Welcome to the North American Subaru Impreza Owners Club Tuesday March 3, 2015
Old 12-11-2001, 06:09 PM   #1
GregBolby
Member#: 498
1981 jdm swapped gc
sniklfritz
Default Took the sube off road now at 45 there is a bad shaking of the car!
just took the sube into the mud, hit a few hard spots but nothing bad....well the wheels had alot and i mean alot of mud in them...so leaving the place i pull out onto the highway. 10-20-30-40 ah ohhhh when she got to 45 it was wobbling very badly felt like it was coming from the rear because the steering was shaking a little not to bad but the body was shaking pretty harsh
i think if i had a bent ANYTHING it would wobble at low speeds, i am thinking that the balance on on or more of the rear wheels is off? the little balance weights may have come of or something? anyway any advice will help, i did a visual of all 4 wheels and no bends anyway thats what happend and im bumed out right now
thanks
Greg
GregBolby is offline   Reply With Quote
Old 12-11-2001, 06:17 PM   #2
Keith99RS
Member#: 9243
05 Nissan Titan
06 B9 (hers)
Wash out your wheels, there may be mud trapped behind then throwing off yhe balance. If that doesn't work, check for missng wheel weights or loose lug nuts. If that doesn't fix things, I'd take it to get looked at.
Keith99RS is offline   Reply With Quote
Old 12-11-2001, 06:21 PM   #3
FastPorsche
Member#: 11125
2000 Impreza 2.5 RS
Silverthorne
This same thing has been know to happen when spirited driving is done in the snow. assuming that you bent nothing First thing to do is make sure you wash all the mud out of the wheels. You may even want to take them off to do this. Try the car now. If it still shakes as you described. Get more invloved Check for more mud on any thing that rotates. This is the most likely problem and most inexpensive to correct. let us know what happens there are more thing to do but this is where to start
FastPorsche is offline   Reply With Quote
Old 12-11-2001, 07:22 PM   #4
GregBolby
Member#: 498
1981 jdm swapped gc
sniklfritz
ok sprayed all of the mud out shaking was at 45 now at 55
so i think its the damn weights
sucks
a $.05 weight fell off and its prob gona cot like 40 to get it balanced again blahhhhhhhhhhh
Old 12-11-2001, 07:44 PM   #5
kensington
Member#: 9113
2k4 WRB STi
RIP#92 Fred"G-Money"Zippy
Go back to the high pressure wash and do it again, spend a couple of bucks this time. The first time this happened to me it scared the sh** outta me. I coulda swore i was screwed. Even the smallest amount of mud back there will hose you, get it all. And when you think you got it all do it again. Taking them off is a very good idea if you can do it, if not I stuck the tip of the power washer right into the wheel to wash it out.
kensington is offline   Reply With Quote
Old 12-11-2001, 07:59 PM   #6
8Complex
Member#: 922
04 FXT
Red
Yeah, probably still mud, maybe behind one of the spokes or something in the wheel.
BTW, you can get a wheel balanced for like $10, if that. I was in nowhere-ville Nebraska and lost a weight on their crappy roads (I-80 at that... geez) and had to have it rebalanced at a truck place. Took 15 minutes and cost me like $12. *shrug*
Old 12-11-2001, 08:19 PM   #7
porky
Member#: 9413
2002 OBS
white sans cheesy sticker
Another vote for "wash the hell out of it." Same thing happened to me. Definitely a scary feeling.
porky is offline   Reply With Quote
Old 12-11-2001, 11:31 PM   #8
motorob
Member#: 2878
06 Evo IX MR
You still have mud in the wheels. You may need to take them off the car to get it all out, or just crawl under in old clothes and plan on getting *really* dirty.
motorob is offline   Reply With Quote
Old 12-11-2001, 11:56 PM   #9
andyC
Member#: 1607
2002 Silver
double you are ecks wagon
wash wash wash!!!
and then wash again!
andyC is offline   Reply With Quote
Old 12-12-2001, 01:08 AM   #10
HIHO
Member#: 7624
BD5; family sedan
that just wooped your ass
$40 bucks to balance the wheel! I can get all four balanced for that price. I think you might be mistaken on the price. It is common for your wheels the get out of balance. You should have them balanced at least every 5k miles. A wheel out of balance is no big deal.
HIHO is offline   Reply With Quote
Old 12-12-2001, 01:43 AM   #11
GregBolby
Member#: 498
1981 jdm swapped gc
sniklfritz
my fault
i meant all 4
hopefully its just one wheel
thanks
for all the info guys
i got an apointment for 10am
so hopefully it will be fixed
Old 12-12-2001, 02:08 AM   #12
Steve-oWRX
Member#: 8495
good luck with that man...hopefully this experience doesn't discourage you from offroading again!!
Steve-oWRX is offline   Reply With Quote
Old 12-12-2001, 02:34 AM   #13
imp2.5
Member#: 11354
2009 LGT
BF3 tag: Snbrd4evr
The exact thing happened to me up here in Ashland, we have all these forest trails for the hunters and I decided to follow my friend and he went through some pretty deep mud. Well, My car started shaking at 50 but then let off some at 75 so I didn't know what was up. I took my car to the shop and the guy looked at it and just put his fingers in there and rubbed off a good 1/2 inch of sandish mud that was caked inside the wheel. I even looked at it to see if that was what it was but I couldn't see it. You just need to feel inside there but be careful of the brakes because I cut my hand a few times trying to get in there. Well, stupid me, good luck and I would also suggest a brush of some sort, maybe one of those snow brushes for your windshield. That should work, have fun in the mud.
imp2.5
imp2.5 is offline   Reply With Quote
Old 12-12-2001, 02:44 AM   #14
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
'09 Concours 14 ABS Black
wash your wheels first...still there then you bent a rim or seperated a belt in the tire.
jeremy
Old 12-12-2001, 02:50 AM   #15
AnimalMother
Member#: 11835
2004 Honda Pilot
Dark Blue
Cool
gotta be mud dude...haven't you ever seen "My Cousin Vinny"?
good luck getting it fixed!
AnimalMother is offline   Reply With Quote
Old 12-12-2001, 01:31 PM   #16
GregBolby
Member#: 498
1981 jdm swapped gc
sniklfritz
found the problem,,,,sprayed the wheels last night then check this morning low and behold more mud still in there so i took a brush and scraped it out then went for a ride WOOOOHOOOOO
back to normal
thanks for all the help guys
late
G
Old 12-12-2001, 02:19 PM   #17
remarcable
Member#: 2362
1999 Legacy Outback
Blue w/ Paint Chips & Mud
I usually take my rhino ramps with me to the car wash after driving around offroad, if there was lots of mud.
Sure people look at me a bit funny, but I get the underside of the car and wheels clean. Don't forget to check above the heatshields and differentials for packed-in mud above them. If it stays there too long it could cause heat problems.
remarcable is offline   Reply With Quote
Hey Bro- let's take the Jeep off-roading at the skatepark! subenerd Off-Topic 62 10-18-2009 10:54 PM
There is a new Lord of the Nerds. aod Off-Topic 10 08-21-2007 02:09 PM
there is a giant lugie on the side of my car. alacrity024 Off-Topic 9 12-08-2004 12:19 PM
wanna get your sube off road? dirty? muddy???? ldivinag Bay Area Impreza Club Forum -- BAIC 4 02-26-2004 06:24 AM
Took the wagon off road at lunch!! :-) FreeBMW Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 8 10-15-2001 11:28 PM
