Old 04-11-2007, 07:48 PM   #1
PhastEddie
Member#: 136545
2006 Evolution IX
Default Upgraded 03 WRX to 4pot/2pot. Brakes feel soft.
I have bled them twice. I am not a novice at this stuff. I am not sure what the deal is. The pedal goes down almost to the floor before I get any stopping power. if I pump the brake really hard real fast it grabs. But if I brake slowly, she goes down to the floor. The fluid was flushed and filled with motul racing brake fluid. Anyone got a suggestion?
PhastEddie is offline   Reply With Quote
Old 04-11-2007, 07:59 PM   #2
chrisarella
Member#: 35584
1965 FFR Roadster
Coyote + TR-6060
I had the same thing last time I did pads and rotors. I wound up bleeding and checking twice, when i cleared the last air bubble. I'd say you either still have one air bubble left in the line (which I suggest you have someone stomp on the brake pedal while you bleed the rears) or your master cylinder is on it's way out. More likely air than a bad MS though.
chrisarella is offline   Reply With Quote
Old 04-11-2007, 08:12 PM   #3
REX8
Member#: 24038
It could very well take more than 2 times. Further, if you have air in the abs system, you'll have to get out there and engage that a few times, then bleed to get it out of there.
Without a power bleeder, pulling everything off like you had to, a few more times to get it right wouldn't suprise me.
Old 04-11-2007, 08:52 PM   #4
PhastEddie
Member#: 136545
2006 Evolution IX
Will a power bleeder take care of the abs possibly as well? If so, what is the proper way to use the power bleeder? Are you referring to a pump as well?
Old 04-11-2007, 10:21 PM   #5
DrD
Member#: 22412
2012 Legacy 2.5GT
Ice Silver Metallic
it could be the seal in the master cylinder failing... I'd say maybe air in the master, but that wouldn't respond the way you said it does if you hit the pedal quickly
Old 04-11-2007, 10:35 PM   #6
Turn in Concepts
Member#: 93646
Many Track Records
Let us help you go fast!
Are you having trouble getting the pedal "hard" when the car is off? If there's little or no air in the lines then you should be able to get it rock hard with the car off.
If not then bleed some more.
If that still doesn't work then I would start to suspect a blown seal.
which reminds me of a joke.
A penguin is driving down the road in the desert. it's hot. Really hot. Suddenly his car starts freaking out. He pulls into the closest town and finds a mechanic. While standing there in the hot waiting for the mechanic he's really uncomfortable. Afterall, he's a penguin.
So he decides he's going to wander into town to find something to cool himself off. Off in the distance he sees an ice cream parlor...
Oh, wait. I've told this one here before.
Turn in Concepts is online now   Reply With Quote
Old 04-12-2007, 01:43 PM   #7
Psydotek
Member#: 44168
2003 Yellow WRX
with too many lights...
Are the bleed screws on the calipers pointing up or down?
Old 04-12-2007, 02:25 PM   #8
PossumK
Member#: 53548
2004 WRX PSM (sold)
2007 S2000
I had to Google the rest of the joke. Funny.
PossumK is offline   Reply With Quote
Old 04-12-2007, 08:30 PM   #9
PhastEddie
Member#: 136545
2006 Evolution IX
Yes when the car is off, it takes two pumps and its rock hard.
Old 04-12-2007, 08:44 PM   #10
BIGSKYWRX
Member#: 7958
09 GH B+
pay attention to this post- it's more common than you think getting the calipers swapped
if they are correct l/r and further bleeding doesn't help- I'd consider a power bleeder like Motive- relatively inexpensive and it allows you to crack the bleeders longer than "traditional" bleeding- often yielding some nasty, long air bubbles.
w/o a doubt something is awry as the 4/2 pots will yield a firmer pedal the oe sliders
Old 04-12-2007, 09:22 PM   #11
PhastEddie
Member#: 136545
2006 Evolution IX
The bleeding screws are in the proper place at the tops. Now, I highly doubt the MC is bad as it was fine before the install. I am going to try to bleed her one more time this weekend and get some hard pumps in there to push any other air out. Everything is installed correctly.
FEELER: 06 wrx 4pot 2pot brakes IL E6V6I6L MWSOC Private Classifieds 4 11-12-2008 02:15 AM
WTB: '06 / '07 WRX 4pot/2pot brakes drvrswntd Private 'Wanted' Classifieds 0 03-07-2008 05:24 PM
FS: OEM 2006 WRX 4pot/2pot Brake Pads F&R bobbybouchet Suspension/Brakes/Handling 1 04-25-2007 04:56 PM
Brake Comparison: Stock WRX vs. 4pot/2pot vs. Brembos leadfoot Brakes, Steering & Suspension 6 01-30-2006 05:00 PM
Read in another thread someone here was selling Subaru 4pot/ 2pot brake sets. BIGSKYWRX Southern California Impreza Club Forum -- SCIC 4 05-19-2002 02:07 AM
