Old 12-12-2001, 12:37 PM   #1
SoLo OnE
Member#: 9941
www.djforums.com
Default Best way to get FULL turbo boost?
I was wondering what is the best way to get full boost from the turbo?
Sometimes if I'm at 3000+ rpms and floor it I will only get about 12psi.
Is the best way just to mash the pedal to the floor, get the car up to 3000rpms then floor it, or just apply constant pressure to the gas pedal?
Jeff
SoLo OnE is offline   Reply With Quote
Old 12-12-2001, 12:58 PM   #2
JenisonWRX
Member#: 6049
02 WRX & 99 RS
MBC or EBC
with the stock system...I've noticed that I get more boost in second at partial throttle..*shrug*
JenisonWRX is offline   Reply With Quote
Old 12-12-2001, 01:39 PM   #3
jhonas
Member#: 9015
2002 Impreza 2.5RS
Platinum Silver Metallic
You'll need an aftermarket boost controller (EBC or MBC). It is my understanding that in 1st you only get partial boost, in 2nd you get a little more but not full, and 3rd-5th the computer will let you go full boost.
jhonas is offline   Reply With Quote
Old 12-12-2001, 01:49 PM   #4
Tinman
Member#: 8480
2002 WRX Sedan
Sold!
Not, for sure, so no yelling...but I thought the number was 4000 rpm and you should see full boost, but I've noticed that sometimes I do see less, and occasionally a higher spike in boost.
They're right though, unless you change the chip or boost controller, you'll have to live with what it's giving you.
Tinman is offline   Reply With Quote
Old 12-12-2001, 01:55 PM   #5
SoLo OnE
Member#: 9941
www.djforums.com
OK, maybe I should clarify my question a little.
In fourth or fifth gear (which should show full boost) and floor it, when I'm already at 3000+ rpms, I only hit about .9Mpa on my turbo gauge (about 12psi). But if I'm at say 2000rpms or lower and mash the throttle I sometimes see .1Mpa (about 14.5psi).
Does the amount of boost you see have anything to do with engine load? Is there anyway to achieve full boost if you are already at about 3000rpms?
Jeff
Old 12-12-2001, 02:00 PM   #6
JenisonWRX
Member#: 6049
02 WRX & 99 RS
yes....that is correct...
you should never see full boost in 5th gear...
thats just how they tuned it...your boost tapers off at higher RPMs to save both the turbo and engine. If you want to have full boost longer ... or just more boost for a given rpm...get an mbc or ebc
Old 12-12-2001, 05:54 PM   #7
knightsnke
Member#: 9461
what about for an auto . i feel i get max boost right after 4th gear at 40mph.?
knightsnke is offline   Reply With Quote
Old 12-12-2001, 10:08 PM   #8
JenisonWRX
Member#: 6049
02 WRX & 99 RS
do you have a boost gauge???
I don't know how an auto differs from a manual in that respect. But I would like to know...
Old 12-13-2001, 12:50 AM   #9
knightsnke
Member#: 9461
well knowing if I have a boost gauge or not doesn't answer my question really. only someone with an auto or driven an auto would know what im saying.
Old 12-13-2001, 08:26 AM   #10
peepshow
Member#: 1777
2005 LGT
#92 FZippy
Right, but what "feels" like full boost, may not be. The only way to know how much boost you are making is with a boost guage, so do you have one? If yes, are you making full boost (~14.5psi) in 4th gear @ 40mph? What RPM does that translate to? This information will answer your question.
- Trent
peepshow is offline   Reply With Quote
Old 12-14-2001, 09:52 AM   #11
Shag-e
Member#: 8168
2013 WRX Limited
you could weld the wastegate shut to get full boost...!!!!
well just a thought....
Shag-e is offline   Reply With Quote
Old 12-14-2001, 10:00 PM   #12
knightsnke
Member#: 9461
anyone with an auto that can assist in answering my theory of full boost at 40mph on 4th.
Best way to get a personal loan? Where to go? Samirr76 Tri-State Area Forum 10 03-14-2003 08:14 PM
ATX: best way to get to the airport. [27] Texas Impreza Club Forum -- TXIC 19 02-21-2003 03:20 PM
What's the best way to get to Logan Airport? Red Rocket New England Impreza Club Forum -- NESIC 17 02-06-2003 12:57 PM
Best way to get amp wires to x-over in doors?? fastsubie Car Audio, Video & Security 4 09-29-2002 10:12 PM
Best way to get to Myrtle Beach SC IMPREZIV Tri-State Area Forum 13 06-17-2002 08:14 PM
