Old 04-09-2007, 03:07 AM   #1
hella_sti
Member#: 139289
2003 WRX Wagon
Default Do I really need an EGT and oil pressure gauge?
I'm looking at buying a maddad v2 or prosport boost gauge (with a warning light(do I need that?)) along with the subiegal gauge pod. The thing is that if I buy this set up I won't upgrade to a three pod set up to gain the oil pressure and egt temp gauges, and do I really need those two anyways? I don't auto-x or track my car and am running cobb stage 2 base map. The sube gal pod and boost gauge will run around $150 and the three gauges plus the ATi pod will run upwards of $350, do I really need all that information?! I'm a college student on a budget and a pretty fixed income so keep that in mind
hella_sti is offline   Reply With Quote
Old 04-09-2007, 03:09 AM   #2
iamchris
Member#: 106479
2005 9-2X Aero
Fluorescent Brown
Keep in mind that the cars do not come stock with them, so no.
iamchris is offline   Reply With Quote
Old 04-09-2007, 03:14 AM   #3
hella_sti
Member#: 139289
2003 WRX Wagon
I realize that, but what I'm mainly asking is if the cost to benifit ratio is greater with one option than the other.
Old 04-09-2007, 09:00 AM   #4
rkramer
Member#: 118209
2015 WRX Limitec
oil pressure would be the first to drop. By the time you get to too low of oil pressure, the damage is done. EGT is nice, it can tell you about any problems in your tune or issues with the OTS map if you are running one. But again, certainly not needed.
Old 04-09-2007, 12:18 PM   #5
ekw
Member#: 92141
2004 STi-WRB on gold
Street prepped by TiC !
if you run the boost gauge on the dash in the Subie Gal pod,
you could run two other gauges in the Autometer twin bezel.
they are cheaper than most of the triple gauge pods that go in the dash clock spot.
and much stealthier too.
but you do not 'need' additional gauges if you are not planning any further mods.
you probably don't even 'need' the boost gauge.
but they are all nice to have.
ekw is offline   Reply With Quote
Old 04-09-2007, 12:22 PM   #6
epson1
Member#: 122909
2003 Evo 8
Apex Silver
yea a boost gauge isn't even needed....
epson1 is offline   Reply With Quote
Old 04-09-2007, 01:29 PM   #7
rkramer
Member#: 118209
2015 WRX Limitec
for someone running stage 2, i think a boost gauge is virtually a requirement. it is easy to get boost spikes when you start removing cats.
Old 04-09-2007, 05:54 PM   #8
texas05sti
Member#: 126242
2005 STi/2012 GTR
TXIC's most loved
It all depends on what kind of modifications you have done/are going to do to your car. If you are going to run higher-than-stock boost, then you need a boost gauge. If you are going to run aggressive timing, then you need an egt, wideband, or both. Oil temp is very important if you race for long distances, oil pressure is important if you race with lots of turns. You can fill up your entire cockpit with gauges, but they are only necessary/unnecessary depending on how much you will use them.
I personally have boost and wb02 gauges, but I monitor most everything else with my laptop when I am tuning/racing. I need to get an EGT gauge as well, but haven't found a gauge pod setup that I like.
texas05sti is offline   Reply With Quote
Old 04-09-2007, 09:01 PM   #9
02BlueSuperRoo
Member#: 78290
2011 WRX 5-door
SSM
Is his motor stock?
It can also tell you if are low on oil (before the oil light will tell you)
It will tell you if your pump is going out or is clogged
It can definitely save your motor if you monitor it closely
neither is a turbo
Good advice
02BlueSuperRoo is offline   Reply With Quote
Old 04-09-2007, 09:20 PM   #10
wrxzboost
Member#: 86322
base stage 2...not necessary. reflash and aftermarket exhaust isn't that far off from stock. save your money and interior from looking like a rice burner.
wrxzboost is offline   Reply With Quote
Old 04-09-2007, 09:24 PM   #11
fastwrx25
Member#: 126441
03 bugeye
just start yourself up with one boost gauge first. You don't even need a pod, you can just mount it up to your steering column using something like a greddy band gauge holder that looks like this. It costs like 5 bucks
if you feel you need or want more gauges later then you can do so.....
if you are on a budget consider buying some used gauge setups. Good cheap deals for quality parts pop up everyday in the classifieds.
fastwrx25 is offline   Reply With Quote
Old 04-09-2007, 09:49 PM   #12
veightkiller
Member#: 78967
2011 335i
it's always nice to have one.
veightkiller is offline   Reply With Quote
Old 04-09-2007, 10:18 PM   #13
BoostinEJ20
Member#: 73710
i have 2 greddy 52mm gauge holders (pictured above) that ill sell ya one cheap!
BoostinEJ20 is offline   Reply With Quote
FS -Chicago- BNIB Omori 60mm. Boost, EGT, and Oil Pressure Gauges KenSekiguchi Interior/Dressup/Audio & Security 25 10-22-2008 05:01 PM
WTB QUICKLY!: 52mm EGT and Oil Pressure gauge Clark Kent Private 'Wanted' Classifieds 1 03-16-2007 04:01 PM
NJ: Greddy 52mm EGT and Oil pressure gauges, Like new. Cosworth Private 'For Sale' Classifieds 19 09-06-2005 10:13 AM
WTB: Defi D-series EGT and Oil Pressure gauges STibiotch Private 'Wanted' Classifieds 2 12-17-2004 09:40 AM
Do I really need a EGT gauge? Steven Saunders Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 07-26-2002 08:32 AM
