Old 04-10-2007, 11:06 PM   #1
GripGC8
Member#: 110653
87 FC3S
Default Z4 stock ecu specs
does anyone know the specs for the factory Z4 ecu?
Rev limit
Boost limit
Fuel cut
etc..
etc..
any info would be great.
GripGC8 is offline   Reply With Quote
Old 04-10-2007, 11:25 PM   #2
rob
n00b Moderator
Member#: 811
2000 RS-Ej20G
It tastes like burning
Rev limit -- 7100 RPM
Max boost -- 0.87 bar (12.6psi)
Fuel cut -- 1.08 bar (15.7psi)
Speed Limit -- 113 MPH
-Rob
rob is offline   Reply With Quote
Old 04-10-2007, 11:29 PM   #3
hail2theTheif
Member#: 42548
2005 GF8 05 STi
Red
I'd really like to know where my ecu came from. obviously my clip but i've never heard anyone have the same specs as mine. out of a V2 STi 555 Edition
Rev Limit - 7250
Max Boost - 1 bar
Fuel Cut - never taken it there
Speed Limit - not sure either but the concenus on JDM limiter is 113 i think.
hail2theTheif is offline   Reply With Quote
Old 04-10-2007, 11:36 PM   #4
rob
n00b Moderator
Member#: 811
2000 RS-Ej20G
What's the 2 digit code on the ECU?
Old 04-10-2007, 11:38 PM   #5
GripGC8
Member#: 110653
87 FC3S
thanks again rob
Old 04-10-2007, 11:41 PM   #6
hail2theTheif
Member#: 42548
2005 GF8 05 STi
Red
good question...i'll see if i can find the pics of the clip before i bought it...if not i'll take a look see tomorrow
Old 04-10-2007, 11:58 PM   #7
rob
n00b Moderator
Member#: 811
2000 RS-Ej20G
cool. My guess is that it's the same as the ver2 STi ECU which was 6k. If so, I have the details for that ECU as well.
-Rob
Old 04-15-2007, 02:02 AM   #8
supasweetr34skyline
Member#: 113060
2000 Built GC8
Aiming for 10's
<--rocking the 6k ecu, so more info would be greatly appreciated
supasweetr34skyline is offline   Reply With Quote
Old 04-18-2007, 04:52 PM   #9
rob
n00b Moderator
Member#: 811
2000 RS-Ej20G
The only difference I see is in the boost targets. They are a tick higher for the 6k. Even the fuel and ignition maps look the same with the Z4.
Max target boost -- 0.94 bar (13.6psi)
-Rob
Old 04-18-2007, 04:52 PM   #10
rob
n00b Moderator
Member#: 811
2000 RS-Ej20G
Did you ever figure how to take the cover plate off?
-Rob
Old 04-19-2007, 12:22 AM   #11
kingsubi
Member#: 19239
Rev Limit - 7250
Max Boost - 1 bar
Sounds like the scoobyecu chip. Raises boost to 1.1 bar. On my 555 ecu it can get 1 bar but only b/c of the bigger turbo and free flowing exhaust.
kingsubi is offline   Reply With Quote
Old 04-19-2007, 01:47 AM   #12
rob
n00b Moderator
Member#: 811
2000 RS-Ej20G
What's the the 2digit code on your 555 ECU?
Old 04-19-2007, 01:54 AM   #13
hail2theTheif
Member#: 42548
2005 GF8 05 STi
Red
wierd i posted the other day responding but it didn't show up. how do you get the cover plate off? haha. i can see 3 screws but i have a feeling there are more than that. anyone?
Old 04-19-2007, 02:16 AM   #14
kingsubi
Member#: 19239
Forget if its the 6K or Z4...but found this jem while googling:
http://www.jprova.co.jp/product/engine/ecu.html
Old 04-19-2007, 12:14 PM   #15
Matt Monson
Member#: 832
99 2.5RS, '85 911
'73 914 and 2012 BRZ
-Rob
Are you sure about that rev limit? On Kbahus's 6K ECU I know he took it to 7500 a few times without hitting the limiter. Moose told him it was 7800-8000 when he sold it to him...
Old 04-19-2007, 12:40 PM   #16
Jaxx
Member#: 177
The 93 Imp W/EJ20K
flat black
ooh nice too bad it doesn't do the older stuff
Old 04-19-2007, 04:38 PM   #17
rob
n00b Moderator
Member#: 811
2000 RS-Ej20G
Not 100% sure. I only have a portion of the ECU dump for the 6k. It's possible that it's mixed up with some other code (although I would be suprised). I have the full code of the 7k (STi-RA ver 2) and the rev limit shows 7700. Perhaps Kbahus's ecu is chipped?
-Rob
Old 04-19-2007, 06:12 PM   #18
Matt Monson
Member#: 832
99 2.5RS, '85 911
If it is chipped that would explain a lot. I never pulled the cover on it to see if it was chipped and I don't have it anymore. And before you say anything, I know you wanted it, but a local offered me silly money for it along with a stripped Ej20G harness ready for swapping. I just couldn't pass it up...
Old 04-19-2007, 06:16 PM   #19
kingsubi
Member#: 19239
-Rob
7700 sounds like mine.
And I just picked up a scoobyecu for ~$100 to safely get up to 1.1bar and use regular pump gas. Although at $4.99/gal for 100, its not looking that much more based on the prices for 91 out here.
Old 04-20-2007, 02:42 AM   #20
Marnix
Member#: 51480
1984 AM5, 1994 BC4,
2010 BR5
AFAIK the STI ECUs rev higher than the stock WRX; the EUDM EJ20K ECU (MY97) allows 7200 rpm, 0.87 bar (fuel cut 1.08 bar) without speed limit - typically with long WRX gearing these do 6k in fifth at about 240-250 kph on the speedo.
Marnix is offline   Reply With Quote
Old 04-20-2007, 03:26 AM   #21
hail2theTheif
Member#: 42548
2005 GF8 05 STi
Red
where did you find the scoobyecu kingsubi? rare find or relativly easy to find? I would like to upgrade mine to get some more power outta my car but the PFC are gettin harder and harder to find for our cars and I have no idea how to tune it.
Old 04-20-2007, 01:39 PM   #22
kingsubi
Member#: 19239
check out this seller on ebay: rick9761
http://cgi.ebay.com/ws/eBayISAPI.dll...m=290106380853
some go for more, some less. Seems like he is making them by coping the scoobyecu map onto new chips. Either way I should get it in a week or so and update the differences.
Old 04-23-2007, 11:29 PM   #23
kingsubi
Member#: 19239
edit: mine is a 6K sti ver2 555 edition
Old 04-24-2007, 12:50 AM   #24
civic2scooby
Member#: 78658
2005 LGT Limited
Black/Black
specs for the W6 ecu?
civic2scooby is offline   Reply With Quote
Old 04-24-2007, 01:24 AM   #25
hail2theTheif
Member#: 42548
2005 GF8 05 STi
Red
would love to hear the results when you get it. i hope he will have more for sale if it works out. at the moment he has none listed.
WTT: Ecu-Tek ECU For 04 WRX Stock ECU nightcrawler60 SCIC Private Classifieds 16 03-10-2010 02:45 PM
JDM Z4 EJ20G ecu $150 00boostedRS Engine/Power/Exhaust 0 06-27-2009 08:57 PM
JDM Z4 WRX ecu $170 shipped 00boostedRS Engine/Power/Exhaust 0 06-20-2009 03:32 PM
Z4 virgin ecu 00boostedRS Engine/Power/Exhaust 0 03-31-2009 04:38 PM
FS: My stock ECU,GT Spec Headers, Crucial Race Pipe. From my 04 STI PKSJ4 Engine/Power/Exhaust 7 05-25-2008 10:24 PM
Message Board Statistics All times are GMT -4. The time now is 04:49 AM.
