Welcome to the North American Subaru Impreza Owners Club Sunday August 28, 2016
Old 04-04-2007, 03:20 PM   #1
MarkRx
Member#: 42242
2006 STI
Default WHICH shifter grease?
Everyone and their brother says to use grease on your shifter, or when installing a short throw. Cobb shifters recommend moly grease to go in the pivot cup, on the end bushings and sleeve. I want to the EXACT kind of shifter grease that is to be used with metal/nylon/rubber combination. I supposed white lithium would work, but no moly. the only thing that part stores carry that has a small percent of moly is the black EP grease, this is a big NO NO. Energy suspension makes a white bushing lubricant that comes in a small tube, but theie recipe is hush-hush so no telling what is in there. Anyone know??
MarkRx is offline   Reply With Quote
Old 04-04-2007, 04:00 PM   #2
Member#: 67
1999 Outlasting
the competition.
just about anything will work fine. just make sure you use a good amount or you will get a stiff shift
Old 04-04-2007, 04:36 PM   #3
rkramer
Member#: 118209
2015 WRX Limitec
white lithium grease... it really doesn't make that big of a difference!
Old 04-04-2007, 04:52 PM   #4
MarkRx
Member#: 42242
2006 STI
The sulfur found in most EP greases (common at your local parts store) will eat away the nylon. molybdenum disulfide will greatly delay this process.
Old 04-04-2007, 05:07 PM   #5
Member#: 67
1999 Outlasting
the competition.
true but you wont keep the car for 100 years.
tom
Which shifter do you run and does your shift selector seal leak? DS1 Transmission (AT/MT) & Driveline 22 07-31-2008 02:11 AM
Which shifter bushings should I go with? xlr8onu Transmission (AT/MT) & Driveline 11 09-28-2005 10:50 AM
Which shifter will work KEVINL Transmission (AT/MT) & Driveline 0 02-23-2003 07:30 PM
What kind of grease for shifter? scoop Transmission (AT/MT) & Driveline 7 03-28-2002 01:31 PM
Which Shifter? oldguy General Forum Archive 7 10-05-2000 07:14 AM
