
I'm not sure if anyone else has experienced this, but when installing the front mud flaps, you are required to remove the sideskirt via 2 different plastic push screws.... WHO INVENTED THOSE DAMNED THINGS AND WHY ARE THEY SO CHALLENGING TO REMOVE
![]() ![]() ![]() ![]() ![]() ![]() ![]() I have never been so frusterated ![]() ![]() in my entire career of dealing with cars... while I am no professional mechanic, it would seem to make much more sense to just use regular screws or bolts. At this point, I have damaged or destroyed 3 out of the 4 side skirt push-screws that are required to be removed... time to call my Subaru dealer I guess. So, back to the question, why are they so demanding to remove or am I just on the short-bus here?
#2 |
Member#: 11356
Vehicle:2012 WRX STi Hatch DGM |
Not sure why you are having so many issues. Mine came off just fine. Did you follow the directions and use two flat head screwdrivers to pry them out first? Once that is done that basically fall right out!
#3 |
Member#: 304606
W. Canada
Vehicle:2012 STi SWP |
I just pulled mine off...Make sure you have all the necessary pins/screws removed. The side skirt is just pushed in/pulled off.
#4 |
Member#: 324354
it's not the side skirt that is hard to remove its the pins themselves.
#5 |
Member#: 324354
i think its because i was trying to do it with only one flat head screw driver
#6 |
Member#: 128517
Vehicle:2012 WRX Ltd 5 Door WRB |
Have to use some patience with any of the plastic retaining clips on these cars. They are one aggravated pull from shattering. Of course, this is the reason I have a bag of replacements on hand at all times.
#7 |
Member#: 338152
For anyone who wants more specifics, use two flathead screwdrivers from opposing angles (180 degrees offset each other), then push them in as far as you can while prying them. This will compress the inner legs of the pin, and it will pop right out. You *cannot* do it well with one screwdriver.
For the other pins (that have a philips head point), slowly twist them until they are at their peak height. If you turn them too far, they'll snap back in and you'll have to continue turning them until they get back up to that peak height. Once there, use a flat head to pop it out. The screwing motion pulls the pin far enough out to compress the inner legs, which is why it's necessary. |
#8 |
Member#: 306372
any body clip is a pain to remove. Just make sure its clean and get two screw drivers and try to work the pins out.. takes time.. new clips are a couple dollars last i checked so its not to bad if the old ones break..
#9 |
Member#: 307939
Vehicle:2012 WRX Base Sedan WRB |
anybody know of some good websites to order these plastic screws from?? I broke at least 2 of them...
#10 |
Member#: 322385
try your dealer, probably cheaper/easier
#11 | |
Member#: 307939
#12 |
Member#: 262760
Vehicle:2011 WRX Hatch Limtd Satin White Pearl |
Hey short bus! I can get those off using one larger screwdriver and a twisting motion. Good luck. Your dealership stocks those and you can buy 300 of them for $2 (note exaggeration). The point being this; you must not be the only one having issues.
#13 | |
Member#: 262760
#14 |
Member#: 335422
SCIC
Vehicle:2013 STi Sedan White |
Hahaha I feel your pain. When I was installing mine, the screw rivet wouldn't pop out cause I was applying too much pressure. So I got frustrated and popped it off with a flat head. That broke it. That was on the first flap, then I learned less pressure is better. Once you loosen them, you should be able to pull them off with your fingers. You're not the only one though, I'm there with you.
#15 |
Member#: 337980
TXIC
Vehicle:2012 WRX Sedan Satin white |
u can find them on this websites. i broke two of mine as well already ordered them and i think these are the same ones but i broke my rear ones so i ordered the correct ones and a few extras just incase this is were i found them em all at
http://www.clipsandfasteners.com/Sub...s_p/a21420.htm http://www.clipsandfasteners.com/Sub...r_p/a21576.htm http://www.clipsandfasteners.com/Sub...r_p/a21563.htm |
| Thread Tools | |
| Display Modes | |
| FS : Rally Armor Mudflaps STI AND WRX SEDAN 11-12 ONLY!!! | Zwrx85 | Exterior/Styling | 1 | 06-05-2012 11:17 PM |
| WTB : Rally Armor Mudflaps for 2011 WRX Sedan | rigs09 | Private 'Wanted' Classifieds | 0 | 11-13-2011 11:56 PM |
| WTB : Rally Armor Mudflaps for 2011 WRX Sedan | GreenArrow1911 | Private 'Wanted' Classifieds | 1 | 07-06-2011 10:56 PM |
| WTB : WTB Rally Armor Mudflap for 2011 WRX sedan | xabre1200 | Private 'Wanted' Classifieds | 0 | 02-12-2011 08:06 PM |
| WTB: Rally Armor Mudflaps, Fastlines 02-07 WRX | MikeSlimJimLim | SCIC Private Classifieds | 36 | 09-03-2008 01:32 PM |
