Old 04-04-2007, 12:12 PM   #1
BigJ04STi
Member#: 77239
2004 Impreza WRX
None
Default JDM Legacy TGV's the same as USDM STi?
I came across these the other day on AVO's site, and for the price you can't go wrong.
The question is, are these Manifold Risers aka TGV-less TGV's from a JDM Legacy GT the same exact fitment as a USDM Legacy or USDM STi?
Will they bolt right up, and utilize side-feed injectors?
For the price you can't go wrong... I think I'm gonna order a set anyhow...
Please click the link...
http://www.avoturboworld.com/avoshop...e468b04f64bc81
BigJ04STi is offline   Reply With Quote
Old 04-05-2007, 11:46 AM   #2
BigJ04STi
Member#: 77239
2004 Impreza WRX
None
No one?
If this is repost, sorry... I didn't see anything anywhere else... I'll keep searching.
Old 04-05-2007, 12:57 PM   #3
socalLGT
Member#: 89752
08 STI
They are a direct fitment to the USDM and JDM Legacy with the plstic intake manifold. I have a set on my car and they dropped right in. IIRC they will fit on an STi, you just need to redrill a couple holes on the manifold to line them up with the holes on the TGV's. So while it's not a perfect drop-in, it'll work quite well with minimal fuss.
socalLGT is offline   Reply With Quote
Old 04-05-2007, 02:19 PM   #4
moswald80
Member#: 96620
2005 WRX STi
Yes, I installed these in my STi a few months ago (I got mine from Renick but I assume they are the same). You will need to slot 4 holes on your Intake Manifold. The gaskets (make sure you get new gaskets) are slotted at those holes so you just need to make the Manifold match the gasket. I would also recommend porting your Intake manifold to match the TGV deletes. The TGV Deletes have about 1/4 inch larger diameter than the Intake Manifold Runners so you should try to smooth out that transition as much as you can.
Other than that they are a direct replacement and they utilize side-feed injectors (obviously you'll have to turn off all of the TGV codes or you'll get a CEL). They are great parts, especially for the money. You should change out your turbo inlet too (if you haven't already) while you have the manifold off.
moswald80 is offline   Reply With Quote
Old 04-05-2007, 02:40 PM   #5
BigJ04STi
Member#: 77239
2004 Impreza WRX
None
Cool... I was told the holes "almost" match up for the bolts... I just wanted to know by how much.
Thanks for all the responses...
I'm Installing an 8cm FP Green, Samco Turbo Inlet, PE 850cc Injectors, etc etc etc... So I figured why pay someone to port TGV's and fill the rod holes, or do it completely myself... when for $199 I can have perfectly clean ones.
Thanks again...
is the valve cover gasket for jdm ver. 7 sti same as usdm sti? legacy2003 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 9 04-13-2013 04:51 AM
Timing Cover for JDM EJ207 Ver8 same as USDM STi? Kotir Subaru Conversions 7 03-24-2013 06:00 PM
Are JDM sti axles the same as USDM sti axles? Capt Crunch Transmission (AT/MT) & Driveline 0 06-25-2006 02:34 PM
WRX Headers the same as USDM STI? GTR STI Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 2 10-12-2004 04:12 PM
Are the JDM STi axle boots the same as USDM STi? Capt Crunch Transmission (AT/MT) & Driveline 0 07-23-2004 08:23 AM
