Old 12-12-2001, 01:45 AM   #1
ANZAC_1915
Member#: 456
2008 Forester XT
Steel Gray Metallic
Default WRX US OEM vs STi/SPT sedan spring rates ... again
Here are my latest wild assed guesses:
OK, the actual FHI specs for the SPT/STi kit is:
38 N/mm F
33.4 N/mm R
(source: SOA, though they quoted N/m not N/mm).
This looks very close to the relationship between what I'd calced for front and stiffest possible for rear (lower coils bound).
That gives us for STi/SPT:
217 lbf/in F
190 lbf/in R
If you then take my prior comparisons between the springs -> 27% stiffer at front, and 107% stiffer at back (stiffest) and work backwards, then you get:
US WRX sedan:
169 lbf/in F
92 lbf/in R
Note how soft the rear is compared to the front, compare to either the rates Jamie Drummond measured for the Aussie WRX and the STI rates.
Believeable?
Glenn
ANZAC_1915 is offline   Reply With Quote
Old 12-12-2001, 11:38 AM   #2
tt_ttf
Member#: 4431
MY07 STi and '06 WRX
Urban Grey & WRC Blue
Seems really low value for the rear spring rates (what were they thinking?) but believable given the rear end dance the rear does on throttle lift off in a corner!
Also would explain the huge improvement in lift on your car under acceleration
tt_ttf is offline   Reply With Quote
Old 12-12-2001, 12:12 PM   #3
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
hmmmmm
169 for the front seems really high the 110-120 #s sound better
a differance in the stock spring rates that big would create some intesting handeling
if you use the same 101% gain figure with th front you get ~106 .. which i think is closer
side note:
notice the similarities in the sti/spt spring rates vs the v.5 spring rates (very simmilar) with in ft/lbs
Old 12-12-2001, 09:21 PM   #4
ANZAC_1915
Member#: 456
2008 Forester XT
Steel Gray Metallic
Yeah, but you can't use that cos I didn't measure that as a difference between the two sets of front springs.
DEFINITELY there is a huge spring rate difference between the front and rear OE springs. The rear is very soft.
Glenn
Old 12-13-2001, 03:11 AM   #5
Kostamojen
Member#: 2272
2013 Subaru BRZ
Galaxy Blue
Very interesting... Wonder if someone might try to put a pair of the front springs on the back to compensate? (I know it will screw up the geometry, but it might be worth trying to see)
Old 12-13-2001, 10:40 AM   #6
ANZAC_1915
Member#: 456
2008 Forester XT
Steel Gray Metallic
I seem to recall there are diameter differences at the top (or bottom?)
Glenn
Old 12-13-2001, 12:52 PM   #7
tt_ttf
Member#: 4431
There was a taper in diameter on on one of the springs (think it was rear) plus differences in the rubber. The rears had very substancial boots on the top of the springs plus there was differences in the shock perch.
04 WRX Sedan Spring Rates????? bline Brakes, Steering & Suspension 1 03-29-2005 09:42 PM
WRX Sedan STi/SPT strut/spring set fully assembled with STi strut tops. For Sale! boxerT Texas Impreza Club Forum -- TXIC 4 05-07-2003 12:13 PM
STI, SPT..etc spring rate list maybe? stratos Brakes, Steering & Suspension 7 03-05-2002 07:28 PM
attention adrian!!! need gab spring rates again josh Bay Area Impreza Club Forum -- BAIC 4 08-07-2001 01:26 PM
WRX Wagon Stock vs STi v5 struts/springs svxtrem Brakes, Steering & Suspension 0 06-08-2001 11:01 AM
