Old 04-06-2007, 02:01 PM   #1
omdwrx508
Member#: 125108
Default EDM headlight grounding HELP?!
so i junked the ebay lights and got some EDMs for my bugeye. the previous owner hacked one harness off the right headlight to get the ebay ones.. i rewired it with no problem. on the left headlight i was able to use the harness adapter the headlights came with. bot bulbs have burned out in the left side. i redid the wiring to the harness adapter, and put in new bulbs. still no left low beam and the right high beam is incredibly dim. can i just take the grounds and screw them to the cars frame? otherwise i guess i could hack off the harness like was done on the right by previous owner. thanks
omdwrx508 is offline   Reply With Quote
Old 04-06-2007, 05:08 PM   #2
omdwrx508
Member#: 125108
afternoon bump for a reply
Old 04-07-2007, 02:52 PM   #3
BlkTS02
Member#: 50142
2002 2.5TS
MBP
Sure, you could ground them to the chassis, but then the lights will stay on when the car is turned off due to our cars having a switched ground.
Try it, if it works cool. If you don't like it, try something else.
BlkTS02 is offline   Reply With Quote
Old 04-08-2007, 01:40 PM   #4
pinkrobe
Member#: 55447
2002 WRX wgn/'10 STI
WRB/grey
I used relays for my EDMs and grounded directly to the chassis. Works like a charm! Check out http://forums.nasioc.com/forums/showthread.php?t=694380 for instructions.
pinkrobe is offline   Reply With Quote
WTB: Bugeye EDM Headlights or Retrofit Headlights cjx17 Private 'Wanted' Classifieds 0 12-05-2009 01:09 PM
JDM headlight leveling switch for EDM headlights? gling Electrical & Lighting 3 07-16-2009 02:17 PM
EDM Headlights vs. JDM Headlights masterpickle Interior & Exterior Modification 24 05-24-2007 02:53 AM
Question about mixing a JDM and EDM headlight (jdm left side edm right side datdudedennis Electrical & Lighting 5 07-22-2004 11:15 AM
One JDM headlight and one EDM headlight GoRacerXGo Interior & Exterior Modification 11 09-19-2003 09:10 AM
