Welcome to the North American Subaru Impreza Owners Club Friday September 4, 2015
Old 04-06-2007, 01:05 AM   #1
TURBOCURT
Member#: 118504
02 Rhd bugi
2010 forester xt
Default radio wont turn off after turbo timer installed
i installed the blitz turbo timer in my 02wrx.. everything works but when i turn the car off the radio stays on after the car shuts off.. its an 06 radio and it worked fine before i did this... thanks for the help
TURBOCURT is offline   Reply With Quote
Old 04-06-2007, 01:12 AM   #2
t4nk
Member#: 129905
2005 WRB WRX
2003 F-350SD, 7.3PSD
how did you wire the TT?
t4nk is offline   Reply With Quote
Old 04-06-2007, 01:57 AM   #3
TURBOCURT
Member#: 118504
02 Rhd bugi
2010 forester xt
out of the tt is green, red, blue, and black... i pluged it into the wire harnis under the dash that is black,red, and brown.. green-black...red-red...blue-brown...black-ground... i just unpluged the red wire and the radio shut off?? do i not need the red wire???
Old 04-06-2007, 03:20 AM   #4
t4nk
Member#: 129905
2005 WRB WRX
typically red is power, black is ground.. ima have to look up the blue and green.
if anyone knows the blitz tt wiring offhand please chime in, im a apexi user here...
Old 04-06-2007, 03:27 AM   #5
t4nk
Member#: 129905
2005 WRB WRX
with the blitz tt you only need the 12v and the ignition to be tapped.. im still looking up the right colors
Old 04-06-2007, 03:35 AM   #6
t4nk
Member#: 129905
2005 WRB WRX
Red --- 12 Volt
Blue --- Accessory
Green --- Ign. "on"
Black --- 12v- Ground
dunno if this will help.. ill get a friend to log on if he's still up, he's installed a couple.
Old 04-06-2007, 12:08 PM   #7
TURBOCURT
Member#: 118504
02 Rhd bugi
2010 forester xt
Cool thanks.. I think its working right but the red wire isnt hooked up.. So i guess ill just leave it off unless someone thinks i need it???
HVAC Fan wont turn on after gauge install HighAspirations Electrical & Lighting 14 07-28-2008 05:52 PM
Passenger headlight turns off after CAI install khizzle Newbies & FAQs 3 07-13-2008 05:15 PM
Radio sometimes turns off when I turn off engine dauss Newbies & FAQs 3 04-06-2007 12:07 AM
Buzzing after turbo timer install..... irishink Electrical & Lighting 1 10-02-2006 07:42 PM
fuel pump wont turn on after motor install. oldbluwrx Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 07-15-2005 11:01 AM
