Old 04-10-2007, 10:14 PM   #1
DieselClown
Member#: 36135
2005 WRX
Default 18x8.5 51 offset SSR COMP..will it fit on an 05 WRX?
with either 225/40/18 or 235/40/18. Any input would be appreciated. Thanks!
DieselClown is offline   Reply With Quote
Old 04-11-2007, 12:16 PM   #2
narenji
Member#: 12727
Its got internal
combustion ftw!
i've got 17x8.5 SSR-c, +48 on my 05 sti (5x114.3), and w/ 255-40-17 tires, there's about 3mm of clearence to the strut. the fender seems fine... w/ a +51, you just can run as wide a tire... you could probably run 235-40-18... i think for 8.5 width, +48 is about the highest id go. you could go +51 if they were 18x8...
narenji is offline   Reply With Quote
Old 04-11-2007, 05:30 PM   #3
DieselClown
Member#: 36135
2005 WRX
THANKS! I originally had 18x8 SSR Comps in 51 offset, but bent two of them, and am looking to replace them with 2 18x8.5 48 offset that I'll throw in the front to clear a BBK. As long as I run the same width tires, they should be good to go I read.
What STi springs will fit on an 05 WRX? ismegamanthere Brakes, Steering & Suspension 4 04-15-2010 02:26 PM
Will 15" steelies fit on an 05 WRX? nicholam Tire & Wheel 4 09-10-2008 06:28 PM
Will this fit on an 07 Wrx??? ETown Newbies & FAQs 3 09-07-2007 09:05 PM
17x8 37off....will it fit on an 03wrx? NVSPRELUDE Tire & Wheel 24 08-09-2007 04:39 PM
will SSR comps that fit an 03 fit on an 05 wrx? DieselClown Tire & Wheel 9 09-10-2004 06:46 PM
