Welcome to the North American Subaru Impreza Owners Club Sunday December 11, 2016
Old 04-07-2007, 12:09 AM   #1
rufracer
Member#: 44490
Default wrx fuel pump in 98 impreza L?
Will a wrx fuel pump fit in my 98 impreza L 2.2? Nine is bad and wrx fuel pumps a plentifull and cheap.
rufracer is offline   Reply With Quote
Old 04-07-2007, 02:06 AM   #2
rallifan
Member#: 132786
2001 Impreza TS
Artic Silver Metallic
Default mmm
you should call a dealer or go to a favorite parts place and physically look at the two. or if you have a good junk yard pull the two and look at them and take home the WRX pump if a match!
rallifan is offline   Reply With Quote
Old 04-07-2007, 02:09 AM   #3
Kostamojen
Member#: 2272
2016 Commodore SS
Heron White
Someone asked this question not to long ago, and here is the thread about it:
http://forums.nasioc.com/forums/show...ight=fuel+pump
Old 04-07-2007, 01:57 PM   #4
Storm
Member#: 5218
96L Most Over-
Developed Beater
I just replied over in that other thread. Basically, as long as the pump doesn't increase the flow so much that the fuel pressure regulator can't control it....it won't hurt anything. In fact, it'll give a stronger blast of return fuel into the pickup area...which might keep you from fuel starving. Just don't do this and think that you'll be making any more HP. The FPR is still going to keep the pressure at the injectors the same.....
You will have to splice the power wires...but it can be done with butt connectors. Get the plug that goes into the pump, your stock pump might have terminal lugs instead of the plug.
Jay Storm
Old 04-08-2007, 12:48 AM   #5
rufracer
Member#: 44490
sweat, thanks everybody. I already found one for 20 bucks.
Old 04-08-2007, 02:11 AM   #6
mxpunk
Member#: 132130
2002 Ford F-150
Graphite Gray
should bolt up
mxpunk is offline   Reply With Quote
Old 04-08-2007, 01:59 PM   #7
Storm
Member#: 5218
96L Most Over-
Developed Beater
Run a length of tube from the return and aim it at the pickup sock. You'll be amazed at how low on fuel you'll be able to go before starving...I ziptied it to the jetpump and the main pump.
Make a surgebox out of a 32oz RC plane fueltank and ziptie it to the whole assembly.....100x cheaper than an STi pump assembly and nearly as effective. A couple small holes to keep it full is all you'll need.
Jay Storm
wrx fuel pump in 99rs??? beaun-nus Subaru Conversions 7 06-12-2007 08:39 PM
2002 wrx fuel pump in gc8? billyr2.5 Normally Aspirated Powertrain 10 01-22-2006 12:40 PM
Variable WRX fuel pump vs basic Impreza pump? bryan_johnson Subaru Conversions 13 01-31-2005 11:24 AM
WRX fuel pump in 98 RS? IllNastyImpreza Normally Aspirated with bolt-on Forced Induction Powertrain 4 05-30-2004 11:56 AM
WRX Fuel pump into 98 RS ilmaestro Normally Aspirated with bolt-on Forced Induction Powertrain 4 03-03-2004 08:33 AM
