Welcome to the North American Subaru Impreza Owners Club Tuesday July 7, 2015
Old 04-09-2007, 10:41 PM   #1
krambte79
Member#: 97452
05 STi, 02 STi
& 09Ltd Tribeca
Default hella supertones install question
when installing the new hella horns can i just hook up to the wire from the old horns and also wire in a ground for each horn...... or is there something more to this? thanks i am not an electrical genius. the horns came w/ a relay and schematics but i know the car (o5 sti) already has a relay.
krambte79 is offline   Reply With Quote
Old 04-09-2007, 11:07 PM   #2
Bayley
Member#: 49763
2004 WRX
Jetzt mit 25% mehr Motor!
You will be fine with the stock wiring. I've run my supertones for two years now and have never had any problems... and I use them A LOT!
Bayley is offline   Reply With Quote
Old 04-09-2007, 11:49 PM   #3
krambte79
Member#: 97452
05 STi, 02 STi
& 09Ltd Tribeca
thanks
Old 04-10-2007, 01:20 AM   #4
pinkrobe
Member#: 55447
2002 WRX wagon
WRB/dirt
There's a full install guide floating around here somewhere. I will say that although the horns work fine with the stock wiring, running a relay produces significantly more volume.
pinkrobe is offline   Reply With Quote
Old 04-10-2007, 01:21 AM   #5
02wrbrex
Member#: 103061
98 Impreza EJ207
350 Zed
Use the relay's provided its really not that hard to install just look up the install guides on here and you will get it. If you do not used the provided relay's then there was no point in buying them.
02wrbrex is offline   Reply With Quote
Old 04-10-2007, 01:56 AM   #6
thrlskr
Member#: 81826
2005 WRX STi WRB
I hooked them up to the stock wiring and ran the ground to the mounting bolt. Don't worry they're plenty loud!
thrlskr is offline   Reply With Quote
Old 04-11-2007, 09:31 PM   #7
krambte79
Member#: 97452
05 STi, 02 STi
& 09Ltd Tribeca
i just used the stock wiring and grounded them, they are loud thanks for the info
guys
------------------------------close thread----------------------------------
Old 04-17-2007, 10:33 AM   #8
absoluturq
Member#: 146421
hey, i have another question about this....
im not a subaru owner, i drive a VW, but way more subarus have supertones, so i cant really ask this to my VW forum....
my question is, yesterday i tried hooking the horns up, and i messed up....smoke came out of my power thingy on the relay...
i dont know why it happened....but it happened....
now i think my relay is done? what can i do? i need the car back to normal by sunday
absoluturq is offline   Reply With Quote
Old 04-17-2007, 11:30 AM   #9
Siper2
Member#: 1134
2007 BMW 328xi wagon
Psst! http://forums.nasioc.com/forums/show....php?t=1133994
absoluturq,
You already posted in that thread, man!
General install instructions: http://www.griotsgarage.com/pdfs/77573.pdf
Siper2 is offline   Reply With Quote
09 wrx hella supertones install question punjabi408 Newbies & FAQs 21 08-23-2010 01:28 PM
Hella Supertones install question thunder_lizard_1976 Electrical & Lighting 5 03-27-2008 11:52 PM
HELP....another hella supertone install question wrxsown Electrical & Lighting 6 07-25-2006 01:44 AM
Hella Supertone Install Question USF97J4x4 Interior & Exterior Modification 9 12-31-2005 10:17 AM
Got question about Hella Supertone installation in a GC8 edkwon Mid West Subaru Owners Club Forum -- MWSOC 17 09-10-2002 01:11 AM
