Mid Atlantic Impreza Club
Old 04-06-2007, 03:40 PM   #1
jamapor
Member#: 111694
2002 Bugeye clan
Suspension is next...
Default An oil question...
I've only had my car for 3 months now, but I've used Mobil 1 Synthetic every time.
I need an oil change now, and Annapolis Subaru is having a special on Castrol Synthetic ($34.95 with new filter)
Do I spend the $66.95 for the Mobil 1 Synthetic?
(Yes I could do this myself, but I really don't have the time)
jamapor is offline   Reply With Quote
Old 04-06-2007, 03:50 PM   #2
big16gwrx
Member#: 129459
0000 Built gt3076
neither.... buy some royal purple!
big16gwrx is offline   Reply With Quote
Old 04-06-2007, 03:53 PM   #3
Seeing StaRS
Member#: 5294
Motul FTW
(Annapolis carries it too. Hit up Jackie)
Seeing StaRS is offline   Reply With Quote
Old 04-06-2007, 04:25 PM   #4
jamapor
Member#: 111694
2002 Bugeye clan
Originally Posted by Seeing StaRS View Post
Motul FTW
Any idea a price on this?
Old 04-06-2007, 04:25 PM   #5
AllAWD
Member#: 17079
2001 SV650
Switch to Motul 8100 X-cess 5w-40, about $40 for 5L jug. Andrewtech stocks it, not as far as Annapolis.
Mobil 1 is not so great in the WRX engine. 5w-30 is too thin.
AllAWD is offline   Reply With Quote
Old 04-06-2007, 04:56 PM   #6
kcook
Member#: 78074
2005 STi
i use castrol 5w-30 fully synthetic ... thats also what my dealer uses on all the subys
i was told to stay away from mobile 1
kcook is offline   Reply With Quote
Old 04-06-2007, 05:01 PM   #7
KanosWRX
Member#: 17904
010 STI
I've always used mobil 1 for the last 5 years, never had a problem with it in my subaru's. You can pick up a 5 liter bottle at walmart for around 30-35 bucks, 5 bucks for a filter and your done.
KanosWRX is offline   Reply With Quote
Old 04-06-2007, 05:10 PM   #8
AllAWD
Member#: 17079
2001 SV650
I burned a quart every 3000 miles using Mobile 1 5w-30 in my WRX. Every other car in my family has used Mobil 1 with no problems. It depends on driving style also.
If you review oil analysis results you will see that Mobile 1 is quickly sheared to a 20 wt oil. It is designed to be very thin for fuel economy.
I switched to Motul at the advice of Andrew. He rebuilds Subaru engines daily and I trust his advice.
Old 04-06-2007, 05:16 PM   #9
WRX Shenanigans
Member#: 101378
2011 Sonata
Harbor Gray Metallic
I've used castrol non-synthetic 5w-30 since day one and it has never burned a drop ::knocks on wood::
WRX Shenanigans is offline   Reply With Quote
Old 04-06-2007, 05:48 PM   #10
UrbonWRX
Member#: 71382
0407 WRX/C6 Vette
WR Blue and Vel. Yellow
I would like to know who told you that?! I wouldn't put anything other than Mobil 1 in my vehicles.
UrbonWRX is offline   Reply With Quote
Old 04-06-2007, 06:57 PM   #11
vet
Member#: 42194
05 LGT Wagon
GRP, sold 98 2.5rs Acadia
I wouldn't say Mobil 1 is bad but it's definitely not all that. I'm using Castrol Syntec 0w-30 (GC). It made my engine run noticeably smoother. Great things are said about it over on bobistheoilguy.com
vet is offline   Reply With Quote
Old 04-06-2007, 07:11 PM   #12
kts262
Member#: 45464
91 E30 325i
95 E36 325is
I had A LOT of oil consumption with Mobil 1 as have a lot of other STi drivers on IWSTI.com. (~250 miles/quart)
I'm currently using Motul 8100 5w30 and my consumption has dropped significantly. (~2/3rd qt per 1k miles so far) I will probably switch to Motul 5w40 to see if the thicker oil helps reduce the consumption even more, once I get it under control I might try the German Castrol which has been popular with a lot of Subaru people.
kts262 is offline   Reply With Quote
Old 04-06-2007, 07:56 PM   #13
siopao2000
Member#: 63247
1993 corolla
I've used the following:
Havoline 5w30 - first 10,000 miles with no oil consumption even with a couple autox's. Reading on Bitog, this seems to be a well liked oil.
German Castrol 0w30 - I've read good things about this oil but there are a few that still see problems while using it. I haven't had any problems at all. It's also closer to 5w40 according to the tests. Started using this oil after 10,000 miles and now have 29,000.
Mobil 1 5w30 - Didn't have any problems with m1 but I only used to for 4k miles. No oil consumption at all. This was during winter though with little to no hard driving. (Actually I had an autox class while using m1 and no consumption)
The best way to find out if the oil is really working for you is to get an oil analysis. There are many threads about it in the "Service and Maintenance" section of the boards.
http://www.bobistheoilguy.com/ is also a good place to read about oils.
siopao2000 is offline   Reply With Quote
Old 04-06-2007, 07:59 PM   #14
ButtDyno
Street's closed, pizza boy
Member#: 17301
is the "dark side"
06 Evo #7 STU, 05 Saabaru
I've done M1 5w30 and gotten good oil analyses even with extended changes but never noticed it burning oil. Now you guys have me all paranoid
*runs to check engine*
ButtDyno is offline   Reply With Quote
Old 04-06-2007, 08:03 PM   #15
siopao2000
Member#: 63247
1993 corolla
I remember reading one of your oil analysis. I think it said even after 5k miles, 10 autox's, and 2 track days the oil was still good.
I'm sticking with the German Castrol since I'm affraid of M1. Andrew did advise me on using a higher weight because of piston slap or something. I don't remember. I'll ask him next time I go to their shop.
Old 04-06-2007, 08:41 PM   #16
BryanH
Member#: 993
I used to go through a quart every 500 miles in my 03 WRX on Mobil1...I switched to Castrol Syntech and consumption dropped to a quart every 2000 miles.
BryanH is offline   Reply With Quote
Old 04-06-2007, 10:45 PM   #17
SubieDugie
Member#: 119219
2005 STi
WR Blue
I have used Castrol, Mobile1, Royal Purple, and AMSoil. After 2-3000 miles on anything other than Royal Purple, I can't get a good reading on the dip stick. I switched from R.P. a couple of oil changes back because it was cheaper, and I wanted to see how it would work out in my motor. Instantly I noticed oil temp was running higher than w/ R.P., and at about 5000 miles on the the AMSoil I couldn't read the oil on the dip stick. When I had the oil changed, it didn't look too bad, and still felt pretty slippery. I am back with Royal Purple and happier with my oil temp. If it does get up to the temp that the AMSoil would be at, it is much quicker to cool down; water temp appears to be a little cooler as well. I found a guy in PA on Ebay selling Royal Purple 5w30 cases for just over $76. I received my case within 4 days of payment. You can buy 6, case, 5 gals. in various viscosities.
SubieDugie is offline   Reply With Quote
Old 04-07-2007, 12:34 AM   #18
kts262
Member#: 45464
91 E30 325i
95 E36 325is
If youre UOAs look good and it's not consuming oil you're fine. Some people have had great success with M1 in their Subies, others haven't. I was one of the unlucky people who didn't have good luck with it.
Their 5w30 did give me less consumption then their 10w30 did. I thought the 10w30 would be thicker but M1's 10w30 is actually thinner in most temperature ranges compared to their 5w30.
Gotta love all the info BITOG can provide.
Old 04-07-2007, 03:28 AM   #19
psyber_0ptix
Member#: 60671
1991 e30 318i
s50b30us swapped SOLD!
i didnt have any luck with mobil 1. Royal purple wasnt that much better for me either, but i did have great luck with amsoil.
there are different formulations, but i think i ran the ASL 5w-30
psyber_0ptix is offline   Reply With Quote
Old 04-07-2007, 04:39 AM   #20
4x4STi
Member#: 144412
2004 STi
Aspen White Cobb Stage 2
mobil one always winter 5w30 summer 10w30
car 04 sti 66,000 miles . oil changes done every 5k to 6k , with out any extra oil needed
4x4STi is offline   Reply With Quote
Old 04-07-2007, 07:04 AM   #21
drrice
Member#: 82595
let me see ur feetz
amsoil
drrice is offline   Reply With Quote
Old 04-07-2007, 07:14 AM   #22
jamminj6693
Member#: 94993
05 STI Agile Tuned
Mobil One works, stick with it!
I use it and i reckomend it to all my Subaru Customers.
jamminj6693 is offline   Reply With Quote
Old 04-07-2007, 12:56 PM   #23
SubieDugie
Member#: 119219
2005 STi
WR Blue
Anyone know where I can get an oil analysis done? I am thinking about trying to have it done at AIMD oil analysis lab on Norfolk base. If I can smooth talk someone; maybe a six pack or 2 of brew will get it done.
Have any of you guys using AMSoil noticed oil temps rise with it? Even going from FL to VA it didn't really any cooler. As far as Castrol, it seems to do a really good job of cleaning and capturing to dirt; I believe that is why it came out of my car so dark. But, I think over all, as long as you are keeping an eye on your oil and changing it within 7500 miles, you are good. I just don't like how I can't get a good read on my oil with the STi's turbo. Anyone know where I can get a Crawford air oil separator?
Old 04-07-2007, 01:09 PM   #24
kts262
Member#: 45464
91 E30 325i
95 E36 325is
http://blackstone-labs.com/ is where I've been getting my UOA from.
Old 04-07-2007, 03:54 PM   #25
24
Member#: 39142
Memb er#: 39142
I have a bridge for sale, anyone interested?
24 is offline   Reply With Quote
Three questions. One about an oil pan, one about fuel, and one about intake manifold Cyclops Built Motor Discussion 19 12-25-2008 05:30 PM
Quick Question about fitting an Oil Temp. Sensor nxwrxfx Factory 2.0L Turbo Powertrain 1 05-11-2006 12:41 PM
Question about getting an oil cooler SubyNewbie Mid Atlantic Impreza Club -- MAIC 5 10-04-2002 01:00 PM
How many quarts of oil for an oil change? codemunky Service & Maintenance 9 07-30-2002 06:35 PM
An oil question... ImprezaRS2000 General Forum Archive 2 05-22-2000 09:50 AM
Message Board Statistics All times are GMT -4. The time now is 10:42 PM.
