Go Back   NASIOC > NASIOC Classifieds > Vendor 'For Sale' Classifieds > Engine/Power/Exhaust
Closed Thread
Old 04-11-2007, 11:07 PM   #1
Gruppe-S
Vendor Sales Rating: (65)
Member#: 23216
2006 949-457-1234
949-457-1234
Default VF34s $819!! HELIX Cat-backs Arrived $449!! EZ30Rs $1899 Gruppe-S 4-1 Headers 349!!!!
Hey guys,
Just landed 72x VF34's!!!
The Venerable VF34
For those of you who don't know the VF34 is the turbo found on the JDM STI Spec-C. It is a roller bearing based turbo that employs the best materials and the tightest tolerances in the turbo industry. These turbos take a huge amount of abuse and keep on boosting where many other turbochargers fail. No bearing / cooling issues like Mitsubishi turbos, no finicky oil pressure issues like Garrett turbos. These turbos are good for up to 375HP with excellent spool, transient response, and spool up. There have been a few 2.5 cars running low 12's high 11's with this turbocharger.
-Capable of 375HP
-Excellent response, spool up, durability (top end isn't everything)
-Roller bearing design
-High quality compressor / turbine castings
$819 Shipped!! (must mention this ad)
VF34 TURBO PACKAGE WITH AP
-IHI VF34 Turbo
-STI 565cc Pink Injectors*
-Walbro Fuel Pump
-Cobb V2.0 AP
-Gruppe-S Battery Tie Down
$1699
*STI pink injectors b/o for 2 weeks
VF34 TURBO PACKAGE WITH OPENPORT ECU
-IHI VF34 Turbo
-Open Port ECU Reflash Tuner
-Walbro Fuel Pump
$949
Gruppe-S V2 Manifold - IN STOCK!!
The Gruppe-S manifold is a 4 to 1 unequal length manifold. It will retain your boxer rumble and features T304 Stainless Steel piping, mandrel bends, and CNC precision cut flanges. The 4-1 collector is cast to ensure the smoothest possible low rates. This header is dyno proven to make power; it will not lose power or torque in 2.5L applications anywhere in the RPM range. 2.0L motors will lose some low-end and mid- range power to gain more high-end power and torque. The more modified your vehicle is, the more pronounced the gains from these headers will be. Includes all necessary gaskets.
The Helix V3 Uppipe is the perfect complement to the Gruppe-S Header. The large 2.3" piping allows for more exhaust gas volume, and the lack of a flex-section or restrictions ensures maximum exhaust gas velocity to spool the turbo.
Normal Price: $379.00
SALES PRICE: $349.00 SHIPPED!!
HELIX HELIX HELIX!! BACK IN STOCK!!
HELIX CAT-BACK!
-Helix Catback
-Great Fit
-3 Piping Diameter
Normal Price: $499.00
SALE PRICE: $449.00 SHIPPED!!
JDM EZ30R
I am told this is a junkyard engine pulled from a test Tribeca. This particular engine has a bit of leak down loss, about 15-20% loss (80-85%) across all 6 cylinders. Overall the condition of this engine is good (although a bit weathered) - a great candidate for a motor build. We can include custom forged Supertech pistons.
$1899 + Shipping
With 6x Forged Pistons $2199 + Shipping (These pistons have been upgraded to use STI wrist pins)
GRUPPE-S STAGE 2 GS650 SHORT BLOCK
-+2mm Helix Long Rod Ratio engine w/ ARP L19 rod bolts
-Custom Wiseco Forged Pistons with Det Coating (not shown)
-Nitrided, Cross drilled, Balanced Crankshaft (not shown)
-Race coated bearings
-Overall lighter rotating assembly, better balance, stronger internals
-Good for 8000+RPM operation, 650+ crank HP
$3299 + Shipping
Gruppe-S is offline
Old 04-11-2007, 11:07 PM   #2
Gruppe-S
Member#: 23216
2006 949-457-1234
949-457-1234
Y-PIPE & R2D2 BOV PACK!! - ONE IN STOCK!!
-SARD R2D2 BOV
-Gruppe-s Y pipe
Normal Price: $358.00
SALE PRICE: $289.00 SHIPPED!
2004 USDM SUBARU IMPREZA STI INTAKE MANIFOLD (RED)
This intake manifold is designed to be used with the 2004 USDM Subaru Impreza STI (EJ25). This manifold works with the TGV system as well as the drive-by-wire throttle bodies. It will NOT work with the WRX cable throttle body unless new holes are tapped. This is a great upgrade for any other EJ25 DBW car, such as the Legacy GT - the aluminum manifold both flows better and supports higher boost pressures than the plastic manifolds.
PRICE: $89.00 SHIPPED!!
Helix RR500 Turbo Super Special!!
-Perrin V2 Fuel Rail Kit STI - Black
-Perrin Turbo Inlet Pipe
-Helix RR500
-Helix 860CC Injectors
-Walbro 255 lph Fuel Pump
Normal Price: $2138.00
SALE PRICE: $1999.00 SHIPPED!!
HELIX RR500 Turbo Package!!
The Helix RR500 Turbo is a new turbo brought to us by Helix. This turbo is a 46lbs wheel turbo, race designed 8cm hotside, and features similar to the TD06 20G but with a larger compressor wheel. This turbo is rated at 500HP and will give you that extra boost of power when you most desperately need it.
This Package Includes
-Helix RR500 Turbo
-Helix 660cc WRX or Helix 860cc STI
-Walbro Fuel Pump
Sale Price: $1449 Shipped!!
Combo With Cobb V2 Access Port: $2099.00 Shipped!!
Turbo Alone: $999.00 Shipped
GRUPPE-S STAGE 2 (+2mm) FORGED INTERNAL KIT!
-Custom Wiseco +2mm Pistons
-Aerospace coating to reduce detonation and improve thermal characteristics (same as Cobb)
-Helix +2mm rods with ARP L19
-Longer piston dwell time improves rev range and top-end power
-Gruppe-S Coated Race Bearings
$999 Shipped!!
The Cobb Version 2 Access Port is one of the most user friendly systems on the market. This hand held ECU reprogramming system utilizes the full extent of your fuel management system allowing for easy, real time tuning. The Cobb AP V2 has come out with some upgrades since the Cobb AP V1 but still retains the high level of performance.
Cobb V2 Access Port Features:
-On the fly map switching
-Monitor vehicle sensor data and display in analog or digital format
-Vibrant color graphic display
-Read/Clear engine trouble codes
-Preloaded with performance, economy and convenience maps.
-Update via the Internet
-Measure 0-60 and ¼ mile times
-Adjustable on screen shift light functionality
-Estimates horsepower and Torque
-Displays current and averaged fuel economy
-Drag race simulation with reaction time and time slip data
-Built in on screen help mode function
-Multi language support
-RoHS Compliant (Lead Free design)
Cobb V2 Access Port Package 1
This package includes
-Cobb V2 Access Port
-Your choice of 1 Step Colder Spark Plugs or Walbro Fuel Pump
-Dyno Tuning
-Free Installation
Sale Price: $899.00 INSTALLED/TUNED
Cobb V2 Access Port Package 2
-Helix 660cc Injectors
-Walbro Fuel Pump
Regular Price: $1199.00
SALE PRICE: $899.00 OTD!!
INSTALLED/TUNED PRICE: $1149.00
Customers will have 30 days to schedule dyno tuning from time of purchase.
Non Local Customers!!!
This Package Includes:
-Set of NGK 1 Step Colder Spark Plugs
$699 shipped!
TURBO COMBOS!!
We have a great selection of turbo packages just for you Combo with Cobb Access Ports For ADDITIONAL SAVINGS!!
Forced Performance Green or Red Turbo Package
-FP Green Turbo or Red
-Helix 860cc Fuel Injectors
-Walbro Fuel Pump
-Water and Oil Lines
Regular Price: $2755.00
Combo With Cobb V2 Access Port: $2599 Shipped!!
Gruppe-S Y-Pipe Kit
The Gruppe-S intercooler hose kit replaces the corrugated rubber stock y-pipe, smoothing and increasing the airflow, making for a nice increase in power and better boost response. Includes a cast-aluminum Y-pipe, premium quality 4-ply silicon hoses, clamps. This kit will work for STi TMICs being installed on WRXs.
Normal Price: $99.00
SALE PRICE: $89.00 SHIPPED!!
SMC ALKI INJECTION KIT
-High quality / reliable pump
-Good for substantial horsepower gains
$499 Shipped!!
THANKS!!
-Travis
Gruppe-S
Gruppe-S is offline
Old 04-12-2007, 04:47 PM   #3
Gruppe-S
Member#: 23216
2006 949-457-1234
949-457-1234
Bump!!
Gruppe-S is offline
Old 04-13-2007, 06:38 PM   #4
Gruppe-S
Member#: 23216
2006 949-457-1234
949-457-1234
Bump!!!
Gruppe-S is offline
Old 04-16-2007, 01:27 PM   #5
Gruppe-S
Member#: 23216
2006 949-457-1234
949-457-1234
Bump!!
Gruppe-S is offline
Old 04-16-2007, 01:56 PM   #6
Patman015
Member Sales Rating: (1)
Member#: 106542
Pm sent, will the V2 Header mate to a Perrin GT3076R Rotated up pipe?
Patman015 is offline
Old 04-16-2007, 10:10 PM   #7
Gruppe-S
Member#: 23216
2006 949-457-1234
949-457-1234
Yup, the V2 header is designed to work with all stock location uppipes. It will work great with the Perrin turbo kit as the exhaust diameter is larger which works better with a GT3076.
Thanks,
Gary
Gruppe-S
Gruppe-S is offline
Old 04-16-2007, 11:30 PM   #8
Patman015
Member#: 106542
Thanks,
Gary
Gruppe-S
Okay then I'll take one. Is there a way I can contact you about this item and order it? I sent you a PM but no reply, i'd like to call you and pay for it. Thanks!
-Patrick
Old 04-16-2007, 11:36 PM   #9
-AliasMunky3-
Member#: 57407
1983 02WRX & 14BRZ
WRB & DGM
Awaiting response to PM I just sent
-Al
-AliasMunky3- is offline
Old 04-17-2007, 08:58 PM   #10
Gruppe-S
Member#: 23216
2006 949-457-1234
949-457-1234
Patman015 - Give me a call at (510)783-5300 and ask for me, Travis. I would be more than happy to help you place your order.
-AliasMunky3- - PM Replied!
Gruppe-S is offline
Closed Thread
FS CA: Gruppe-S 4-1 Headers (wrapped/coated) Ski Bum Engine/Power/Exhaust 6 05-25-2008 07:58 PM
FS-NYC/PA Gruppe-S 4-1 Header w/Cast collector $150 picked up amelnikov Engine/Power/Exhaust 7 07-25-2007 11:13 AM
Helix Downpipes $199 Shipped!Gruppe-S 4-1 Headers/$1599 Engines/VF22s/Turbos/Injector Gruppe-S Engine/Power/Exhaust 6 09-26-2006 09:39 PM
Gruppe-S 4-1 Headers/$1599 Forged blocks/VF22s/Built Motors/Turbos/Injectors/CobbAPs Gruppe-S Engine/Power/Exhaust 14 09-21-2006 08:22 PM
WTB: Gruppe-S 4-1 headers for an STI selds Private 'Wanted' Classifieds 0 04-10-2006 12:11 PM
