Old 04-10-2007, 12:24 PM   #1
mummer43
Member#: 113985
2006 Outback Sport
Steel Grey Metallic
Default Audible clicking when I turn on my lights
I just took my headlight bulbs out because there was some condensation inside the housing and after replacing them, there is an audible clicking when I turn my headlights on and when I engage the high beams. I comes from the area of the glove box, and it wasn't there prior.
Any ideas?
Edit: I just did a search and it seems as though this is normal? I never really noticed it before.
mummer43 is offline   Reply With Quote
Old 04-10-2007, 12:31 PM   #2
SoobATV
Member#: 6883
MY04 Foz XS
MY02 Imp TS
Sounds like it's just a relay. You should be safe.
SoobATV is offline   Reply With Quote
Old 04-10-2007, 01:36 PM   #3
shadyrex
Member#: 24540
2015 WRX
That's your headlight relay under the dash.
shadyrex is offline   Reply With Quote
Old 04-10-2007, 06:34 PM   #4
supernootz
Member#: 138869
2007 Impreza Outback
Yeah, man that thing is LOUD. I thought something might be wrong, too.
supernootz is offline   Reply With Quote
Old 04-11-2007, 05:22 PM   #5
mighty_hank
Member#: 42473
2004 WRX Wagon
WR Blue
Default Same here
I also get a noise sometimes when I turn on my headlights. It's a relay clicking sound from behind the glovebox. It also happens when I push my blinker stem to signal lane changes, and causes my headlights to flicker. I can cause the clicking by slowly turning on/off the headlight knob. The phenomenon is intermittent, and only happens for a short time every other month or so. Anyone know of or suspect a root cause?
mighty_hank is offline   Reply With Quote
Old 04-11-2007, 05:26 PM   #6
harrison88
Member#: 127639
06 T REX No Rear
Cupholder :(
i also get this click noise, i'm pretty sure it's just the headlight relay
nothing to worry about
harrison88 is offline   Reply With Quote
Old 04-11-2007, 10:36 PM   #7
Hank3
Member#: 16157
'03 Mazda P5 <><
'02 WRX & '08 MS3 SOLD!!!
It is the relay - no need to worry. It's perfectly normal for the Subarus.
Hank3 is offline   Reply With Quote
Old 04-12-2007, 12:46 PM   #8
mighty_hank
Member#: 42473
2004 WRX Wagon
WR Blue
Well, mine is not so normal. It's triggers the relay like quick machine gun bursts, and the relay switching is visible as my headlights flick on and off. When I change lanes at night and signal with my blinker (pushing down the turn signal stalk also causes the flickering), the car in front of me gets to experience the headlight flashing in their rear view mirror. Again, this only happens for a brief period every couple months, and actually hasn't happened for a long time. The only normal thing about it is it always comes back.
Old 04-12-2007, 11:52 PM   #9
Handsdown
Member#: 29355
i hear two relays go off with my harness. it's loud
Handsdown is offline   Reply With Quote
Old 04-13-2007, 12:30 PM   #10
SoobATV
Member#: 6883
MY04 Foz XS
MY02 Imp TS
You *may* have a bum headlight/signal switch. Happened to me with a few older cars.
Old 04-13-2007, 05:59 PM   #11
mighty_hank
Member#: 42473
2004 WRX Wagon
WR Blue
Yeah, I highly suspect it's the switch b/c when the phenomena is occurring, I can agitate it by slowly turning the headlight knob on and off, so the switch seems to be the trigger. Hasn't happened in a while, so I'm not too bugged out about it. It's got to be the first quality concern I've found with my Subie.
Old 07-21-2007, 02:27 AM   #12
Daggah
Member#: 152077
2002 Integra Type R
Championship White
I'm having this issue as well. Is there an easy fix, or will Subaru fix it under warranty (mine's an '04 with less than 36,000 miles on it.)
Daggah is offline   Reply With Quote
Old 07-21-2007, 05:49 AM   #13
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
If your car is under warranty and the combination switch is bad, it should be covered unless you have modified your lights.
Clicking Noise when I turn on my heater. AK*WRX*2004 Electrical & Lighting 2 03-05-2005 02:45 PM
I smell gas when I turn on my heater DetroitWRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 37 02-13-2004 03:11 AM
Kow how to keep the Instrament Cluster Clock from dimming when I turn on the Lights? Turk Interior & Exterior Modification 3 12-13-2000 05:57 PM
