Welcome to the North American Subaru Impreza Owners Club Sunday May 24, 2015
Old 04-05-2007, 11:29 PM   #1
wrichiex_sti
Member#: 36349
2003 wrx
wrblue
Default Help!!! My Alternator is not charging.
I don't know what else to do. Here's the deal. I have an 03 WRX. I installed an Avic D3 over the weekend. It was working fine but then my car died. At first I was thinking I need a new battery so I got one. The end of that day, my car died again. No power. So I assumed it was an alternator problem. Tested it and sure enough it was reading around 11.93 on the voltmeter. So I bought a new alternator. Installed it and went off to my day. A couple hours later, my car's electricity was flickering so I turned my car off. I tested it with the VM and same reading 11 ish. I took it off and took the new alternator and old one back to pepboys and had them test both. Both worked perfectly fine. I thought maybe I wired the D3 incorrectly So I took the unit out and the harness off and started the car. Reading is still 11 ish. What else should I look for? Please help someone.
wrichiex_sti is offline   Reply With Quote
Old 04-06-2007, 10:05 AM   #2
wrichiex_sti
Member#: 36349
2003 wrx
wrblue
Anybody? Please?
Old 04-06-2007, 08:54 PM   #3
caterpill
Member#: 27136
Look for a blown fuse to the ignition signal wire going to the alternator. If the alternator was checked out, and it's fine, the problem is the car.
Check for good power, good grounds. If both check out, the alternator is not charging because the alternator needs power to energize the magnetic field when you turn the ignition on, before the engine is started. If the alternator does not energize first, it will not produce current no matter how fast you spin it.
caterpill is offline   Reply With Quote
Old 04-07-2007, 10:13 AM   #4
wrichiex_sti
Member#: 36349
2003 wrx
wrblue
Thanks man. Figured out the problem. Basically, when I tapped into the VSS wire behind the intrument cluster, I didn't plug one of the plugs in all the way. I guess the alternator needs to read voltage and when the plug wasn't plugged in, it wasn't reading anything so it wasn't working. Now I get 14+ on the voltmeter. Such a stupid mistake that caused me so much headache
Old 04-07-2007, 11:52 AM   #5
caterpill
Member#: 27136
Good to know it all went well.
Help my V1 is not working. down_for_the_scooby AccessPort 3 08-08-2009 02:27 AM
So I was googling to figure out why my freezer is cold but my fridge is not.... Ripper Off-Topic 13 11-28-2007 02:57 PM
Help ! Why my car is NOT lowered after installing STI pink ? andivic Brakes, Steering & Suspension 18 01-21-2007 10:45 PM
Help... my cellphone is not working! WRXVII Off-Topic 9 11-04-2003 02:04 PM
How to check if my alternator is working ? NicEJ25 Electrical & Lighting 2 05-25-2003 01:54 PM
