Old 04-07-2007, 05:28 PM   #1
Highway Drifter
Member#: 81013
Default Car keeps dying anyone have suggestions?
Hey guys, someone attempted to steal my car a couple of weeks ago and while i got all the parts together to fix it (fender, fender lining, front bumper, sideskirt) I had it sit there...Well while it sat there, I didnt start it at all. So yesterday I goto start the car, realize its dead...jump it, starts up runs, no problem...figure I let the alternator recharge the battery, move the car out of its spot...park it, put the alarm no problem...about 1/2 hour later, check on it, starts up no problem...an hour later its dead. I looked under the driver side fender to see if there was any frayed wiring from when the autolock tore thru the lining but nothing obvious that I can see. I'm thinking about just replacing the battery and see if its that, but does anyone have any other suggestions that they have that it could be? Oh and another weird thing is that my radio doesn't turn on...for ANYTHING. No volume, not even as much as static out of the speakers...could it be some type of ground that came loose? Thanks for the help guys.
Highway Drifter is offline   Reply With Quote
Old 04-08-2007, 01:32 PM   #2
Highway Drifter
Member#: 81013
bummmmmp
Old 04-09-2007, 10:48 AM   #3
12sechatch
Member#: 132458
Okie Dokie Fine
i would say first off, check your radio fuse. its obvious i know but that is more often then not the problem. as for starting issue, it sounds like a dead battery to me. good luck
12sechatch is offline   Reply With Quote
Old 04-10-2007, 08:32 PM   #4
michael_wrx
Member#: 130041
2004 WRX
Java Black
You might try giving your battery a full charge from a real battery charger. If the battery was significantly drained it could take a long time for the alternator to give it a good charge. If it still gives you trouble, make sure your battery terminals are clean as well.
michael_wrx is offline   Reply With Quote
Car keeps dying when I come to a stop. speed_freak27 Normally Aspirated with bolt-on Forced Induction Powertrain 9 03-04-2005 04:05 AM
Greddy Type-s BOV...My car keeps dying??? WRX8U82 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 11 05-06-2004 09:25 AM
My car keeps dying MattDell Mid Atlantic Impreza Club -- MAIC 9 12-03-2002 09:37 PM
My car keeps dying MattDell Normally Aspirated Powertrain 2 12-01-2002 12:34 AM
Ok, my car keeps dying on me...what's up? Sauginius Southern California Impreza Club Forum -- SCIC 6 11-07-2000 12:01 AM
