Old 04-10-2007, 11:52 PM   #1
obyone
Member#: 16523
Default How the hell do you change the rear defroster light?
I have a 2000 RS and the little bulb on the switch burned out; the rear defroster still works thank God. I've pulled the front panel surrounding the stereo, pulled the clips and screws off the little compartment above the vents and it will move but not come out. For the life of me, I don't know how to pull the switch to swap out the bulb.
obyone is online now   Reply With Quote
Old 04-11-2007, 12:43 AM   #2
dans06limited
Member#: 126594
2007 STI
black
no clue but ill bump ya good luck
dans06limited is offline   Reply With Quote
Old 04-11-2007, 10:24 AM   #3
Subie Gal
GC84Ever
Super Moderator
Member#: 301
1970 FF-1 & '70 Van
02 WRX/01 RS
you cant swap the BULB in that unit
it's sealed
you'll need a new rear defroster switch
Jamie
Old 04-11-2007, 10:49 PM   #4
obyone
Member#: 16523
How do you pull the switch?
Old 04-12-2007, 06:46 PM   #5
obyone
Member#: 16523
bump for good measure
Old 04-12-2007, 09:37 PM   #6
4wdrift
Member#: 1403
99 RBP GC8 Impreza
You can pull the switch out with a good amount of pressure. If you are crafty enough you can take the switch apart and get a replacement bulb from radio shack.
4wdrift is offline   Reply With Quote
Old 05-07-2007, 04:58 AM   #7
obyone
Member#: 16523
4wdrift...I think you're going to need to break it down for me Crayola Style.
Do I pry the switch off with a screw driver from the bottom/side, do I need to pull some screws, pull a panel and then pull the switch?
I just don't want to break something.
How do you change the fog light? Lagwagon Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 03-03-2005 09:25 PM
How the hell do you get the header bolts off linux>windows Normally Aspirated Powertrain 17 09-22-2004 11:37 AM
04 REX how do you change the fog lights? kitbar Interior & Exterior Modification 2 04-12-2004 11:38 PM
How do you change the WRX parking light bulbs? YeeHa Interior & Exterior Modification 5 02-03-2002 05:06 AM
How do you change the Rear Speakers in a Legacy GT? BrysImpreza Car Audio, Video & Security 9 07-26-2001 04:43 PM
